#51 | ||||||
http://www.photobrando.com Have a look... and order some prints Quote:
#52 |
Latest standings:
1997 up to vin JH4DC231XVS025863, still count 320 Type Rs 1998 up to vin JH4DC2312WS005737, count 1002.
The nipple is the only intuitive interface, everything else is learned. |
#53 | |
H-T Order of Merit
#54 | |
as in, modular arithmatic
2000 #0241 FBP |
#55 |
This is truely one of 2006's best and most informative threads. Thanks to Ken and andyt for the hard work. That rocks!
This does not count JDM/CDM/UKDM R's....right? |
#56 | |||
#57 |
Great thred!!! Good work guys.
00 M5 - nice days 06 CBR 1000 RR - weekends 99 Accord V6 coupe - daily/winter |
#58 | |
#59 | |
Wow, looks like most of the 1998 R's were produced early in the cycle correct? BTW could this program be run by anyone? Some of us could get started on 00 and 01.
http://www.campaignforliberty.org/ |
#60 | |
#61 |
EDIT:
Program has a bug! My bad, here is the corrected version. ---------- Let's see, to run the program you need: some sort of unix system, probably Linux a fairly recent perl the libwww libraries and perl packages the WWW:Mechanize library and its prerequisites an ownerlink username and password Also, you need a decent amount of RAM to run it for any length of time. I tried to clean up the memory leaks as much as possible, but I dont think they are all mine ![]() Well, here it is, if you want to run it... #!/usr/bin/perl use WWW::Mechanize; use HTTP::Response; my $username = 'PUT_USERNAME_HERE'; my $password = 'PUT_PASSWORD_HERE'; my $year = "2000"; # or 1998, 2000, 2001 my $sequence_start = 0; my $sequence_end = 40000; my $yearcode = ""; my $magic_number = 0; if ($year eq "1997") { $yearcode = "V"; $magic_number = 203; } elsif ($year eq "1998") { $yearcode = "W"; $magic_number = 212; } elsif ($year eq "2000") { $yearcode = "Y"; $magic_number = 230; } elsif ($year eq "2001") { $yearcode = "1"; $magic_number = 167; } my $mech = WWW::Mechanize->new(); my $response; my $n = ""; my $first = ""; my $second = ""; my $third = ""; my $fourth = ""; my $fifth = ""; my $sixth = ""; my $remainder = 0; my $vin = ""; my $url = ""; my $logname = $year . "integras.txt"; open LOG,">>$logname" or die "$!\n"; select LOG; $|=1; for ($x=$sequence_start; $x <= $sequence_end; $x++) { $n = sprintf("%06d", $x); $first = (substr $n, 0, 1) * 7; $second = (substr $n, 1, 1) * 6; $third = (substr $n, 2, 1) * 5; $fourth = (substr $n, 3, 1) * 4; $fifth = (substr $n, 4, 1) * 3; $sixth = (substr $n, 5, 1) * 2; my $sum = $magic_number + ($first + $second + $third + $fourth + $fifth + $sixth); $remainder = $sum % 11; $sum = undef; if ($remainder == 10) { $remainder = "X"; } $vin = "JH4DC231" . $remainder . $yearcode . "S" . $n; print LOG "$vin\n"; $url = 'http://www.ahm-ownerlink.com/login.asp'; $mech->get( $url ); $mech->submit_form( form_name => 'loginForm', fields => { user => $username, password => $password, } ); $url = 'http://www.ahm-ownerlink.com/prod_profile.asp?profile=force'; $mech->get( $url ); $mech->submit_form( form_number => 1, fields => { vin => "$vin", } ); $response = $mech->response(); if ($response->is_success) { my $output = $response->content; my @lines = split /\n/, $output; foreach $line (@lines) { if ($line =~ /Integra/) { print LOG "$line\n"; last; } } $output = undef; @lines = undef; } } Modified by andyt at 8:18 AM 1/17/2006
#62 |
And oh yeah,
97 im up to 29201, count 320 98 im up to 10051, count 1002 I'm going to 40,000 on each based on the link Ken provided. For 2000/2001 a smaller number will suffice.
#63 |
nice work andyt.
