Increase your engine lifespan with the MFactory Oil Catch Can. By acting as a reservoir for waste gases (and overflowing oil during tight cornering), via the built-in oil level indicator, you can view the amount of oil that has been caught by the catch can and route the oil back to your engine sump to prevent oil starvation.
Whether you are an amateur trackday enthusiast or race professionally, installing our Oil Catch Can is a must!
- CNC Aluminum Body
- 15mm Hose Fitting
- Includes Hose & Clamps
- MSRP: $59.95 + Shipping
Precision Machined from T6 aluminum, the MFactory Oil Block Adaptor is the perfect solution for those installing aftermarket oil temperature and oil pressure gauges, or for your turbo's oil feed line.
- 3 x 1/8 point sensor holes
- Fits most Honda, Mazda/Ford and Mitsubishi blocks/filters
- MSRP: $49.95 + Shipping
Precision machined from T6 Aluminum, the MFactory Oil Cap is lightweight, as it is strong, preventing potential failure from plastic units under racing conditions.
- Unique Final Drive "Ring Gear" design
- Functional "Bolt Holes" allowing a safety wire to be attached
- Laser-etched MF logo
Constructed from lightweight Aluminum, the MFactory Water Sensor Adaptor allows you to install your water temperature sensor with ease.
- Designed specifically for use with aftermarket water temperature gauges
- 1/8 point sensor hole fits most popular aftermarket water sensors
- Includes hose clamps
- MSRP: $14.95 + Shipping
Increase your engine's lifespan with the MFactory Magnetic Drain Plugs. By removing metal shavings from your oil, this will prevent premature damage and increase the life of your engine. You will notice a smoother running engine and significantly cleaner oil between changes.
Do not let your next oil change go by without installing our Magnetic Drain Plugs. Our plugs replaces your stock OEM drain plug with hassle free installation. Don't rely on your oil filter to catch damaging particles in your oil - Your oil filter alone Cannot save your engine from metal shavings.
Our Magnetic Drain Plugs come with a crush proof aluminum washer to stop leaks and utilises a neo-dymium magnet which will not rust. Beware of other cheap plugs on the market with a weak magnet.
The image to the left shows our magnetic drain plug lifting an old Cam Gear, a rear camber arm (Weighing over 1.2kg!) and 2 plugs attracted to each other through a solid 1.5inch wood shelf.
Features:
- Made of extra-durable lightweight Aluminum
- Neo-Dymium Magnet that Will Not Rust
- Tested to hold over 1.3kg!
- Safety-Wire hole to meet race regulations
- Extremely cheap insurance for your engine
- MSRP (Oil Pan or Tranny Plug): $14.95
- MSRP (Set): $24.95
How are these compared to the PasswordJDM plugs?I would buy those but cant get ahold of the dealership selling them.They had a set (tranny and oil) for $15.
We don't currently offer a pickup service just now as we are temporarily working from a small office while we look for a suitable location for a workshop.
In regards to getting the plug for the weekend, quickest we could get it out to you would be around mid next week as we are waiting for a new batch of plugs to arrive which should be here hopefully start of next week (Holiday post )
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaMarketPlace.com content, comments, or advertising. HondaMarketPlace.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaMarketPlace.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
