> Hybrid
Old 05-23-2006, 04:43 PM   #1
amy
Default h2b into Del sol
Picture Updates Pages 3, 9, 12
specific instructions are located here http://www.quartersportsdrag.com
What you need for this swap:
H22 or F22 longblock and its components
H or F series Exhaust manifold (will have to be modified to connect to existing exhaust piping)
B-series transmission
H2b Adapter plate Kit (www.quartersportsdrag.com)
B-series axels
B-series mounts with polyurethane inserts or aftermarket B series mounts
B-series starter
B-series slave cylinder
B-series clutch
B-series ALUMINUM flywheel
4 OEM Honda alignment dowels
NOT REQUIRED but definately something to consider:
-Better cooling system, either an aftermarket aluminum dual core radiator or a del sol VTEC radiator will work
-Aftermarket mounts for a b-series motor
-Using a chipped p28 instead of a prelude's p13; P28 does not look for a knock sensor or egr system which I hear is a major pain in the ass to do up
-Removal of balance shafts (i did not do this but many other H2b'ers have) will require a freeze plug to keep oil from spurting out. They can be found here: http://www.kaizenspeed.com/.
-Alternator relocation kit. My alternator did NOT fit in so I had to get a relocation kit so it would work. http://www.explicitspeedperformance.net offers many different options and has kits for OEM spec or for those who have removed their balance shafts.
-Machining off the Power steering pulley. To create a bit more room, I had the P/S pulley machined off of my crank pulley. I used this machine shop Master Grinding Services Inc.
Just thought I'd post some pics up of how my install went for all who are contemplating this swap
Aluminum Flywheel with the aluminum spacer that is included in the kit.
exedy clutch goes on as if it were just a plain old b series swap
The plate is attached first with 4 countersunk bolts that you need an 8mm hex to tighten. They're on the top and right side of the plate (2 and 2)
The tranny was a bit of a pain in the ass to put on with the 2 dowel pins in the block and 2 in the tranny... This part is definately a two person job. One person held the block and guided the tranny on making sure the bolt for the starter gets lined up while the other used their big strong muscles to lift the tranny up and push it on...
Ah, everyone's favorite part: grindin down the backside of your motor... I was surprised by how far in you actually have to grind, almost right down to the oil pan bolts... Don't forget your gasket sealer afterwards
A shot of the back of the motor with the intermediate shaft and the adapter bracket for it..
I decided to keep the balance shaft assembly in tact but removed the belt and tensioner. The lower timing belt cover was reinstalled with a slight trim on the top. The power steering pulley has to be machined down so it'll fit. (will get pics of machines crank pulley as soon as i get it back)
Where the frame rail had to be bashed in... Doesn't look too bad. This project is good for anyone who needs to get out some pent up aggression
Edit: as of 7/5 had to take the motor back out so we decided to create a little more clearance
and let's not forget my knockin motor
Modified by amy at 10:20 PM 11/3/2007
amy is offline Report Post   Reply With Quote
Old 05-23-2006, 05:31 PM   #2
vtecspeed1320
Shooting Star
vtecspeed1320's Avatar
Send a message via AIM to vtecspeed1320
how did your scam thing end up coming out....looks nice...cant wait till mines done. what trans you sportin
Evo VIII
2.3L 4094r
vtecspeed1320 is offline Report Post   Reply With Quote
Old 05-23-2006, 05:36 PM   #3
amy
Default Re: (vtecspeed1320)
my bank was able to resolve it with paypal...
I am using a 00 b16 tranny with b16 sir II lsd
Old 05-23-2006, 05:51 PM   #4
vtecspeed1320
Shooting Star
thats awesome for both things, youll have to stop back and check out my h2b turbo build at the end of the summer.
