> Honda Accord (1990 - 2002)
Old 09-20-2006, 07:20 PM   #51
pg_mark_sotto
pg_mark_sotto's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (sinister2c)
sick!!!!!!!
[IMG][/IMG]
pg_mark_sotto is offline Report Post   Reply With Quote
Old 09-20-2006, 07:20 PM   #52
pg_mark_sotto
sick!!!!!!!
[IMG][/IMG]
Old 04-25-2007, 03:35 PM   #53
MestizoRacer310
MestizoRacer310's Avatar
Send a message via AIM to MestizoRacer310
OK, so would I run into any problems if I put them w/ the bleeder screws on top so I don't have to remove the calipers from the spindle every time I'd need to bleed/flush the system?
Also to reiterate...calipers in question are from ANY 93 and up COUPE and 94-95 GS (coupe AND sedan)?
Kevin; AIM: MestizoRacer310
UA5: Tein|Rota|Racingbrake|Cusco|Eibach||CG6: H&R|TYC
Vouches: Crashtest Sonny, SiPower99, Blackstar, blackdc5
MestizoRacer310 is offline Report Post   Reply With Quote
Old 04-27-2007, 09:43 AM   #54
MestizoRacer310
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (TouringAccord)
Originally Posted by TouringAccord
...I've only heard of people flipping the right caliper to the left side and left to right to get the bleeder screw on top. But then I always wondered if that hurt any performance of the caliper, since you would now be using it in reverse of how it was intended to be used on the Legend. You would now be contacting with the bigger piston first instead of the smaller one or visa-versa, can't remember which piston is first when mounted correctly in a Legend.
Autozone just called me to tell me my legend 2piston calipers have been delivered. I'm going to do this next week in school. I need to know for sure which is the best way to mount them....flipped around so the bleeder's on top OR correct side but bleed them off the car...????
Also what brake pads are good for street use/light canyon runs....and if I should get stainless steel braided brake lines while I've got the system opened...
Hell, I'll just probably upgrade the lines in two weeks...and re-bleed. HAHA I need the hours at school.
Old 04-27-2007, 11:41 AM   #55
dvp95
Hey which ones did you buy from autozone and how much were they? I was thinking of buying them since its so hard to find at a junkyard.
dvp95 is offline Report Post   Reply With Quote
Old 04-27-2007, 11:13 PM   #56
DCFIVER
DCFIVER's Avatar
using the legend calipers is not the best option
http://www.cb7tuner.com/vbb/showthread.php?t=836
You're better off going with Prelude VTEC calipers. They also use 11" rotors. Also if you do not increase the size of the MC's pistons you will not be utilizing the full benefit of this upgrade.
FS: BNIB MFactory 5.2 FD $675
H22 cylinder head w/ bent valves-$150 obo
P72 w/ H22 basemap by Inlinefour $175 obo
DCFIVER is offline Report Post   Reply With Quote
Old 05-01-2007, 11:22 AM   #57
MestizoRacer310
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (cb7-R)
Getting the MC is part of my plan. I went to a parts place and looked at the MC of my accord and the MC of a '95 legend GS side by side. The bolt pattern matched to bolt the MC to the brake booster and the lines that go to the calipers are correct. I did notice that the way the reservoir would sit looks crooked. Is there, or would that be cause for concern? If the cap's on correctly I really don't think it would matter, it would just take a tad more time making sure it's at the correct level, but it could also mess with the brake light (for when the level is too low...)
Any thoughts on that?
Old 05-01-2007, 12:59 PM   #58
Bruce Banner
Bruce Banner's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (HONCORD)
looks gewd
Bruce Banner is offline Report Post   Reply With Quote
Old 05-01-2007, 04:12 PM   #59
BoostedH23Accord
BoostedH23Accord's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (Bruce Banner)
Maybe I missed it but what was the cost of this upgrade.
H23/F22B Hybrid Accord Member 001
http://www.honda-tech.com/zero...ge=22
BoostedH23Accord is offline Report Post   Reply With Quote
Old 05-01-2007, 05:37 PM   #60
MestizoRacer310
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (BoostedH23Accord)
I paid approx. $110 each (reman. w/ pads each side) $220 plus CA tax at Autozone
Then I'm looking at about $150 at ASC (downtown los angeles) for a 1" master cylinder then another $100 to $160 for stainless steel braided brake lines. Debating what brand to get. There's Earl's for 100, then there's Goodridge for $163.99 then Russel's for 169.99.
I know the benefits of going w/ stainless braided lines but don't know what the differences are between brands....???
Old 05-01-2007, 09:57 PM   #61
DCFIVER
DCFIVER's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (MestizoRacer310)
Yes but you have to remember that as you increase the size of the pistons you will also need to increase the force needed to assist in pushing those pistons out. By which i mean you will also need a larger booster. Also the required push rod length is not the same between the two masters another reason you will need a bigger booster. One of the reasons the GS's stopping power is so great is the amount force clamping down on the rotors even when you barely tap the brakes. In order to achieve this same force you would have to slam on your brakes with your stock set up.
