#1 | |||||
#2 |
create a nice tight little bung hole in your manifold for it.
FORMERLY ITR206 05 EB Evolution |
#3 |
#3 runner within 2 " from the head
#4 |
I heard that #1 is the best spot to put it?
#5 | |
Listen to sgT, #3 runner is the ideal place for your 4cyl Honda
Dave |
#6 |
i just got a EGT gauge too. shouldn't you put it some place where it could read all 4 cyl. If you put it on #4 cyl. and something goes wrong with #1 injector, you wouldn't know it? just a thought. how close to the head does it have to be? should it be before the turbo or can it be after?
#7 |
The best place for accurate readings is in the hottest cyl(#3) within a distance
from the head which is equal to the diameter of the exhaust primary. Every inch farther than that point and the temp drops SIGNIFICANTLY. |
#8 |
thats funny, I see a LOT of people put the probe allllllll the way down on the downpipe, near the downpipe Flange/collector.
#9 |
well, they are probably real happy with their egt readings
#10 |
SGT is right, you want it at your hottest spot! A fuel pressure guage will tell you if something like an injector fails in cylinder 1. EGT is not meant to monito that!
For Sale: Greddy Peak/Warning oil pressure gauge. Never used, asking $150 shipped. |
#11 |
If you do this, will a new drag manifold crack? I will perform this mod within a week. Anybody know?
For sale: Momo Steering wheel and hub for Civic or integra Powered by Dynamic Autosports 949-457-1234 Lake Forest, CA Hondata http://www.hondata.com Torrance, CA Mochanic, absolutely the BEST technician in Houston, Texas. Trust Me! http://www.hughlett.net/ |
#12 |
no cracking yet
#13 |
the instruction that came with my auto meter EGT says to put the probe on the down pipe close to the turbo.
#14 |
Sorry I am a turbo newb and would like to know how I can tell if the installer is doing thing wrong? I am having the kit installed by someone who has done many turbo installs so am not too worried, but would like to know. What is the proper way of putting the EGT sensor in the manifold? Just drill it large enough for the sensor to fit? Could someone please expand on what is actually done....thanks.
#15 |
i left the car running so when I drilled my manifold the shavings blew out instead of having a good time in the turbine blades. Use a bit a tad smaller than the fitting then crank the fitting in.
...that in-cabin turbo smell... U-U-D-D-L-R-L-R-B-A-SEL-START |
#16 |
My EGT is tapped right at the tippy top of the dp where it meets the turbo, its accurate as hell :D
[Stolen 10/19, recovered 10/21, stripped and destroyed] R.I.P. http://images.honda-tech.com/set1/smile/acura1.gif 99' Integra LS 2dr (auto-no more) 5spd now 14.338 @ 101.29 MPH 189whp @ 8psi (.58 bar) 167lbs of tq Rev Hard Stage 2c T3/T04e S-AFC hack + Rc 440cc injectors (TUNED!!) TechEdge wideband o2, Greedy Boost + Egt gauges Stock internals Pics and mods here: http://shadowdawn.dyndns.org:81/car.htm |
#17 |
do you need to remove the turbo from the manifold before drilling a hole for the EGT? or can you just let it blow out the exahust turbine??? I know this is a stupid question but I'm curious.
MR 00' Civic Si-T <U>#142 EM1 Crew</U> Spoolin Performance.com http://images.honda-tech.com/set1/smile/emthup.gif Fast-Turbo.com http://images.honda-tech.com/set1/smile/emthup.gif StreetRays.com http://images.honda-tech.com/set1/smile/emthup.gif |
#18 |
you could let it blow out the exhaust turbine...that's if you want to expletive the blades and ruin your turbo.
So the non-smartass answer is yes, you need to remove your turbo and make sure the manifold is clean of all metal shavings.
'08 R6 Raven - Just beginning to modify it... '97 LS-GSR/VTEC Turbo - Everything is a bolt on '92 Jeep Cherokee 4WD - Superchrgd twin turbo |
#19 |
and the answer is..... ????
92 Custom Black EG8 Stock Winter Beater 92 <FONT COLOR="red">Imola Red</FONT> EH2 on 15" Mugens B18B with a GT28R dyno tuned at 211WHP 187lbs @ 10psi 13.4 @ 106 street tires I'm am a JDM whore |
#20 | |
hook it up on the manifold, 2inches from the head on runner #3 or put it after your turbo. it's up to you and how exact you want the reading.
karmaloop code: YG9283 for 20% off | JDMSPEEDWORX 209.545.3200 automatically honda-tech's most hated member
#21 | |
or 2in from the head cylinder number 3.
http://www.honda-tech.com/zerothread?id=1932918 |
#22 |
about 2-3" from the head on the #3 cyl. #3 tends to run hottest, so it should be monitored closest. all other cyls should theoretically be cooler
hx coupe 2652lbs - lsvtec--318whp/241wtq 12.54@115.57 on bfg's 92 hatch---415whp/300wtq in '07 425whp/286wtq in '08 2410lbs 12.1@125.5 1bar boost @etown fall nats |
| Bookmarks |
| Tags |
| egt, honda |
