Honda and Acura Appearance/Cosmetic Forums
> Honda / Acura
Old 12-15-2005, 06:24 PM   #1
Anthony
Mr. Fuch-yu
Anthony's Avatar
Send a message via AIM to Anthony
Default Metal Polishing How-to
The other day I did a search for "metal polish" to see what is most recommended. When the results came back, I found that mothers mag polish was the most common answer. I also found a few threads where people posted questions regarding how to go about polishing metal and they had little or no feedback. I then decided that I would do a write-up on it. I did not use anything that is not easily accessible for those of us with a limited income. This was done fairly cheap. I used a valve cover that I bought off of mike93eh. Great Seller. So here is my how-to.
Here is a list of the items you will need (I will explain each when I use them):
Sandpaper (240, 320, 400, 600, 800, 1000, 1200, 1500, 2000, 2500 grits)
Mothers Aluminum and Mag Polish
A 20oz. Pepsi Bottle
6 inch Lag bolts
Aircraft remover
2 Flapper wheels (1 coarse and 1 fine)
2 old white t-shirts
Elbow Grease
You can get all of this stuff from Wal-Mart, except for the sandpaper, you have to get it at a paint supply store.
First, If whatever you are polishing has any paint or clearcoat on it, I highly recommend this stuff. for mike93eh on recommending this to me.
You get it at Wal-Mart in the same section as the automotive touch up paint. Follow the instructions on the can, and your good to go.
Once I removed all of the paint I went over the area to be polished with 2 flapper wheels, 1 coarse and 1 fine. These go in a drill and can smooth out any gouges in the metal.
Next, you are going to start to wet-sand the area to be polished with the 240 grit sand paper. Alot of people say to use a spray bottle for wet sanding, but since we are doing this on the cheap, grab an empty pepsi bottle, poke a hole in the lid and use it for your sprayer.
The sanding will be much easier if you have the valve cover fastened down to keep it from moving. I used lag bolts and fastened it to the table.
The wet-sanding procedure is the same for all grit levels. Begin with 240 grit, and work your way up to 2500 grit. Use plenty of water, and move your hand in a circular motion. If you see an area that looks rougher than the rest, sand it down. Once you are finished using a particular grit, rinse the area and wipe it to remove the leftover dust from the metal. Here is a good example of what each grit level should look like once done.
240 grit
320 grit
400 grit
600 grit
800 grit
1000 grit
1200 grit
1500 grit
2000 grit
2000 grit is where the valve cover really is beginning to become smooth. Here is a pic at a different angle with the mothers polish on top of the valve cover. Notice the reflection.
2500 grit
Now that is basically what the valve cover should look like after each step. Now, on to the polishing.
This pic is to show you how smooth the valve cover is before polishing.
Now, to polish the valve cover I used Mothers Aluminum and Mag Polish (the stuff on top of the valve cover in the pic above) and a couple of old hanes t-shirts cut into small rags. T-shirts work well due to how soft they are.
Take a cloth and put a little bit of polish on it and apply it in a circular motion using slight pressure.
Do NOT use too much polish. If you use too much it will dry and be harder to buff off.
Continue with the circular motion until the polish turns black. Do not use the dirty cloth to apply polish to any other surface.
Then take a clean cloth and buff the spot until it shines. Continue this step until you reach a desired luster.
And here are a few pics of the finished area at different angles.
Notice the reflection of the stuff that is hanging on the wall in this pic.
In all actuality, this is a really easy thing to do, just time consuming. I hope that you guys can understand this write-up. If there is anything that I may have missed or that isn't clear enough, tell me. This is my first write-up, and I look forward to your comments.
-Red
Modified by nitrared at 1:06 AM 12/19/2005
97 Prelude SH - Stock
Originally Posted by ManBearPig4silly
What? *looks around and runs away*
Originally Posted by Anthony
Sigged to prove David is afraid of something.
You're a rat bastard Annathy.
