> Forced Induction
Old 05-30-2006, 03:14 PM   #51
BlackCRX
BlackCRX's Avatar
Default Re: (LaOstha)
Originally Posted by LaOstha
anyone having a problem with their car overheating with the small thin ass 92-95 radiators.
running an auto eg half rad right now
car overheated on me once on the hwy during rush hour and popped the head gasket
replaced the headgasket with arp headbolts and shimmed the hood hinges to help vent the hot air out
so far so good
stock D16Y8 + 15psi = 235whp
13.3@109mph - 15psi. granny shifting to save an already dying tranny
BlackCRX is offline Report Post   Reply With Quote
Old 05-30-2006, 03:35 PM   #52
blackeg
blackeg's Avatar
Default Re: (BlackCRX)
What does it mean when all the coolant is pushed back into your resevoir
bad headgasket or your head is lifting under boost.
new gasket and aftermarket headstuds torqued down pretty good usually solve that problem
hx coupe 2652lbs - lsvtec--318whp/241wtq
12.54@115.57 on bfg's
92 hatch---415whp/300wtq in '07
425whp/286wtq in '08 2410lbs
12.1@125.5 1bar boost @etown fall nats
blackeg is offline Report Post   Reply With Quote
Old 05-30-2006, 03:56 PM   #53
nonvtecD
nonvtecD's Avatar
Send a message via AIM to nonvtecD
Default Re: (blackeg)
D16y7
Stock rods
Suzuki Vitara pistons
ACL bearings
.48/.60 T3 turbo
JRC FMIC
DSM BOV
DSM injectors
Uberdata and Ostrich tuned up to 10 psi
My Garage:
Previous: 1994 Civic turbo, 1989 Civic hatch, 1985 Toyota MR2
Current: 2003 Pontiac Vibe GT, 1991 Mazda Miata, 2006 Yamaha FZ6
nonvtecD is offline Report Post   Reply With Quote
Old 05-30-2006, 04:15 PM   #54
civic nation
civic nation's Avatar
Send a message via AIM to civic nation
Default Re: (FR-MOB: SnoFlake)
never had a problem with mine my stock one went bad but that was after probably atleast 12 yrs of use it was the original
civic nation is offline Report Post   Reply With Quote
Old 05-30-2006, 06:17 PM   #55
Chronicsinners
Chronicsinners's Avatar
Default Re: (civic nation)
one day my setup will be finished
Current parts list:
Hf mani w/td04 adapter plate
Starion intercooler
Chrome w/ innovate wbo2
many more parts requred to complete the setup... aiming for 200whp
-Bobbo-
http://bobfab.blogspot.com
90 Civic - 08 SX4 - 03 CRF230 - 78 CB125s
Chronicsinners is offline Report Post   Reply With Quote
Old 05-30-2006, 06:22 PM   #56
FactionR
FactionR's Avatar
original thread: http://www.honda-tech.com/zerothread?id=1634662
Engine:
D16z6
Turbo set-up:
GT3076R w/ TO4S compressor housing and .82 a/r turbine housing
ATP oil inlet restrictor (.035") w/ 4 -an feed
ATP oil return flange and and 5 deg tilt return flange for the pan
Peakboost manifold (first made for a d-series :D )
Peakboost 3" DP (open) and WG dump
Tial 38mm WG
HKS BOV
JRC 8" FMIC
2" charge piping all the way around
Engine:
Stock head
Zex 59100 cam
Skunk 2 IM
B18 TB
Stock bottom end
Mr. Gasket crankcase evacuation system
Unorthodox ultra-r pulley
ARP head studs
Felpro HG
Ishihara-Johnson teflon crank scraper (first teflon CS made for a d16 :D )
Fuel management/Spark:
Hondata S300
RC 750cc's
PLX devices M500 wideband o2
Walbro 255 fuel pump
MSD 6a box
MSD plug wires
MSD blaster 2 coil
H22/H23 distributor cap
7-series NGK's
R1 grounding kit
Tranny:
Stock everything
CM stage 3 clutch
autozone axles
http://www.turbod16.com
FactionR is offline Report Post   Reply With Quote
Old 05-30-2006, 06:38 PM   #57
nerdsports
nerdsports's Avatar
Send a message via AIM to nerdsports
Default Re: (FactionR)
95' civic hatchback dx
d16y7 block [stock]
d16z6 head [stock]
arp head studs
d16y8 intake manifold
b-series throttle body
sfp short tubular manifold
t3/t04e .48/.60 50trim
38mm tial .5bar spring
2.5" to 3" downpipe
3" exhaust
dynomax muffler
2.25" & 2.5" charge piping
jrc 8" intercooler
walbro 255lph fuel pump
precision 440 injectors
aem fuel rail
ex/si transmission
act xtss clutch
fidanza aluminum flywheel
turboxs dual stage mbc
low: 7psi | high: 12.5psi
plx m300 wideband
moates.net hondalog
ostrich emulator
crome pro tuned
by Herman @ HermsFab
made 273whp/224wtq @ ~12.5psi
ran 12.19 @ 111mph and later that day, 12.17 @ 110.3 and cut a 1.7 60'
best picture i have of my setup.
