> Drag Racing
Old 02-28-2006, 07:43 PM   #51
Bserious
Bserious's Avatar
Send a message via AIM to Bserious
Default Re: (Missing Gears)
270+ , and there is definitly more in what you have.
Originally Posted by Missing Gears
post up, i wouldnt mind seeing some other good setups.
everyones always so top secret, hush hush. i don't see what the big deal is. sure anyone can copy a setup, but it still has to be assembled and tunned and paid for.
im not the first to do this setup and i surely wont be the last, so i have no prob. sharing w/ everyone.
Here was one of ours for comparison.
87x95mm
http://www.quartersportsdrag.com/H_Dynos/Zac.jpg
With this setup the long block was all Honda. No port work, no cams, no pistons, just am aftermarket intake manny, 70mm TB, race header, and a longer stroke.
Modified by Bserious at 6:39 PM 3/5/2006
QSD 9167921549
BDHK... all just numbers.
Bserious is offline Report Post   Reply With Quote
Old 02-28-2006, 09:51 PM   #52
H25
H25's Avatar
Default Re: (fmfkid250)
Belive it or not 300whp is alot harder to attain the people think. Well not that hard just more money if you got the know how..
let me find something and I will email it to you skunked. thanks!
92 civic 11.41@121mph. H series all motor street car (April 2003)
95 integra GSR Turbo. 10.2@142mph (Nov 2001)
H25 is offline Report Post   Reply With Quote
Old 02-28-2006, 10:23 PM   #53
BlownHatch
BlownHatch's Avatar
Default Re: (MHRacing-310)
great numbers randy! i look foward to seing you guys out this season
I have a trans , if u think u might need one call me.
www.nrgtechracing.com atc race supply
rated r performance
9.91@152mph stock trans. suck
BlownHatch is offline Report Post   Reply With Quote
Old 03-01-2006, 10:12 AM   #54
SikITR01-248
SikITR01-248's Avatar
Great numbers bro, car is a beast . I was at the shop when it was on the dyno and she was SOOO LOOUD . Look forward to seeing you run this year at Crapital or MIR. 11.20s all day long
SikITR01-248 is offline Report Post   Reply With Quote
Old 03-01-2006, 04:40 PM   #55
Missing Gears
Missing Gears's Avatar
Default Re: (SikITR01-248)
found a little time today to mess w/ the car. drained the oil from the dyno runs, no milk anywhere to be found, but oil was a little off color and smelled a little like fuel.
no milk in filter either, no metal anywhere to be found. everything looked very clean
btw, during assembly i set the ring gaps fairly loose: 21 top, 24 2nd, 18 rails, i didnt know if the motor would like unleaded w/14:1. i figured better to be safe than sorry.
for crankcase venting im using the stock nipple on the back corner of the valve cover going to a can. also blocked off hole for pcv valve and added another nipple in its place on the back of the cover going to check valve after collector in exhaust.
how did i get here http://is.rely.net/1-92-30008-l-au16...EFX98SjN8A.gif
Missing Gears is offline Report Post   Reply With Quote
Old 03-01-2006, 05:16 PM   #56
vtecmissle
vtecmissle's Avatar
Why not have the head pressure tested and magnafluxed. THen you will know for sure where the problem is.
vtecmissle is offline Report Post   Reply With Quote
Old 03-01-2006, 05:33 PM   #57
Missing Gears
Default Re: (vtecmissle)
i should have press. tested the head after last season, but i was sure the leak was in the block. that block came from a salvage yard and had a small external leak on the front of it, basicaly water was seeping through the alum. i just thought it had been stressed when the car was wrecked.
the new block is out of my old prelude so i know its good. when i pull the head i plan on press. testing it to make sure its the problem. i was also thinking of maging it, but dont think you would be able to see into all the oil galleys.
Old 03-01-2006, 10:23 PM   #58
precisionelite
precisionelite's Avatar
Send a message via AIM to precisionelite
You make me forget about the K series.
