#1 | |||||
LSV 2.0 PART OUT. DARTON, PORTFLOW, RMF, RC, SKUNK, BUDDYCLUB SPEC IV, NGK, STR TB, HONDATA, B SERIES PARTS http://www.hondamarketplace.co...02023 |
#2 | |
Your Future STEP DAD!!!!
If NISMO stands for NISsan MOtorsport,what do they call HOnda MOtorsport MUNKY W3RKZ INC BISIMOTO ENGINEERING CAMP1320 |
#3 |
tuning is HUGE
#4 |
use the pro1s.
I would have used a little more compression but I'm weird that way. who did the P&P? if you have a good head and the motor is put together right you may have 240whp potential, alot depends on tuning as others have said.... |
#5 |
also will be running hondata s200. and hopefully will be tuned at churchs.
#6 |
how much compression do you think is possible on pump gas daily driven?
#7 |
12.5:1 with good tuning.
#8 | ||
#9 |
i'm trying to be around 12.5. If my pistons compesssion were to be 12.1. would a milled head bump the compression up a bit. Also WHAT SIZED INJECTORS TO USE? i'm looking at 370cc w/ a walhbro 255 fuel pump.
#10 | |
just take a little out of the box where it says "headgasket thickness" to show what you will get from milling the head.... |
#11 |
how do u know the dome size on a 12.1 comprssion piston?
#12 | |
the compression ratio they tell you is just an estimate, if you look at the actual piston spec sheet it doesn't say a compression ratio it says a dome volume. that is because even with the same piston, the compression ratio will change if you use a different head, or a different crank (LS vs GSR/ITR stroke).... |
#13 |
exactly thats what i was thinking also. do you see anything else i would need? what size injectors or anything else make my build stronger and reliable.
#14 |
I am bad with injector sizes, I'm sure someone else will chime in and let you know what you need.
Make sure the bottom end is assembled by a reputable builder and that you have the rotating assembly balanced..... |
#15 |
I would think the 370 would be good enough, but to be on the safe side with 12.5:1 I would go one step higher and just get 440's.
#16 |
anything else i could use for my build that would benefit it
#17 |
w/ 12.5-1 comprssion skunk2 pro1's would benefit mroe than pro 2's?
#18 | |
#19 |
yeah the pro2s are a really big cam, the pro1s would be better for a 12.5:1 motor...
#20 |
We hit 238 whp on my buddies motor this week.
skunk pro-1 11.1 2cc wiseco pistons .006 piston to deck .008 milled gsr head Ported head smsp header 85x89 68mm t-body Jg Ed intake mani Tbones magic hondasport intake tube.(lol) Crome pro
Coatings expert Project 300 .280 whp on RLz's dyno oh yeah!!! test passes netted 11.2 @ 124 ish, needs traction 11.78@114.9 Full street car(238whp then) http://www.Bristoldyno.com |
#21 |
440 injectors should work just fine you might be running alittle rich though
#22 | |
96 Toyota Tacoma 4x4
#23 |
#24 |
2000 Acura IntegraMy Garage |
im pretty sure i will hit 240whp on hookups dyno.....on 91 octane.
#25 | |
| Bookmarks |
| Tags |
| 111, cam, compression, gas, gear, lsv, pump |
