> Honda CRX / EF Civic
Old 05-27-2006, 09:34 AM   #1
b16_madman
b16_madman's Avatar
Send a message via ICQ to b16_madman Send a message via AIM to b16_madman
Default How to: Install replica bass tubes Crx cr-x jdm
So, this is a pretty simple deal & how to's shouldn't be necessary for anyone, but I'm relaxin Saturday & figgured I'd make this for whomever.
Take your bits n pieces:
- drill bit smaller than your screws of choice (to secure speaker)
- your 6.5" speaker of choice
- needlenose pliers
- phillips head screwdriver
- flathead screwdriver
- one big fan to keep you cool
- one nice light if you do it at night
First, go ahead and remove the rear speaker grills, obviously. That's what the flathead is used for. To pop the grille loose after you undo the 2 phillips heads.
Next, remove the OEM honda speaker that's held down by one screw, now that's funny.
Be sure to remove all four of those phillips heads you see, because the tubes will mount to those for holes.
Next take the wiring that comes out of the rear of the tubes & connect the two to eachother. The smaller female blade connector is the negative side & the larger is positive.
Here's an issue I came up with. The male blade connectors are both the larger size, but problem solved if you just slide it inside the oem insulator around the female blade. It holds fine.
next, carefully fit the tube into place, may require a bit of a shove, but don't gorilla it in there, it should fit.
Personal prefrence is I mounted the speaker after I installed the tube itself. If you've got a steady hand do it this way, if you don't install the speaker first like here.
Next, the replica tubes do not have any holes for you to mount your speakers, my tool of choice isn't a huge drill, it's a hand drill.
just flip the wrist a few times and w/out too much pressure you should have your necessary holes. I did this with the 6.5"s sitting on the tube, so don't slip & poke your speakers
after all that you should have it all done and lined up.
As a refrence point if you want to do it like I did, see where the mounting tabs are. I doubt it matters a lot but i wouldn't cover the speaker port.
BE CAREFUL drillingn those holes, and also when installing the screws. It's thin fiberglass.
Always do this on a nice sunset.
TO clear the wind:
These aren't subwoofer replacements. Sheesh, I'm still going to install my sub since I have it just sitting around. The tubes MOVE air, you can def. feel lots of air moving through that port. No, it's not whistly or anything you only hear the speakers. Ideally you'd want tubes in the front, but these work great, are a piece of cake to install & are a lot cheaper than the real deal. I think they sound fine so I'm leaving them how they came. Some say stuff them with polyfill, but meh, I have other things to do.
The skinny:
Where can I order these?
Orange Hat Design
Who can I ask to bug him questions about what he made?
jdm_tubes@comcast.net (Jonathan Bianco)
I don't work for them or anything, just helping out.
donnanphotography | crx | m coupe
b16_madman is offline Report Post   Reply With Quote
Old 05-27-2006, 10:55 AM   #2
Tippyman
Tippyman's Avatar
Cool! Seems like there is alot of talk going on about these lately...
-95 Miata DD
-91 Civic Turbo
Tippyman is offline Report Post   Reply With Quote
Old 05-27-2006, 11:09 AM   #3
itsmike
itsmike's Avatar
Default Re: How to: Install replica bass tubes Crx cr-x jdm (b16_madman)
Originally Posted by b16_madman
TO clear the wind:
How exactly does this tube "move air"? What will that do and whats the result of the install... more bass? louder?
For Sale:
-Two JL Audio 12" Subs in Box w/ Grills - $220
-OEM 94-95 Accord tail lights - $25
-OEM 94-95 Civic corner lights - $10
References: delsolguy, tbud454, jabroni95gsr, JDMisGood, milton, -_-, AngelTeg, {Powered by R}, revolt_allmotor, Skyliner, IntegraDriver, bart2546...
itsmike is offline Report Post   Reply With Quote
Old 05-27-2006, 12:04 PM   #4
b16_madman
b16_madman's Avatar
Default Re: How to: Install replica bass tubes Crx cr-x jdm (itsmike)
"enclosure"
ported
[quote=diysubwoofer.comThe ported enclosure system is characterised by lower distortion and higher power handling in the system's operating range, and lower cutoff frequency than a sealed enclosure system using the same driver. Distortion rapidly increases below the cutoff frequency however as the driver becomes unloaded, and the transient response of a ported enclosure system is usually inferior to that of a sealed enclosure system using the same driver. However, the lower cutoff frequency and better power handling within the system's passband often makes ported systems the alignment of choice for many speaker builders.[/quote]
I'm not going to go in to how all that stuff works down to a science. Honda already did that for me with this design. this guy just modeled the design so that more people can enjoy them w/out the $400 "rare" pricetag.
They are deep. For example, if you need to undo your rear shock assembly (the 2 14mm nuts) you will probably hav eto take these out if you still have full interior.
go inside any nice living room equipped with a speaker system
there you will find ported enclosures & no not more bass. it's not made so that you can listen to more bass, it's fuller richer sound
Old 05-31-2006, 12:36 PM   #5
rexerin
rexerin's Avatar
Send a message via AIM to rexerin
nice write-up, i just got my set a day or two ago
My Cars:
1991 CRX Si - Project Car
1993 del Sol Si - Daily Driver
2004 RSX-S A-Spec - Daily Driver
Pics of my Cars
My Stuff For Sale!
