srs warning light
srs warning light
ok i have a 95 honda accord lx 4 door 2.2 . My problem is that my srs light wont shut off and if the reading is like the check engine light then my code for the srs is 52. what is the problem, what is the code mean and how can i fix it? please help its driving me nuts and cant find any info on this matter.
Location: home of Marciano/Haggler, city of champions, MA
well i dont know too much of how to turn it of, but i do know the srs has something to do with your steering wheel. mine stays on after i installed my snapoff steering wheel setup.
SRS is your Supplemental Restraint System, aka Airbags. I do not know what the code means. See here for a link on resetting the SRS light...
http://www.geocities.com/myintegra96/srs.html
I have noticed that the Honda SRS System is rather sensitive to voltage. The light in my 1997 Civic came on after jumping a bad battery a couple of times. A dealer wanted way too much money to fix it, and wouldn't even gaurantee it would fix it. I reset it and it hasn't come back on in 3 years. My 1996 Ody will go on if I start the car with too many accessories on, like A/C all the way up, light on, etc...I have reset it a dozen or so times in the last few years. I figure that if their was really something wrong with the Airbag system the light would come right back on after reseting it.
check fuse. check wires to make sure there is no loose wires connecting to the airbags. becareful though. i wont take any responsibility for anyone hurting themselves. airbags are dangerous and should be looked at by a professional, if you feel you fall in this catagory good luck.
Re: srs warning light (dansaleen_04)
You have probably fixed the problem by now - I am looking at an Accord to buy, and it has the SRS light on - I looked these up at another site. Just about everything here except a 52, so it's a mystery.
Diagnostic Trouble Code (DTC) Chart
1-1 Open in driver's airbag inflator
1-2 Incrase resistance in driver's airbag inflator
1-3 Short to another wire in the driver's airbag inflator or decrease resistance
1-3 Short to power in the driver's airbag inflator
1-5 Short to ground in the driver's airbag inflator
2-1 Open in passenger's airbag inflator
2-2 Incrase resistance in passenger's airbag inflator
2-3 Short to another wire in the passenger's airbag inflator or decrease resistance
2-3 Short to power in the passenger's airbag inflator
2-5 Short to ground in the passenger's airbag inflator
5-1, 5-4, 5-5, 6-1, 6-2, 6-3, 6-4, 7-1, 7-2, 7-3, 8-1, 8-2 Internal failure of the SRS unit
8-6 Internal failure of the SRS unit or two failures at a time
9-1 Internal failure of the SRS unit
9-2 Faulty SRS power supply (VB line)
10-1 SRS airbags deployed (SRS unit must be replaced)
slowcivic888
12-15-2004 06:32 AM