Evo VIII
2.3L 4094r
Old 05-23-2006, 10:01 PM   #5
amy
nice
I hope to have some new pics as of Thursday with more progress
Old 05-23-2006, 10:09 PM   #6
2fast4u831
I'm really 2slow
1994 Honda Civic
2fast4u831's Avatar
Send a message via AIM to 2fast4u831
Default Re: (amy)
looks good keep the pics coming
H2B squad member #09 my project
Turbogixxer
2fast4u831 is offline Report Post   Reply With Quote
Old 05-23-2006, 10:58 PM   #7
thahuhstunna
thahuhstunna's Avatar
Send a message via AIM to thahuhstunna
Default Re: h2b into Del sol (amy)
can't wait for updates
Originally Posted by John Gaherin
We’re just talking about money here. Money is not the maiden’s virtue, it’s the currency of whores.
Originally Posted by rogue420
Fine you win jesus.
http://images.honda-tech.com/set1/smile/emsmilep.gif
Originally Posted by Kenny Rogers
I cheat.
http://www.postgamepub.com/phpBB2/index.php--Up and Running
thahuhstunna is offline Report Post   Reply With Quote
Old 05-24-2006, 04:04 AM   #8
Gold DA9
Gold DA9's Avatar
Send a message via AIM to Gold DA9
Default Re: h2b into Del sol (thahuhstunna)
I've been waiting for these updates for some time. Glad to see it coming along. Cant wait to see numbers and track times. Getting ready to start pieceing together my kit.
What flywheel and clutch setup are you using?
YC Underground Street and Dyno Tuning York, PA
www.ycunderground.com
REJECT SQUAD #90
Gold DA9 is offline Report Post   Reply With Quote
Old 05-24-2006, 05:40 AM   #9
NJcoupe
NJcoupe's Avatar
wow, looking good!
You should fill/get inserts for the driver side mount so it doesn't move to much, skunked had that problem.
You're keeping powersteering?
NJcoupe is offline Report Post   Reply With Quote
Old 05-24-2006, 06:08 AM   #10
DC4_MADMAN
AKA DEMOLITION_MAN
DC4_MADMAN's Avatar
Send a message via AIM to DC4_MADMAN
Looks good, so the block just has to be shaved to clear the halfshaft assembly?
I am also currently trying to slap an H2B assembly together, but it is taking quite longer than I thought it would, you know, budgets and all. Got the trans(JDM B16 with Kazz), Clutch(CC stage 3), and flywheel(Fidanza), its a start I suppose.
Should get an H2B rollcall going to see how many are running the setup, what times they are running etc.
Recent vouches- cluelessmale, superdave, hondab20t, Its the kidfolk, Midnight Racer X, motrayEG6, 95 Integra, BoltonGSR, Savedone, strang3help, satanracing, jdmcd7_cali-luv, berb_15, ryc555, LudeSH
DC4_MADMAN is offline Report Post   Reply With Quote
Old 05-24-2006, 08:17 AM   #11
AdamITR
AdamITR's Avatar
Looks Great!
AdamITR is offline Report Post   Reply With Quote
Old 05-24-2006, 10:48 AM   #12
ejwan
ejwan's Avatar
good writeup/info with working pictures. thanks for sharing
curent ride= 2 X DB7
previous ride - EJ1 sold - DB1 stolen
DB Squad Member #188
ejwan is offline Report Post   Reply With Quote
Old 05-24-2006, 10:51 AM   #13
amy
Default Re: h2b into Del sol (Gold DA9)
exedy stage 1 clutch and i'll have to double check on my flywheel, it was a donation from my boyfriend who upgraded
Originally Posted by dxcoupe.
wow, looking good!
Yea i have the inserts, they still have to go in... I'm going to see how it is with them and if it doesn't feel right for me I'll probably go with mounts from Hasport or Hcp
and no Definately not utilizing P/S, my car never came with it from the factory and I'm not about to add it now
Old 05-24-2006, 10:53 AM   #14
EJ1 wilcox
EJ1 wilcox's Avatar
Default Re: h2b into Del sol (ejwan)
Looks great!
How much do these H2B kits run?
EJ1 wilcox is offline Report Post   Reply With Quote
Old 05-24-2006, 01:31 PM   #15
skunked
skunked's Avatar
Send a message via AIM to skunked
Default Re: h2b into Del sol (EJ1 wilcox)
looks great Amy, I'm digg'n the valve cover.