BTW, this is a kick ass thread
i was wondering when someone was gonna start a sohc-t thread.
nerdsports is offline Report Post   Reply With Quote
Old 05-30-2006, 06:40 PM   #58
SovXietday
SovXietday's Avatar
Send a message via AIM to SovXietday
Default Re: (igo4bmx)
Originally Posted by igo4bmx
I saw your car dyno at the lansdale, PA meet.
good luck with your future setups!
Hey thanks!
I recently overheated at the track, probably blew a headgasket. Going tomorrow to do a compression test, car keeps heating up (not necessarily overheating) with these hot temps.
Oh and this is the setup.
-Aaron
1996 EK Hatch - 57trim SOHC
325whp 245wtq @ 18psi
1991 CRX Si - Daily Beater
Originally Posted by Ass$nyper
If your life was recorded in a film, it would be a chick flick.
SovXietday is offline Report Post   Reply With Quote
Old 05-30-2006, 06:58 PM   #59
Autoworks
Autoworks's Avatar
Default Re: (SovXietday)
Does the DOHC ZC count in this thread (SOHC block)?
http://www.GO-AUTOWORKS.com
88' Civic HB D16 10.99 @131MPH
09'-2010 Import Face-Off Race Sponsors...Keep the Sport alive, Come Race with US!!
Autoworks is online now Report Post   Reply With Quote
Old 05-30-2006, 07:19 PM   #60
coneheadsracing
coneheadsracing's Avatar
Default Re: (Autoworks)
92 Hatchie....
Fully gutted, no interior including glove box, and heater.
Racing seat,
Kirk racing 4 point on its way.
Suspension
Tien SS 16 way
Full bushing set
Skunk front camber, skunk knock of rear camber kit
Stock front brakes, with Hawk race pads (Awesome, noisy but awesome)
Rear teggy brakes, all stock
new stock 13/16 master
40/40 prop, or whatever it is
Engine
Y8/z6 tranny
stock rebuild
Ford t3/t4 .48/.60
Ef manifold
apexi blow off
dsm side mount
2 in charge piping
2.5 in downpipe (all i could fit)
3 in exhuast
msd 6al, blaster coil
dsm injectors
uber tuned for now, by me
Foster's oil can catch can
I went to the dyno last year, with a y7/y8 setup, but had issues, so 185 hp was not really true of my setup @ 15psi.
I did make a couple of trips to the strip though.
I went 13.4 my first time at 10 psi, went back and turned it up to 15 psi, and went 13.003 and a 13.004 @ 109 mph. This was on khumo street tires and a stock clutch. I was getting 60 fts. around 1.89 to 2.1
I have a act heavy duty and street disc now, but i really have built this car for road course track days, and i did one so far, it was in the rain, but still a blast, very controlable, no match to the m3's and all wheel drive cars, with traction control and abs, but none the less a blast.
I chose the D for cheapness, once i build one up fully, it won't have that cheapness factor though Right now i have the boost up to 17 psi, full stock, even head studs, i boosted 15 last fall for 3000 miles, so we'll see.
My wife hates Honda-tech......
coneheadsracing is offline Report Post   Reply With Quote
Old 05-30-2006, 08:09 PM   #61
W O T
W O T's Avatar
Default Re: (fast2camciv)
You have fun trying to get an 11 seconds pass with that setup man
Im leary I can every get one down in my crx and my motor has a built head ontop of yours, ramhorn manifold and a bigger turbo
Good luck though
W O T is offline Report Post   Reply With Quote
Old 05-30-2006, 08:41 PM   #62
JDMCRX
JDMCRX's Avatar
Send a message via ICQ to JDMCRX
Originally Posted by FR-MOB: SnoFlake
14.1 nd you were making 255?
wha car is this in?