Anthony is offline Report Post   Reply With Quote
Old 12-15-2005, 06:32 PM   #2
Mr.RHTuner
Mr.RHTuner's Avatar
Default Re: Metal Polishing How-to (nitrared)
dam man...much props
good thread
c.i.d
Collaborative Image Design
Mr.RHTuner is offline Report Post   Reply With Quote
Old 12-15-2005, 06:33 PM   #3
Triscuit
Triscuit's Avatar
Send a message via AIM to Triscuit
nice, but IMO crome dip the bitch
1 John 4:9
"This is how God showed his love among us. He sent his one and only Son into the world, that we might live through him"
11/08/2008
Triscuit is offline Report Post   Reply With Quote
Old 12-15-2005, 06:33 PM   #4
dFreezy
dFreezy's Avatar
nice write up. i've only used 1000 grit sandpaper, i can only imagine what 2500 is like. must be like rubbing with notebook paper
few h-t vouches
VT Hokie for life.
dFreezy is online now Report Post   Reply With Quote
Old 12-15-2005, 06:35 PM   #5
Anthony
Mr. Fuch-yu
Anthony's Avatar
Default Re: Metal Polishing How-to (dFreezy)
Nah. Notebook paper would be the next step. Thanks for the compliments.
-Red
Old 12-15-2005, 06:37 PM   #6
onekoop
onekoop's Avatar
Send a message via AIM to onekoop
will this work for polished lips too?
| TEAM5STAR.NET | DUMPEDSTARS #16 |
onekoop is offline Report Post   Reply With Quote
Old 12-15-2005, 06:38 PM   #7
Anthony
Mr. Fuch-yu
Anthony's Avatar
Default Re: (JDMpnOi)
I would imagine it would. We'll find out once spring gets here. My lips need refinishing.
-Red
Old 12-15-2005, 06:43 PM   #8
johnxboi
alotta hard work eh? prolyl alot easier cuz you were using a dremel or soemthign.
johnxboi is offline Report Post   Reply With Quote
Old 12-15-2005, 06:46 PM   #9
Anthony
Mr. Fuch-yu
Anthony's Avatar
Default Re: (johnxboi)
No dremel here. I have one, but I did this from start to finish by hand to show everyone that they don't need expensive tools to do this stuff.
-Red
Old 12-15-2005, 06:49 PM   #10
EG2Driver
EG2Driver's Avatar
Send a message via AIM to EG2Driver
how much did the paint stripper run ya? Its like 68 bucks for a gallon here in this shithole.
Hving girl problems? Don't waste your time on GDD, post here!
http://www.mensalmanac.com/zeromain
People who bought from me --->Wakes4Fun, 1fast90civicsi
EG2Driver is offline Report Post   Reply With Quote
Old 12-15-2005, 06:50 PM   #11
-Gambit-
-Gambit-'s Avatar
Send a message via AIM to -Gambit-
Default Re: Metal Polishing How-to (Mr.R******)
nice write up
***ANTI-HEROS president*** ---Ek Squad #5---
-99% of low offset honda are just a set away from some chrome fender trim-
-Gambit- is online now Report Post   Reply With Quote
Old 12-15-2005, 06:51 PM   #12
Anthony
Mr. Fuch-yu
Anthony's Avatar
Default Re: (deadend9009)
Dude that was like $4 at the Wal-Mart.
-Red
Old 12-15-2005, 06:53 PM   #13
mike93eh
Guest
Posts: n/a
lookin good
Old 12-15-2005, 06:55 PM   #14
shynop
Guest
Posts: n/a
Default Re: Metal Polishing How-to (-Gambit-)
nice write up man.
honestly, how long did that take to do though?