Old 02-14-2008, 09:35 AM   #62
NoSmoking
NoSmoking's Avatar
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (momstaxi)
I found this over in the prelude forum:
"After reading that first thread, I am lead to believe that installing the Legend calipers will lead to a decrease in lower stopping force:
Quote, originally posted by Kotetu »
Here's an example, with 600PSI exerted through the BMC:
P=600 psi
cF=.33
Rotors:
D1=11inches
D2=10.5inches
Force on rotor = (Pressure*piston Area) * (brakepad Coefficient of Friction) * (2 pads)
Braking torque = fR * (radius-1)/12inches per foot
Stopping force (on tire) = bT / ((wheel radius)/12inches per foot)
Force on Rotors (pounds):
fR1=(600*3.976)*(.33)*(2)=1574.5 //front brake with stock (prelude VTEC) caliper
fR1a=(600*3.905)*(.33)*(2)=1546.38 //front brake with twin piston caliper
fR2=(600*1.4)*(.33)*(2)=554.4 //rear brake
Braking Torque (foot-pounds):
bT1 = 1574.5 * (11/2-1)/12=590.5 //front brake with stock caliper
bT1a = 1546.38 * (11/2-1)/12=579.8925 //front brake with twin piston caliper
bT2 = 554.4 * (10.5/2-1)/12=196 //rear brake
Stopping Force (pounds):
sF1=590.5/((20/2)/12)=708.5 //front brake with stock caliper
sF1a=579.8925 / ((20/2)/12) = 695.871 //front brake with twin piston caliper
sF2=196/((20/2)/12)=235.6 //rear brake
So the Legend/NSX brakes are actually a downgrade???"
In view of this the only advantage I can see to the GS 2 pot is that it spreads the force over the pad more efficiently and makes the pad "address" the rotor more effectively, making the real difference in brake torque impossible to predict with simple math. Need to compare two identical vehicles with both setups. NosmoKing
NoSmoking is offline Report Post   Reply With Quote
Old 02-25-2008, 08:12 PM   #63
NoSmoking
NoSmoking's Avatar
I just put prelude vtec calipers and rotors on my accord. Hard to imagine any stock setup would perform better
Old 02-27-2008, 02:23 PM   #64
jmk2888
Default Re: 95 Accord Legend 2 Piston Brake Upgrade (cb7-R..no more)
I have a 1994 Accord EX Automatic, which year Prelude Vtec rotors should I buy ? Do I need larger rotors or would my stock be fine ?
Modified by jmk2888 at 10:36 PM 2/27/2008
jmk2888 is offline Report Post   Reply With Quote
Old 02-28-2008, 10:45 PM   #65
JuNkDoGAccOrD
JuNkDoGAccOrD's Avatar
Send a message via AIM to JuNkDoGAccOrD
Default Re: (NoSmoking)
for the lude vtec calipers what caliper brackets did you use ?
JuNkDoGAccOrD is offline Report Post   Reply With Quote
Old 03-01-2008, 12:17 PM   #66
NoSmoking
NoSmoking's Avatar
23T
Old 03-01-2008, 12:19 PM   #67
NoSmoking
NoSmoking's Avatar
You have to do a rotor over hub conversion to use Vtec rotors.
Old 03-04-2008, 03:33 PM   #68
JuNkDoGAccOrD
so does the brake booster from the legend bolt up in the CD location ?????
did you upgrade your Master cylinder ???
Old 03-04-2008, 05:00 PM   #69
NoSmoking
NoSmoking's Avatar
Have an EX Near as I can tell has the same MC as prelude. LOL looked for Legend calipers for a month and ended up buying two sets, accidently, on the same day. Tried to cancel one because the other was cheaper and was sent already.
Old 03-05-2008, 03:25 PM   #70
Cannon Slirpa
Cannon Slirpa's Avatar
Send a message via AIM to Cannon Slirpa
nice job
Cannon Slirpa is offline Report Post   Reply With Quote
Old 09-22-2009, 07:48 PM   #71
2mchbst
2mchbst's Avatar
P=600 psi
cF=.33
Rotors:
D1=11inches
D2=10.5inches
whats thd difference in a 94 accord ex caliper and a 93-01 prelude vtec caliper? and is the prelude caliper worth swapping for better stoping?
2mchbst is offline Report Post   Reply With Quote
Old 09-22-2009, 07:56 PM   #72
bseriescrxsi
1995 Dodge Neon
My Garage
bseriescrxsi's Avatar
Send a message via AIM to bseriescrxsi
Originally Posted by gianinline View Post
so, what would be the special tool for this job?
pepboys sellss a nice little slide hammer kit that i believe comes with a similar part to that
-the search button exists and is in RED for a reason
-if you have a swap question, what kinda car did you put it IN
-its VTEC not VTECH
-its a CHECK ENGINE LIGHT not "the yellow light" aka a CEL
bseriescrxsi is offline Report Post   Reply With Quote
Bookmarks
2003, 94, 95, accord, brake, caliper, calipers, dual, honda, hondatech, legend, piston, swap, upgrade, upgrades