PS-Put the inserts in!!!!
2.2L H2B NA DC2 S/P 12.1@110
http://www.quartersportsdrag.com/
SINISTER RACING
skunked is offline Report Post   Reply With Quote
Old 05-24-2006, 03:56 PM   #16
amy
Default Re: h2b into Del sol (skunked)
haha the VC is no longer that color
Old 05-24-2006, 03:57 PM   #17
skunked
skunked's Avatar
damn girls!!!!
SINISTER RACING
Old 05-24-2006, 09:15 PM   #18
SlowCGP_EJ8
SlowCGP_EJ8's Avatar
Definitely looks great!
I've had my long block for ages and am so anxious to get my project rolling..
Too bad Im a broke college kid with no dough, haa.
Cant wait to see some numbers and 1/4 mile times.. Great Work!
PS - How much did you pay for the kit from quartersports?
- 1998 CGP EJ8 (The Daily Grind)[EJ8 Squad #075]
- 1995 PBGP EJ1 (An Extra Daily Grind)
- 1999 EBP EM1 (Project)
SlowCGP_EJ8 is offline Report Post   Reply With Quote
Old 05-24-2006, 09:52 PM   #19
AllMotorRandy
AllMotorRandy's Avatar
Send a message via AIM to AllMotorRandy
Default Re: (4door_demon)
Originally Posted by 4door_demon
........Should get an H2B rollcall going to see how many are running the setup, what times they are running etc.
Here is my setup. Almost ready for NHRA in Las Vegas!!! See you guys there!!!
Team H2B
"10's or BUST!"
Exospeed Racing Wheels | Skunk2 | Torco | MFactory | QSD | Camp1320
AllMotorRandy is offline Report Post   Reply With Quote
Old 05-24-2006, 10:10 PM   #20
DeuceD
DeuceD's Avatar
Default Re: (AllMotorRandy)
do you have a shot of the hood closed? would like to see that.
Plenty of Vouches. Just PM me and let me know if you need any.
DeuceD is offline Report Post   Reply With Quote
Old 05-24-2006, 10:14 PM   #21
thahuhstunna
nice specs of the set up, and how did you close the hood, heard this is a problem with H2B's
Fine you win jesus.
I cheat.
Old 05-25-2006, 07:03 AM   #22
skunked
skunked's Avatar
Default Re: (thahuhstunna)
1" spacers guys, 1" spacers......I tell everyone this everyday it seems.
2.2EG has posted pics of this as well.
SINISTER RACING
Old 05-25-2006, 07:16 AM   #23
2fast4u831
I'm really 2slow
1994 Honda Civic
2fast4u831's Avatar
Default Re: (skunked)
it looks more like 1/2" on his car home depot right Matt?
Turbogixxer
Old 05-25-2006, 07:20 AM   #24
skunked
skunked's Avatar
Default Re: (2FAST4U831)
it depends on the type of hood and MAP location, anywhere from 1/2" to 1" spacers.
Home Depot or lowes sells aluminum stand-offs that work perfect.
SINISTER RACING
Old 05-25-2006, 10:06 AM   #25
STEV3-O
STEV3-O's Avatar
Send a message via AIM to STEV3-O
my hood hits the valve cover, timing side
1995 Civic CX H22/H2b- Out of Order
2000 S2000 GPW- New Toy, but miss the Duce Duce Powa
H2B
http://explicitspeedperformance.net/
Vouches
Anekin007, Whoisdan, Bucbaby, LSeeper, 1995charDX, JRSC EM1, Greenciviceg, Lookalike_eh2, HUBB, YayAreal2acer, 3RdT, DATZ WEAKSAUCE, loud3nergy, skunked, RotiEatter, Propulsion, Vita-Soy
STEV3-O is offline Report Post   Reply With Quote
Bookmarks
14, alternator, del, h22a, h2b, honda, hondatech, kit, las, mile, motor, relocation, sol, tech, vegas
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
