> Honda Accord (1990 - 2002)
Old 06-15-2006, 11:35 AM   #1
iLUVmyACCORD
iLUVmyACCORD's Avatar
Default Forbidden short shifter problem
where is the screw that i use to put into the short shifter?
the stock shifter has the screw embedded on to it so there isnt a xtra one for the new shifter
1995 AccorD ex cOupe
forbidden short shift
genesis HiDs
k&n intake
500hp shocker sticker.. http://images.honda-tech.com/set1/smile/emsmile.gif
iLUVmyACCORD is offline Report Post   Reply With Quote
Old 06-15-2006, 11:45 AM   #2
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: Forbidden short shifter problem (iLUVmyACCORD)
I think I remember reading that you need to go to Honda and buy the bolt. Contact Forbidden, I believe they can give you the exact part number you'll need.
TouringAccord is offline Report Post   Reply With Quote
Old 06-15-2006, 11:52 AM   #3
iLUVmyACCORD
oh thanks.. i think ill just head over to honda now
genesis HiDs
k&n intake
Old 06-15-2006, 11:55 AM   #4
khunt0012
Meat Robot Invisible
khunt0012's Avatar
Default Re: Forbidden short shifter problem (TouringAccord)
Not too sure about that. What year is the car?
94 Honda Accord - H22
khunt0012 is offline Report Post   Reply With Quote
Old 06-15-2006, 11:55 AM   #5
TouringAccord
H-T Order of Merit
Default Re: (iLUVmyACCORD)
If I remember correctly, I think you'll find it in the Prelude shifter diagram when you get to Honda. Just have the person at the parts counter pull up the diagram and show it to you, you should be able to locate it.
Old 06-15-2006, 11:56 AM   #6
TouringAccord
H-T Order of Merit
Default Re: Forbidden short shifter problem (khunt0012)
I could of swore that the shifter where intended for the Prelude and if you where buying it for and Accord you would need to buy that bolt from Honda. I'll try and find where I read that at.
Old 06-15-2006, 11:58 AM   #7
khunt0012
khunt0012's Avatar
Default Re: (TouringAccord)
Correct sir:
90165-SS0-000 is the part #. It's #26.
Old 06-15-2006, 11:59 AM   #8
khunt0012
khunt0012's Avatar
Yuo were right. I looked it up for an Accord which is wrong because the bolt actually is built into the Accord shifter.
Old 06-15-2006, 12:03 PM   #9
TouringAccord
H-T Order of Merit
ok, thought I might be loosing my mind there for a second
I just went onto SLHonda and looked at the same diagram you posted because I couldn't find where i read it just to verify what I thought. Then I came back about to post the pictures but you beat me to it
Old 06-15-2006, 12:05 PM   #10
khunt0012
khunt0012's Avatar
Haha, I use SLHonda too! I went all ninja on you there I guess.
Old 06-15-2006, 12:15 PM   #11
TouringAccord
H-T Order of Merit
haha, I like SLHonda because their diagrams are clearer than Majestic (HAP).
Old 06-15-2006, 05:41 PM   #12
VHOA
do they sell short shifters for automatics?
VHOA is offline Report Post   Reply With Quote
Old 06-15-2006, 07:41 PM   #13
fw190bvi
fw190bvi's Avatar
Send a message via AIM to fw190bvi
Default Re: (VHOA)
no. there is not a "short shift kit", however upgraded torque conveters can give you faster shift times. A short shift kit only acts to decrease the "throw" of the shift lever to get from one gear to another. Usually this is done by changing where the linkages connect to the rod, and the overall length of the rod.
im confused....why can't you use your old accord bolt?
I remember the dinosaurs
fw190bvi is offline Report Post   Reply With Quote
Old 06-15-2006, 08:02 PM   #14
sony224422
sony224422's Avatar
Default Re: (fw190bvi)
I think its because its built in.. atleast thats what i get from reading this.
96 accord lx- converted into 5spd ex http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
93 civic CX (project car)- Sold
1997 dodge ram 1500 sport 4x4 extended cab
360 magnum
sony224422 is offline Report Post   Reply With Quote
Old 06-15-2006, 10:18 PM   #15
momstaxi
momstaxi's Avatar
Default Re: (sony224422)
yes, and it should be noted that you really dont need this exact bolt to do the shifter install. any 8mm threaded bolt and nut combo would do just fine...
momstaxi is offline Report Post   Reply With Quote
Old 06-15-2006, 10:23 PM   #16
iLUVmyACCORD
yeah its built into the oem shifter....
the one forbidden has is made for the prelude.. but it fits for the accord also.. so for all you who is gonna get one.. ill advise you to go to a dealership and order that bolt part first before you order your short shfiter from forbidden..
i was lucky enough to find something small and round to fit through the hole to make it work for the mean time.. heres what im talkin about..
its #26 on the diagram a few post up..
genesis HiDs
k&n intake
Old 06-16-2006, 01:10 AM   #17
raceACCORDingly
you need the lude bolt and the little sleeve thing.
it doesnt feel right with a DIY sleeve and home depot bolt.
raceACCORDingly is offline Report Post   Reply With Quote
Old 06-16-2006, 06:20 AM   #18
TouringAccord
H-T Order of Merit
Default Re: (raceACCORDingly)
I've read that a couple times in other posts as well. Does it make it feel sloppy or something?
Also, iLUVmyACCORD, what year Accord are you putting this into?
Old 06-16-2006, 07:35 AM   #19
iLUVmyACCORD
95 ex coupe.. ill take a picture of what i have holding it together at the moment...
im gonna try to describe it.. im sure you all have headphones.. im using the headphone jack extension that you would use to plug it into a home surround sound stereo ..
exactly as pictured..
genesis HiDs
k&n intake
Old 06-16-2006, 07:52 AM   #20
TouringAccord
H-T Order of Merit
Originally Posted by iLUVmyACCORD
95 ex coupe..
Perfect
Would you mind doing something for me?
I was wondering if you could place the cable on the top setting and see if it hits anything like the console or just anything when you shift through the gears? Also, do you think you could place the cable in all three settings and descibe the difference in shift length and/or feel? And one last question, do you think you could take a picture of the final assembly so I can see where the shifter sits in the console, so I can see how much shorter it is from stock?
If you don't have time or if it's too much of a hassle, I understand. Those are just a few things I've been questioning but can't seem to find anything to answer them. If you could do that for me though I would really appreciate it.
Thanks
Old 06-16-2006, 08:10 AM   #21
honda4674
honda4674's Avatar
Send a message via AIM to honda4674
(is it SLhonda.com or is it a different domain name)nevermind sorry great site though
1990 Honda Accord LX
4 Door F22A1!
Right Side is The Best Side
honda4674 is offline Report Post   Reply With Quote
Old 06-16-2006, 08:25 AM   #22
TouringAccord
H-T Order of Merit
Default Re: (honda4674)
yeah, there are a couple online places like that where you can order parts from.
Majestic Honda (HAP)
San Leandro Honda
Old 06-17-2006, 09:57 PM   #23
iLUVmyACCORD
ill try and try out all the holes out and take pics.. im getting the screw on monday from HONDA so.. ill do it then..
genesis HiDs
k&n intake
Old 06-19-2006, 05:09 AM   #24
TouringAccord
H-T Order of Merit
that would be great, thanks
Old 06-27-2006, 10:42 AM   #25
TouringAccord
H-T Order of Merit
Just wondering if you were able to get those pictures and try out the other cable positions when you replaced the screw?
Bookmarks
1990, 2002, 90, 94, accord, forbidden, h22, h22a, honda, pictures, prelude, rod, sale, shift, shifter, short