2001 Prelude 197/152
1.956 60' (M&H 23x8.5x15)
13.997@98.27 MPH
Tempest Tuned http://www.tempestracing.net
precisionelite is offline Report Post   Reply With Quote
Old 03-02-2006, 10:27 AM   #59
mgags7
mgags7's Avatar
Send a message via AIM to mgags7
Default Re: (precisionelite)
long live the H
not enough people make big investments in H motors and post them up on h-t, there are plenty of expensive K's being posted up all the time by the edo guys and random others though....nobody sees that H motors can do the same kinda stuff with money spent in the right places
Matt
mgags7 is offline Report Post   Reply With Quote
Old 03-02-2006, 12:20 PM   #60
Missing Gears
Default Re: (mgags7)
Thanks everyone. And special thanks to everyone who has helped w/ the car:
Joe and Fred @ tempest racing, always taking care of the tunning.
Kenny and Bruce @ woolford bros. chassis fab., helping w/ all the fabrication/ welding and finding time at the last minute to give a hand.
And most of all, IMPORT SPORTS, w/o the shop i wouldnt have anywhere to build and maintain the car or find parts at such reasonable prices . a big to Steve and everyone else @ Import Sports.
Thanks guys, couldnt have done it w/o you
Old 03-02-2006, 02:35 PM   #61
H25
H25's Avatar
time the car and let us know how you do
Old 03-02-2006, 04:12 PM   #62
MADPROPS
MADPROPS's Avatar
hopefully the weather will hold up for this Sunday At Captial I will be there with Steve and Randy, I will try to video tape the runs and posts them on here.
[url]www.perceptivepromoting.com
www.importsportsonline.com
MADPROPS is offline Report Post   Reply With Quote
Old 03-05-2006, 01:57 PM   #63
FCobra94
FCobra94's Avatar
Default Re: (MADPROPS)
I'm looking forward to hearing the results as well!
2003 Honda Civic Si
1994 Ford Mustang Cobra
FCobra94 is offline Report Post   Reply With Quote
Old 03-05-2006, 02:50 PM   #64
Missing Gears
Default Re: (FCobra94)
went to the track today for testing. made 2 passes and decided to call it a day, things didnt go that well. air temp. was in the low 50s, and there was a decent head wind. running on m/h 23x8x13. here are the results:
1st pass: 11 psi
60'....1.703
330'..5.075
1/8...7.712 @94.25
1000'9.977
1/4...11.883 @119.32
2nd pass: 10 psi
60'....1.671
330'..4.993
1/8...7.606 @95.39
1000'9.853
1/4...11.752 @119.56
good news is the trans seems to be shifting great, although i was grannying it a little. bad news is the car is doing the exact same thing it did last season, as soon as i get into 2nd gear it throws me back in the seat and then seems to fall out of vtec and break up for a split second, then it comes alive, throws me back in the seat again and it tears down the track. i can tell the car is def. faster than last season, from the top of 2nd on it pulls VERY hard. i leave the line @ 6k and it spinns through the top of 1st (pretty sure i will need larger slicks) i was wondering if the rpms were dropping low enough between 1st and 2nd to cause it to fall out of vtec, but vtec engages @ 5k and im sure the rpms dont drop that low. its hard to keep an eye on everything all at once, especially during 1-2 shift. im thinking about mounting a cam. in the car and making another pass next weekend.
as far as the water leak, the oil cap got creamy during the first pass and after the second pass the dipstick barely showed any signs of milk. the oil still smells like fuel. im wondering if theres any way the milky oil in the head could be caused by blow by? anyone ever heard of that happening before?
i will probably make a pass next weekend w/ a cam. to double check rpm, but even if the rpms were dropping that low it shouldnt break up. it should just fall out and then come back in again. it feels like it falls out, breaks up, and then comes back in. the motor is tunned to be in vtec above 5k, so if for some reason it falls out at 6k it would probably load up and break up like its doing. the weird thing is it only does it in 2nd gear every pass. hopefully i can figure this out because its starting to piss me off, but hey at least the trans. shifts
Old 03-05-2006, 03:04 PM   #65
RaceProfessor
RaceProfessor's Avatar
I'll take the 23's off your hands if you wanna sell.