Cars is a 4dr 1.6EL
Im having major tunning issues. oh the 255 was on my old motor. This motor is stock and feels like 190whp.
My Egts are going threw the roof 1400 all the time.
1999 Acura 1.6EL turbo D16Y8 300whp 2002 Suzuki Grand Vitara with H27 1995 Honda Civic SI Build thred http://honda-tech.com/showthread.php?t=23987711994 Honda Accord Wagon Build thread http://honda-tech.com/showthread.php...9#post36883659
JDMCRX is online now Report Post   Reply With Quote
Old 05-30-2006, 09:49 PM   #63
oxSLEEPERxo
oxSLEEPERxo's Avatar
Send a message via AIM to oxSLEEPERxo
Default Re: (JDMCRX)
there is some crazy sohc setup in this thread
Check Out My Profile For Vouches
oxSLEEPERxo is offline Report Post   Reply With Quote
Old 05-31-2006, 02:42 AM   #64
blackccoupe
blackccoupe's Avatar
Default Re: (oxSLEEPERxo)
cx mani
t25 dsm
bmc adapter
2.5dp.
2.5 charge piping
3" exhaust. jrc front mount
greddy blue box
fuel pressure 55 haha
moves pretty good 12.5 in boost
soon to be installed 310rc's j-k tuning chipped ecu for my setup then tune
dohc vtec its slow lol
vouches , 91_shoebox_Si, ls racer27, vtec8804, some more cant remember lol
blackccoupe is offline Report Post   Reply With Quote
Old 05-31-2006, 04:23 AM   #65
oxhernandez
oxhernandez's Avatar
Send a message via AIM to oxhernandez
Default Re: (blackccoupe)
D16Y7 block
Eagle rods
Suzuki Vitara pistons (fjt)
OEM honda bearings
OEM honda head gasket
ARP head studs
KMS block guard
D16Y7 head (very mild port/polish)
regrind cam
no cam gear
3" DP
KTeller 3" exhaust
T4/T3 Garrett 60ar, 60trim .48 exhasut
the first pull was @ 17psi
Second pull was @ 20psi
that was my car and i sold it what do you guys think no vtec baby over the 300hp barrier with vitara pistons and the car is still running as of today and sold it a year ago.
oxhernandez is offline Report Post   Reply With Quote
Old 05-31-2006, 04:30 AM   #66
oxhernandez
Default Re: (oxhernandez)
some pics of my old ride
Old 05-31-2006, 05:42 AM   #67
ELSpool
ELSpool's Avatar
303whp at 15 psi, 360whp at 21 psi (Mustang Dyno)
Benson Sleeved with CP/Eagle's
Self Ported Head
Supertech valve train
Stock Y8 Cam
Skunk2 IM with GSR TB
Full-Race T3/T61
Lovefab SST
780cc Precisions
Hondata s100 - Tapp Auto Tuned
Shooting for 400whp this year around 25 psi with a new GE IM and Crower Cam..
This pig's going 11's
Modified by ELSpool at 6:06 PM 6/9/2006
Modified by ELSpool at 1:35 PM 6/12/2006
Acura 1.6EL - D16Y8
11.22@125mph - Sold
ELSpool is offline Report Post   Reply With Quote
Old 05-31-2006, 05:58 AM   #68
Hyaboosta
Hyaboosta's Avatar
2002 civic ex
D17a2
SFP Mani
T3/T4 .48AR
2.5" DP
Greddy Type S BOV
Tial 38 mm
Spearco IC
Emanage
Turbo XS dual stage BC
Stock Motor
204Whp / 189 Lb. Tq @ 9PSI
ASE Cert. Honda dealer tech avalible for side work in Ft. lauderdale. Parts at cost http://images.honda-tech.com/set1/smile/emthup.gif
Hyaboosta is offline Report Post   Reply With Quote
Old 05-31-2006, 06:03 AM   #69
redzcstandardhatch
redzcstandardhatch's Avatar
Send a message via AIM to redzcstandardhatch
Default Re: (ELSpool)
in my 90 hatch recently, my setup (stock a6 head, stock block, SRPs/eagles) made 254 whp/297 wtq @20-ish psi. best time on street tires is 13.1 @ 110, with a miss from 5-7k rpms. (car only weighs 2000 lbs)
the head isnt flowing the greatest, obviously, and the turbo is MAXED i think (t3, .48/.60), i'm putting together a t3/t4 though (.63/60-1), so it should do better.
custom manifold i built, custom rad/intercooler crossmember, smaller spearco 3'' thick "sidemount" intercooler, backdoor design(turbo aims striaght into IC), greddy type s, 255lph pump, deatsch werks injectors (new, i'm beta testing their first honda set-so smooth, so nice), 3'' dp, 3''-3.5'' exhaust.