#64 | |
#65 | |
#66 | |
H-T Order of Merit
As I mentioned, I didn't really know, at the time that I first posted, whether they used one sequence (of last six digits) for all Integras, or had more than one sequence. I just realized that it's possible to find out how many different sequences were used for Integras. You see, there are exactly fifteen different formats for a VIN number for ANY Integra during the years when the ITR was sold: JH4DC231cySnnnnnn ITR hatch JH4DC239cySnnnnnn GS-R hatch with leather JH4DC238cySnnnnnn GS-R hatch without leather JH4DC446cySnnnnnn GS hatch automatic JH4DC436cySnnnnnn GS hatch manual JH4DC445cySnnnnnn LS hatch automatic JH4DC435cySnnnnnn LS hatch manual JH4DC444cySnnnnnn RS hatch automatic JH4DC434cySnnnnnn RS hatch manual JH4DB859cySnnnnnn GS-R sedan with leather JH4DB858cySnnnnnn GS-R sedan without leather JH4DB766cySnnnnnn GS sedan automatic JH4DB756cySnnnnnn GS sedan manual JH4DB765cySnnnnnn LS sedan automatic JH4DB755cySnnnnnn LS sedan manual I chose a very low value of nnnnnn and ran the check digit formula on it to see how many "hits" I got for a given year. The answer? Each year, there are four different sequences of VIN numbers for Integras - three-door hatches with automatic transmissions - three-door hatches with manual transmissions - four-door sedans with automatic transmissions - four-door sedans with manual transmissions Therefore, instead of going all the way up to, say, 040000 in a year in which 40,000 Integras were sold, we only need to go up to the number of three-door hatches with manual transmissions that were sold. I did some quick spot checking of VIN numbers (by trying out the six possible VIN numbers for manual three-doors at various values of nnnnnn) and found that the highest VIN number of three-door hatches with manual transmissions sold in each model year is as follows: 1997 - at least 013000 but less than 013500 1998 - at least 011500 but less than 012000 2000 - at least 008000 but less than 008500 2001 - at least 006500 but less than 007000 So there's no need to go any higher than the highest number here when checking for ITRs. Sorry I didn't think of this earlier. P.S. I only checked 1997 through 2001. It's possible that there were fewer than four sequences of Integra VIN numbers prior to the 1997 model year, before the ITR was sold. For example, NSXs had only one sequence of VIN numbers for the 1991-1996 model years; it was only beginning in 1997 that they created two sequences for NSXs, one for the automatics and the other for the manuals. Modified by nsxtasy at 9:16 AM 1/17/2006 |
#67 |
Then I guess we consider 97 finished with a final count of 320.
I will move on to 2000. 1998 is still running around the 11300 mark, I'll let it hit 12000 and then run 2001. Still at 1002 for 1998. Here are the 1998 ranges so far: 000002 - 000003 002024 - 002071 002091 - 002114 002178 - 002225 002310 - 002333 002358 - 002381 002383 - 002406 002411 - 002433 002494 - 002516 002518 - 002540 002608 - 002630 002674 - 002721 002746 - 002769 002801 - 002824 002861 - 002884 002912 - 002935 002972 - 002995 002998 - 003021 003051 - 003074 003106 - 003125 003185 - 003205 003230 - 003250 003283 - 003287 003343 - 003363 003395 - 003402 003425 - 003431 003450 - 003471 003503 - 003524 003556 - 003577 003606 - 003627 003683 - 003699 003735 - 003756 003822 - 003830 003849 - 003870 003906 - 003921 003976 - 003998 004018 - 004026 004067 - 004075 004105 - 004113 004158 - 004166 004215 - 004223 004272 - 004291 004326 - 004335 004349 - 004358 004386 - 004395 004450 - 004469 004523 - 004532 004549 - 004558 004584 - 004593 004614 - 004622 004639 - 004647 004681 - 004689 004726 - 004734 004777 - 004785 004817 - 004826
#68 |
Man this is great. Its like the holy grail of the ITR for owners in the US. Its weird how they were'nt better documented. I guess they didnt care since it wasnt an American car.
#69 | |
I'm sure someone will make the link or update to the ITRCA website... BBASSO??? Good work guys... -Shawn who's highly impressed with the skillz in this forum (community).
2000 PY #1261 -jrsc Sold 8/21/08 (3 years of fun) 1996 Honda Civic EX MR 5 sp and bone stock. My cause... obviously not an advertisement |
#70 |
Great work, this is the most intelligence laden thread Ive seen on here in a long time
97 ITR - Sold 01 ITR - Sold |
#71 | |
#72 | |
#73 | |
#74 |
Banned
super sweet
#75 |
I understand what you were saying. I meant the numbers hadn't been researched/discovered yet.
| Bookmarks |
| Tags |
| acura, code, honda, hondas, integra, itr, itrs, jh4dc, made, number, produced, sold, transmission, type, us, usa, year |