Sam Wu
RaceProfessor is offline Report Post   Reply With Quote
Old 03-05-2006, 03:20 PM   #66
Missing Gears
Default Re: (RaceProfessor)
not sure yet, i want to get everything running right before i buy anymore parts. thanks though.
Old 03-05-2006, 03:33 PM   #67
skunked
skunked's Avatar
Send a message via AIM to skunked
aren't you running a H23 tranny? 4.2 FD?
2.2L H2B NA DC2 S/P 12.1@110
SINISTER RACING
skunked is offline Report Post   Reply With Quote
Old 03-05-2006, 03:45 PM   #68
Missing Gears
Default Re: (skunked)
went back to h22 trans this season due to the h23 trans being damaged.
Old 03-05-2006, 04:12 PM   #69
MADPROPS
MADPROPS's Avatar
Randy car looked good I think once you get back into the swings of things you will be surprised, the first two runs will not be the record seting passes
Old 03-05-2006, 05:05 PM   #70
Missing Gears
thanks, i guess i will definately mount a video cam in the car and make sure the rpms arent dropping below 5k during 1-2 shift. that way i can also whatch what the wideband reads at that point.
if that is not the cause, then i will pull the head and pressure test it. hopefully finding a leak.
seems like i can never have any normal problems like everyone else. i always have the goofy, never seen or heard of before problems. im starting to think my car has a poltergeist.
Old 03-05-2006, 06:36 PM   #71
H25
H25's Avatar
Everyone has problems... No matter what it seems.. Some people have it more together then others making it seem like they dont have any problems..
My advise would be to rev the motor higher in 1st. overshoot your powerband by about 1,000 rpm that way when you go into 2nd you wont bog down. After that keep doing what your doing. Or you might want to try a smaller diameter slick and go wider to keep traction.. have you tried 22x9x13? When you play around with tire sizes you change your gear ratio's alot. best of luck.
Old 03-05-2006, 06:59 PM   #72
allmotorhatch
allmotorhatch's Avatar
On the 11.75 pass you went 95.3 in the 1/8, I remember you went 11.6x before what was your 1/8 mph on that pass?
On Point Paintball
856-468-6774
All Motor Street Car 11.67@118.58 sold
allmotorhatch is offline Report Post   Reply With Quote
Old 03-05-2006, 06:59 PM   #73
Missing Gears
thanks, i appreciate it. i wish you guys could hear what the car sounds like or see what it feels like. its definately not bogging at all. you can hear the pop where it goes out and back into vtec but in between it breaks up, hesitates almost like a misfire or det.
last season i kept an eye on the rpms while it was happening and they never went below 6k. it was hard to remember to watch everything today, i was trying to keep an eye on the wideband.
there will be a camera in the car next week, so maybee everyone will be able to see and hear.
i got rid of the 22x9s when i started making power. they wouldnt hook at all. im sure if anything i need to go to a 24.5x9. 23s are tall enough but they dont have 9" wide. im thinking if it hooks earlier in 1st it will build more momentum to go into 2nd. this is if the problem is in fact the rpms.
Old 03-05-2006, 07:01 PM   #74
Missing Gears
Default Re: (allmotorhatch)
thats what i was trying to find earlier, but i cant find any of my slips from last season.
Old 03-05-2006, 07:11 PM   #75
Dragline
Dragline's Avatar
you should get the S300 and start datalogging every run so you know whats going on and you'll have that thing figured out in no time.
Dragline is offline Report Post   Reply With Quote
Bookmarks
