> Suspension
Old 01-30-2006, 01:21 PM   #1
Sumslapper
1995 Acura Integra
Sumslapper's Avatar
Send a message via ICQ to Sumslapper Send a message via AIM to Sumslapper
Default breaking upper control arm ball joints?
Ok about 2 months ago my UCA was clicking and popping when i came to a quick stop or or turned the wheel quickly. I replaced it with a brand new (ebay) uca with ball joint and it went away. Now its back! I always hear talk about how camber kits are pretty useless as long as you get a rotation every few months and an alignment. Im dropped about 3 maybe 3.5 inches on 15's. So in my case, should i get a camber kit if im this low or do you think its because i went with a ebay uca and not oem that its busting? thanks
Rattle-bucket DC2
Originally Posted by rico91stang View Post
Has anyone really been far even as decided to use even go want to do look more like?
Sumslapper is offline Report Post   Reply With Quote
Old 01-30-2006, 02:01 PM   #2
Jonny Black
Jonny Black's Avatar
Send a message via AIM to Jonny Black
Default Re: breaking upper control arm ball joints? (sumslapper)
It could be alot of things. But more than likely its prolly cause you went cheap. Also for that much of drop, camber kits are highly advised.
This is a big misinformation. For one thing..usaully if a car is set to factory specs (so assuming your set at factory height for now) unless you get into an accident or hit a curb or somthing nasty like that, then there is no need to get an alignment but maybe once a year. or longer in some cases. Rotation is a great way to help equalize the stress your tires indures on a day to day basis, but will not prevent your tires wearing out due to an excessively lowered vehicle that isnt in an acceptable range of alignment.
If you mostly daily drive your car then -1 degree camber would be grand. at a 3.5 inch drop you should be way over that. Even having your toe set perfectly..you are gonna be wearing your tires improperly. I mention toe cause in actualality the toe is the real killer of tires. If to far off you can burn through tires very quickly.
so in other words...get a camber kit. and you can kill 2 birds with 1 stone by getting adjustable ball joints which can solve your balljoint issue and provide a simple way to fix your camber as well.
Hope this helps.
J
With all things being equal, a Crx has no equal.
Jonny Black is offline Report Post   Reply With Quote
Old 01-30-2006, 02:06 PM   #3
Sumslapper
1995 Acura Integra
Sumslapper's Avatar
Default Re: breaking upper control arm ball joints? (Jonny Black)
cool man thanks alot. appreciate it. i just heard a lot of horror stories from camber kits and i kinda stayed away from them.
Rattle-bucket DC2
Old 02-07-2006, 09:31 PM   #4
ahobbs
Formerly HybridcivicLS-T, moderator
ahobbs's Avatar
Send a message via AIM to ahobbs
mine works great and I'm down about 3 inches on 15's I can't get the back to go in anymore but they don't wear out. I have the toe set and I've been on the same set for 8months and they are in great shape. Also the ball joints are easily replaced with the aftermarket Camber kits well skunk2 it is. I have to change mine this weekend becuase of my stupidity.
stockGSR E85 415/275@18psi...TO BE CONTINUED
XBOX:fireahobbs
ahobbs is online now Report Post   Reply With Quote
Old 02-07-2006, 11:40 PM   #5
94eg!
94eg!'s Avatar
Default Re: breaking upper control arm ball joints? (HybridcivicLS-T)
Did you make sure to "load" the suspension before you tightened any of the bolts. If you didn't, it forces all your bushings to twist as you lower the car back on the ground. This will wear out any new bushings you install in a very short period of time.
Make sure to place a jack under the LCA, lift it until the car just barely raises off the nearest jack stand. Thats when you tighten & torque all your suspension bolts. Then your bushings will have no twist when the car is back on the ground...
Originally Posted by gabebauman
Screws are useless.
94eg! is offline Report Post   Reply With Quote
Old 02-09-2006, 06:36 PM   #6
Sumslapper
1995 Acura Integra
Sumslapper's Avatar
Default Re: breaking upper control arm ball joints? (94eg!)
thanks for the tip. I bet thats why it went so fast. will do on my next install
Rattle-bucket DC2
Old 02-10-2006, 08:36 AM   #7
94eg!
94eg!'s Avatar
Make sure to do this whenever you loosen a bolt that goes through the center of a rubber bushing (including engine mounts).
Screws are useless.
Bookmarks
ball, breaking, joints
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