Old 12-15-2005, 06:56 PM   #15
Local Tuner
Local Tuner's Avatar
Send a message via AIM to Local Tuner
Default Re: (mike93eh)
Originally Posted by mike93eh
lookin good
Fo - Local Tuning
Local Tuner is offline Report Post   Reply With Quote
Old 12-15-2005, 06:56 PM   #16
-Gambit-
-Gambit-'s Avatar
4-6 dollar at checker or pep boys
Old 12-15-2005, 06:56 PM   #17
97spooncivic
97spooncivic's Avatar
Send a message via AIM to 97spooncivic
nice write up red, especially for the price, that valve cover is nice
<U>Selling my Yellow Turbo Hatch</U>
http://honda-tech.com/zerothread?id=1842728
Need work done in the So Cal area?: http://profile.myspace.com/ind...2b773
Check it out ^^^^ http://images.honda-tech.com/set1/smile/emthup.gif
97spooncivic is offline Report Post   Reply With Quote
Old 12-15-2005, 06:56 PM   #18
JDM-EJ1
Danpat/Roche/Cassadee <33
JDM-EJ1's Avatar
Love it!
Positive thoughts, become positive things.
-Michael Parker
JDM-EJ1 is offline Report Post   Reply With Quote
Old 12-15-2005, 07:08 PM   #19
VRD^sam
VRD^sam's Avatar
Default Re: Metal Polishing How-to (JDM-EJ1)
Originally Posted by JDM-EJ1
Love it!
VRD^sam is offline Report Post   Reply With Quote
Old 12-15-2005, 07:19 PM   #20
Anthony
Mr. Fuch-yu
Anthony's Avatar
Default Re: Metal Polishing How-to (McTree)
Originally Posted by McTree
nice write up man.
Understand this. I only polished the top of the valve cover for this write up. The section I polished took me about 30-45 min. It's real easy once you gather up all of the materials. And the Pepsi bottle sprayer beats the hell out of a spray bottle IMO. Thanks for the responses.
-Red
Old 12-15-2005, 07:43 PM   #21
EG2Driver
EG2Driver's Avatar
No all thanks go to you....good and useful write up
People who bought from me ---&gt;Wakes4Fun, 1fast90civicsi
Old 12-15-2005, 07:52 PM   #22
khabi khabi
khabi khabi's Avatar
nice work but you couldve made it easier on yourself if you had an aircompressor,you might want to check out this company,www.eastwoodco.com,look under metal finishing buffing ,nice work i bet your tired.
khabi khabi is offline Report Post   Reply With Quote
Old 12-15-2005, 07:56 PM   #23
ekcivic9
ekcivic9's Avatar
Send a message via AIM to ekcivic9
to speed things up even more, you can buy one of those polishing wheels and put em on a buffer / bench grinder.
then just run the motheres mag through that.
nitrared did a killer job on the prep work... which is the key. skimp out on the prep and the polishing part will not turn out as well.
now i want pics of the valve cover in the car
-edit- is it possible to get the areas near the honda logo as shiney as the rest of the vc? the area is kinda beveled ?
was your v/c painted before? i thought it was just bare metal?
sorry for the questions.
--NSX-T]--
--retired[EJ8 Squad #098]--
ekcivic9 is offline Report Post   Reply With Quote
Old 12-15-2005, 07:59 PM   #24
mike93eh
Guest
Posts: n/a
Default Re: (ekcivic9)
yes please..
Old 12-15-2005, 08:01 PM   #25
...Baker
...Baker's Avatar
you're pretty cool for doing this write up..
**bookmarked**
EJ6 Team Member #4
http://www.RandDMotorsports.com http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif
Vouches: FhCRubarb, wOrd!, DRFlickner, RHDRICHEEEE, 97civicB18C, HAL20XX, shibiku, daonei, nuspeed27, midwestsir, Grip King, freakin_eLRoD, PEARLelectron, CB7VTEC, ArinX, Tallkyle
Closet SRR Freak
...Baker is offline Report Post   Reply With Quote
Bookmarks
1200, aluminum, cover, grit, honda, metal, metallic, notebook, paper, polish, polishing, sandpaper, tech, to, tsx, valve
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