Modified by redzcstandardhatch at 2:16 PM 5/31/2006
Modified by redzcstandardhatch at 2:17 PM 5/31/2006
custom EF traction bar and a cheap K24 for sale too! PM!
WTB: useable h22 of h23 block/girdle..no crank needed
redzcstandardhatch is offline Report Post   Reply With Quote
Old 05-31-2006, 06:25 AM   #70
Autoworks
Autoworks's Avatar
Default Re: (redzcstandardhatch)
^^my fav. SOHC setup.
Old 05-31-2006, 06:31 AM   #71
redzcstandardhatch
haha! thanks man.
splitime and i retuned the new deatsch werks injectors last night.. so much nicer than my old 720's. smooth as silk, and seems to make more power up top too (diff. pintle design, 4 smaller holes, not just the one big pintle)
should be much more fun w/ new turbo.
Old 05-31-2006, 06:38 AM   #72
igo4bmx
igo4bmx's Avatar
Send a message via AIM to igo4bmx
Originally Posted by redzcstandardhatch
haha! thanks man.
more info on the injectors!
D-series TURDBO
300.8 whp/271.8 tq
MY CAR FOR SALE
http://www.hondamarketplace.co...40660
BOOST doesn't get you laid. Roofies and some creativity does however
igo4bmx is offline Report Post   Reply With Quote
Old 05-31-2006, 06:52 AM   #73
redzcstandardhatch
they are coming out with them soon, as long as i put some nice miles on these and they work for a while. they have the same pintle design as new evo injectors. it would seem they would attomize better. the flow charts i got with them are very specific, and they are brand new cores, obd0 plugs, high impedence injectors.
Deatsch is big into nissan and subaru stuff, my brother is good buddies with the owners brother (who is the other employee at deatsch, maxima-turbogeek-moderator, etc) we used to go to the track with him when he lived in chicago, etc.
when he met me, he asked me if i wanted to try out a set if they made honda-compatible stuff. a few months later, they arrived.
http://www.deatschwerks.com/
Old 05-31-2006, 07:41 AM   #74
RyanEJ8
RyanEJ8's Avatar
Not necessarily if it's just filling up the reservoir. Usually if the headgasket is blown the coolant will blow all over the place out of the reservoir under boost. If it's just pushing into the reservoir and not blowing out he might just be running a little hot after a couple of hard pulls.
2000 Honda Civic EX Coupe D16Y8, 12.80@105.8 14 psi SOLD
2004 Ford F150 XLT Supercab Triton V8
RyanEJ8 is offline Report Post   Reply With Quote
Old 05-31-2006, 09:28 AM   #75
SVPCEO
SVPCEO's Avatar
Send a message via AIM to SVPCEO
Default Re: (W O T)
his set up has potential...........should run 11s if he makes over 300 hrses...............
SVP "THOUGHT YOU KNEW"
DNR PERFORMANCE,HAYWARD CA
510-783-5565 OR 510-783-5200
DNR-PERFORMANCE.COM
CMI 04/23/06 10.3@144 &10.4@147 spinin down the track
9s around the corner http://images.honda-tech.com/set1/smile/emwink.gif
DNR-PERFORMANCE http://images.honda-tech.com/set1/smile/emthup.gif 1320CUSTOMFAB.COM http://images.honda-tech.com/set1/smile/emthup.gif SPOOLIN PERFORMANCE http://images.honda-tech.com/set1/smile/emthup.gif MODACAR http://images.honda-tech.com/set1/smile/emthup.gif
SVPCEO is offline Report Post   Reply With Quote
Bookmarks
16g, 35, big, build, cam, centraldriver, chart, cover, d16y8, flow, garret, h22, honda, hx, l3, single, thread, torq, turbo, valve
