Stock Ignition or Keep MSD
Old 12-04-2005, 07:42 PM
XX Boosted Si XX's Avatar
Default Stock Ignition or Keep MSD
Need some opinions, I currently use the MSD sport compact ignition and everyime I tune the dyno cant read the rpm signal correctly because of the multi spark I guess. Do you think I should go back to stock ignition system or keep that setup? Will that screw up my car since I had it dyno tuned with the MSD? Sorry if im not making any sense...lol
Old 12-04-2005, 07:47 PM
Soccerking3000's Avatar
Default Re: Stock Ignition or Keep MSD (XX Boosted Si XX)
its been proven the stock ignition equipment is good for tons of power, i would just use stock stuff and sell the msd and use the money for tuning lol
Old 12-04-2005, 07:52 PM
Default Re: Stock Ignition or Keep MSD (Soccerking3000)
do you think I would need to retune if i change the ignition system back to stock? Car runs great now but always a problem on the dyno
Old 12-04-2005, 08:00 PM
technically it really should make a huge change but i dont know for sure sry man
Old 12-04-2005, 08:01 PM
tallyturbo's Avatar
ill bump this on up because i am debating on doing this also.
Old 12-04-2005, 08:04 PM
mike93eh
Guest
Posts: n/a
i like to keep the ignition completely stock except for a msd cap and coil.
Old 12-04-2005, 09:08 PM
Black DC2's Avatar
Default Re: (mike93eh)
i have seen well over 600 hp on stock ignition and stock head no pp
Old 12-07-2005, 10:20 AM
ppfalcon's Avatar
Default Re: (Black DC2)
i would get crane hi-6 ignition it has so many functions and you can adjust timing from inside the car..
this will allow you to run more boost and having a good solid ignition signal..
every notice how on dynos the signal skips alot and is not very linear? this is because of bad or insufficient ignition.
call msd or crane they will tell you the same or check out turbomustang.com
Old 12-07-2005, 02:22 PM
mike93eh
Guest
Posts: n/a
Default Re: (ppfalcon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ppfalcon &raquo;</TD></TR><TR><TD CLASS="quote">i would get crane hi-6 ignition it has so many functions and you can adjust timing from inside the car..
call msd or crane they will tell you the same or check out turbomustang.com</TD></TR></TABLE>
we're talking about hondas here not mustangs. stock ignition does absolutely great at 600whp.
Old 12-07-2005, 02:39 PM
hondaeg8's Avatar
stock.. msd ignition left me stranded one time
Old 12-07-2005, 02:50 PM
flip1199's Avatar
what's so good about being able to adjust timing in the car when u cant change the fuel map? stock is best up to a point. once that point is met M&W or COP is your friend.
h2b_sedan
Engine Management and Tuning
09-30-2009 01:13 PM
allhonda
07-14-2007 09:27 AM
SiRkid
12-15-2006 10:53 AM
DriveSlowHomie
05-23-2005 09:08 PM
DevSys
08-30-2001 05:36 PM
Quick Reply: Stock Ignition or Keep MSD