"they call me baby driver, and once upon a pair of wheels, i hit the road and i'm gone! what's my number? i wonder how your engines feel..." ~ s & g http://images.honda-tech.com/set1/smile/emsmile.gif
rexerin is offline Report Post   Reply With Quote
Old 05-31-2006, 01:14 PM   #6
njn63
njn63's Avatar
Send a message via AIM to njn63
you don't by any chance have any measurements on these do you? Like how much space they have or the size of the speaker hole? I had a set of JL 6w0 subs sitting under my bed that might fit decent in those and they need almost no space for a box. Hmm..
And no, i'm not interested in a single 10". I need my cargo room and don't like obvious systems.
edit: Forgot to add, that's not the way the speakers came factory in the back (at least not in my car). Your car should of had some metal plates that were the right size to hold 6 1/2" speakers. You'd have to take them out anyways of course, just figured i'd note that.
Modified by njn63 at 5:50 PM 5/31/2006
2000 S2000 Hardtop // 1993 Miata // 1991 CRX HF
Originally Posted by aquito View Post
is it true that if u have a GF and have been living with her for years..its the same shit as being married? meaning that if you break up everything goes half?
njn63 is offline Report Post   Reply With Quote
Old 06-01-2006, 09:42 AM   #7
b16_madman
b16_madman's Avatar
Default Re: (njn63)
yah well maybe they did rear oem speakers different ways.
The car was untouched before I got it. heh i should've left it tha tway
Old 06-01-2006, 10:14 AM   #8
crx_88_si
crx_88_si's Avatar
ya some1 just did that, with the 1 screw. here is the OEM rear speaker mount kit.
these are not mine, i got a new oem package (comes w/ wires) from Tuner Toys but they are out of stock.. you can email them and ask it was only like $15.
Vouche: Jay-C
My Car: http://www.cardomain.com/id/crx88si
crx_88_si is offline Report Post   Reply With Quote
Old 06-01-2006, 02:21 PM   #9
b16_madman
b16_madman's Avatar
Default Re: (crx_88_si)
But why would I do that.
Old 06-01-2006, 02:38 PM   #10
Chase
Chase's Avatar
Default Re: (b16_madman)
i can do backflips...
dAng! PG+K
EMAIL ME at ChaseBaysOnline@gmail.com | EMAIL ME at ChaseBaysOnline@gmail.com
Chase is offline Report Post   Reply With Quote
Old 09-04-2006, 10:02 AM   #11
88hfef8
88hfef8's Avatar
Default Re: (EF8kid)
where can i get replica bass for my crx and how much are they?
thanks
88hfef8 is offline Report Post   Reply With Quote
Old 12-19-2006, 09:51 PM   #12
jdmcrx34
jdmcrx34's Avatar
Default Re: (88hfef8)
dose anybody else sell these the link on this thread no longer works.
jdmcrx34 is offline Report Post   Reply With Quote
Old 12-20-2006, 12:09 AM   #13
MasterShake
MasterShake's Avatar
Send a message via AIM to MasterShake
subin
Originally Posted by .brian.
bullshit asshole. nobody likes the tuna around here/
<FONT COLOR="blue">ADD ME!!!! - http://myspace.com/komplecks1
http://images.honda-tech.com/set1/smile/embeer.gif http://images.honda-tech.com/set1/smile/emcocktl.gif http://images.honda-tech.com/set1/smile/embeer.gif http://images.honda-tech.com/set1/smile/emcocktl.gif
Free The Mind - NGE -_-</FONT>
MasterShake is offline Report Post   Reply With Quote
Old 12-20-2006, 01:16 AM   #14
Bastion
Bastion's Avatar
Send a message via ICQ to Bastion Send a message via AIM to Bastion
Default Re: (MasterShake)
Stay tuned for.. How To: Install Furry Dice in the Rearview Mirror! Honda-Tech Exclusive!
God was my co-pilot, but we crashed into a mountain and I had to eat him..
Bastion is offline Report Post   Reply With Quote
Old 12-20-2006, 05:07 AM   #15
Sifu
Sifu's Avatar
Default Re: (jdmcrx34)
I have the real deal if you want it, PM me
Sifu is offline Report Post   Reply With Quote
Old 12-20-2006, 05:59 AM   #16
CoolRedXylophone
CoolRedXylophone's Avatar
heres the link http://web.mac.com/bun_stylz/i....html
heres the thread http://www.honda-tech.com/zero...ge=12
great guy i will vouch for him email is [ jdm tubes@comcast.net ]
CoolRedXylophone is offline Report Post   Reply With Quote
Old 12-20-2006, 10:56 PM   #17
jdmcrx34
jdmcrx34's Avatar
Default Re: (CoolRedXylophone)
thanks ill be thumping 6.5 pretty soon now
Old 12-21-2006, 02:40 AM   #18
miketurbohonda
miketurbohonda's Avatar
OMG do you guys Actually want them bass Tubes !!!!!!
ive thrown out like 2 sets that were laying round the garage!!!
ive got a set still in 1 of my crx's id quite happenly get rid of
ZC Dohc Turbo EF3 169.2whp (old Setup)
New :Bigger Turbo /Bigger Front Mount /More Boost !!!
miketurbohonda is offline Report Post   Reply With Quote
Bookmarks
bass, cluster, crx, enclosure, fit, gauge, honda, install, installing, jdm, nitrous, rear, si, speakers, work
