***How-To*** Check & Clean Your Front ABS Wheel Sensor
Old 04-06-2006, 07:40 AM
wildoutwhitegsr's Avatar
Default ***How-To*** Check & Clean Your Front ABS Wheel Sensor
If you have a abs light on consistantly and you check the code and it says front wheel sensor, it may not be damaged, but just need to be cleaned. So to check if yours in dirty follow this article and it may solve your problem.
Tools Required:
Rachet
10mm
Short Extention
Jack
Jack Stands
Wheel Lock
Rag or Paper Towels
1) First start by removing the front wheel for either passenger or driver side depending on which one you start with. Make sure to support your car on jack stands and not just the jack.
2) Next turn the steering wheel all the way in, opposite the side your working on. For example if your working on the passenger side, turn the wheel all the way towards the drivers side.
3) Locate the abs wheel sensor which is directly mounted onto the knuckle and then remove the two 10mm bolts that hold the abs sensor directly. Then along the line theres another two 10mm bolts, that need to be removed, just follow the abs sensor line to get at them. Three of the four bolts are pictured below.
Here's what I had to deal with.
Driver Side
Passenger Side
4) Now take your rag or paper towels and start wiping off all the dirt and/or grease.
After Cleaning
Follow steps 3 - 1 backwards for re-installation.
Good Luck
Old 04-06-2006, 08:29 AM
Guess whos bizzack
It's*BOLO!!'s Avatar
Default Re: ***How-To*** Check & Clean Your Front ABS Wheel Sensor (wildoutwhitegsr)
holy crap those were dirty before, thanks for the pics!!!
Old 04-06-2006, 08:30 AM
BLacK FirE's Avatar
Default Re: ***How-To*** Check & Clean Your Front ABS Wheel Sensor (BOLO-FTW!!)
Nice thread, I think I'm going to have to do this.
Old 04-06-2006, 08:31 AM
Lan
Lan's Avatar
Great write up man Thanks!
Old 04-06-2006, 09:04 AM
Uncle Willie's Avatar
Great write up idea. I def need to do this on both my vehicles. THANKS.
Old 04-06-2006, 09:09 AM
Hype-R Stalker
CleanLikeJdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildoutwhitegsr &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Oh come on, real men don't wear latex gloves
Nice write-up though.
bolo, I have a pretty funny pic you should see haha.
Old 04-06-2006, 09:16 AM
TRE_'s Avatar
Default Re: ***How-To*** Check & Clean Your Front ABS Wheel Sensor (FlatBlackTeg)
damn! those were pretty gunked up, probably never been cleaned. nice write-up man
Old 04-06-2006, 09:22 AM
RaceMyGhost's Avatar
Default Re: ***How-To*** Check & Clean Your Front ABS Wheel Sensor (TRE_)
sweet write up man! i would def. take advantage of this write up but i dont have ABS
Old 04-06-2006, 09:31 PM
Hahaha, the gloves stay.
What pic is that?
Thanks guys
Old 04-06-2006, 09:58 PM
iH8RICERZ's Avatar
Default Re: (wildoutwhitegsr)
nice..i've had an abs code saying its my passenger side speed wheel sensor or something. i've always asked people to help me out but usually everyone only knows how to rip out the abs. This is the perfect write up I was looking for. I'll try it out tomorrow evening if I dont end up goin out and drink
Old 04-06-2006, 11:14 PM
bg-33p's Avatar
Default Re: (iH8RICERZ)
bookmarked! nice write-up
Old 04-07-2006, 06:50 AM
95integraSE's Avatar
thanks man, my light has been on forever and I wasnt sure if i has going to be forced to buy a new one or not. now i will be able to check today thanks man
Old 04-07-2006, 07:08 AM
DC2 Mang's Avatar
wildoutwhitegsr is the best person for writing up how-to posts
I enjoy reading all of them, keep up the good work
Old 04-07-2006, 08:04 AM
gsrjrsc's Avatar
hey guys i have a 94 ls and I also have the abs light on. I now when i start my car up you can hear the abs under the hood make noise like its pumping up or something to that affect. After 30ish seconds everytime it quits that noise and posts a abs light. Is that noise normal and could doing this DIY maybe rectify this issue of that noise if its not normal
Old 04-07-2006, 08:08 AM
DC2 Mang's Avatar
Default Re: (gsrjrsc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrjrsc &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i have a 94 ls and I also have the abs light on. I now when i start my car up you can hear the abs under the hood make noise like its pumping up or something to that affect. After 30ish seconds everytime it quits that noise and posts a abs light. Is that noise normal and could doing this DIY maybe rectify this issue of that noise if its not normal</TD></TR></TABLE>
The abs is doing its own self check when it does this, the sensors are probably what is causing the ABS light to come on
I think cleaning them would be a good idea anyways, im about to clean mine when the rain stops
Old 04-07-2006, 08:11 AM
gsrjrsc's Avatar
thanks for the input much appreciated!
Old 04-07-2006, 06:26 PM
00integrals's Avatar
Awesome man! I'm gonna try to do this tomorrow . . .
Old 04-07-2006, 06:40 PM
.water's Avatar
wow..i never heard about this.. this should be on sticky
Old 04-07-2006, 11:59 PM
DC4Marco's Avatar
is it the same for the rear?
Old 04-23-2006, 07:27 PM
Jcards26's Avatar
nice post, have the same problem right now with my front right sensor. im gonna def try this tomorow
Old 05-05-2006, 07:09 PM
indtegra's Avatar
Hey,
I think this will really be helpful to me as I am seeing the ABS light ON my instrument panel. However, I am not able to see the pics attached. Could you send me the pics.
Thanks in advance.
Old 05-05-2006, 10:12 PM
Here's the link for the album
http://smg.photobucket.com/alb...ensor/
Old 05-06-2006, 09:30 AM
S2KILLA's Avatar
Location: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (neo_)
thanx man i have to do that as well, good post
Old 05-06-2006, 10:51 AM
.likes trains
.one lane's Avatar
Nice! My abs light has been coming on recently. I need to do a test to see if it is my sensor (i hope it is). Someone rehost the pictures!
Old 05-06-2006, 04:27 PM
CNSK's Avatar
Default Re: (.one lane)
host the pictures please...thx
Quick Reply: ***How-To*** Check & Clean Your Front ABS Wheel Sensor
