| Thread Tools | Search this Thread |
#47176 | |||||
#47177 |
#47178 |
DIALED!
i love that color... that and the white... mine's shitty rattle can black for now but i've only had it for a couple days hopefully painting next weekend? idk
#47179 |
are those stark rims?
MY 4 door Civic DXhttp://www.honda-tech.com/showthread...4#post37629224 HOW to install EF DOOR SILLS!http://www.honda-tech.com/showthread.php?t=2518823 EFSedanSquad#220 |
#47180 |
EF Sedan Squad SUPERSTAR #84 >>>> MY EF2 BUILD Check out my work @ www.mishafrolov.com |
#47181 |
I got my alarm installed today.. whoever did it last did a shitty job..
EFSS #159 Sold: 1991 Honda civic Sedan LX Crashed: 1989 Honda Civic Sedan LX Daily Beat:1990 Honda civic Sedan EX http://www.honda-tech.com/showthread.php?t=2673610 |
#47182 |
yup clean bro!!! keep doing what u doing... u doing good!!!!
#47183 |
Yeah, and a few other things. I didn't like the chrome with the new paint job. I was thinking about painting the section around the windshield soon, seems you can't remove it to replace it without removing the windshield.
Isn't the answer 42?
My 4wd EF 4 door |
#47184 |
Sooooo glad to be back home! Time to get back to working on the sedan, Look for updates soon, with pics!!!
Check out the pics of my EF sedan, civic, and my crx @ www.myspace.com/greenzcmachine |
#47185 |
#47186 |
You should not have any problems but there is variables.Like tire size,and how low the car is..You run a lower profile tire you should not have any problems 32 is not a very low offset...At worst you will have to roll the fenders which is super easy to do.
#47187 |
this sounds noobish, but the combustion chamber is in the block right?
EFSS Member #221 |
#47188 |
#47189 |
nice gotcha...may have a problem with my water pump. broke off a bolt for the water pump so its not exactly as tight as it can be, thus allowing air to be sucked in thru the pump...causing weird shit to happen.
EFSS Member #221 |
#47190 |
ouch. i hate broken bolts... and the water pump isn't exactly in a convenient location
#47191 |
finally back from the field i love all the pics of the cars....cant wait to start fixing my car up
#47192 |
No but out of all the honda I have had only one didnt end up with a broken bolt at the pump. I have always used the rtv sealent dabbed it around the outside of the seal then run your finger across to make an even layer and bolt it back up. I would wait 12 to 24 hours to run it but I have also done it imediatily and never had an issue. But that is if you can remove the bolt that works just fine
#47193 | |
32 offset is still reasonably high, i don't think you'll have much drama. It could come down to the wheel's spoke design. If worse comes to worse, you could always run spacers.
My 4wd EF 4 door |
#47194 |
dude that suck! i have that same issue, its especially happends when i get off the freeway! i was told, my block guard cause my b18c1 to overheat lack of cooling, which caused my head gasket to blow, coolant leak thur the coolant over flow reservior . my nephew ej had blow gasket and warped melted piston!
94 EJ coupe EX a/c, p/s 91 ED sedan LX a/c, p/s imo imports fixed up during 89-99 were dope because you made your own parts or had them imported, not many cheap bootleg parts. |
#47195 |
dirty car
had a hour of sun today... then it was back to rain ![]()
#47196 |
Mitsu, I think I saw you today. Lawrence expressway around midnight?
»EҒSedanSquad#²²³ »96 hatch sold, 88 sedan sold, 87 sedan sold, 89 crx si sold |
#47197 |
I saw my old sedan yesterday at a meet. Was interesting too see. It was almost the same as I had sold it except for the engine swap and the wheels.
Sadly I broke my AW11 that night on some twisty back roads and had too pay an arm and a leg just too have it towed into town. I gotta go pick it up today its about an hour away with a broken steering rack.
If it were any slower, it would be a Ferrari... '86 MR2/'91 MR2 Turbo |
#47198 | |
thank you and thank you |
#47199 | |
yup must've been me. i was going home from quicklys last night. i primered the rest of my car black [quote=bradpee no the wheels i want are 15x7 which have a 40 offset and 15x7.5 which have a 32 offset, and i want to know if i can run the 15x7.5 with 32 offset without any problems? You should not have any problems but there is variables.Like tire size,and how low the car is..You run a lower profile tire you should not have any problems 32 is not a very low offset...At worst you will have to roll the fenders which is super easy to do.[/QUOTE] 32 offset is not lowoffset. you can run 25 without any problem. it doesnt matter how wide your rim is, it matters about the offset. of course depending on the tires, youd be able to make clearance. Im running 15x7 +10 offset, doesnt bother me at all. +10 front +10 rear with 5mm spacer=+5 offset with camber kit maxxeddd Well, im running negative camber. if you dont want to camber your wheels, dont run lowoffset wheels. in reality its like this. You either go low and slow, or fast and not low at all. so you sacrifce handling once you go slammed, and ride quality. lowest profile you can run on 15 inch rim is 45 series, thinnest tire you can run on this wall height is 195 195-45-15 lowest profile for a 16 inch is 40 series, pretty sure 205 205-40-16
#47200 |
hand polished or new barrel?
i'd polish the whole wheel, the white makes the wheel look smaller for some reason, if it were one color the wheel would look bigger cause the whiteface wont cut out the barrel
| Bookmarks |
| Tags |
| 1990, civic, decals, ef, fuel, honda, hondatech, install, love, middle, pipe, pump, sedan, slammed, squad, thread |
