k20a, k20a1, k20a2, k20a3, k20z1, k20z3 whats the difference
Old 11-08-2005, 07:23 PM
Role Model's Avatar
Default k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference
What the difference with all the new k20, they all have about the same lbs-ft of torque 132 to 155 but hp goes from 155 to 220 so is it only the head is different or what ?!
k20a : 220hp, 155 ft-lbs
k20a1: 160hp, 141 ft-lbs
k20a2: 200hp, 142 ft-lbs
k20a3: 160hp, 132 ft-lbs
k20z1: 210hp, 143 ft-lbs
k20z2: 155hp, ??? ft-lbs
k20z3: 197hp, 139 ft-lbs
Modified by SpoonModel at 9:04 PM 11/10/2005
Role Model is offline
Old 11-08-2005, 09:16 PM
SiR Phil's Avatar
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference (SpoonModel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonModel &raquo;</TD></TR><TR><TD CLASS="quote">What the difference with all the new k20, they all have about the same lbs-ft of torque 132 to 155 but hp goes from 155 to 220 so is it only the head is different or what ?!
k20z1: 197hp, 139 ft-lbs
k20z3: 210hp, 143 ft-lbs</TD></TR></TABLE>
Okay, first off... there is no K20A1, nor is there a K20Z2... at least not in North America or Japan, so I don't know where you got that info. And you got the K20Z1 and K20Z3 mixed up.
Second, it's more than just the head. Some of the engines have oil coolers, a counterbalanced and balanced crankshaft (versus just balanced), and stronger rods. The Z engines have different ECUs than the A engines, and the new Z3 uses a throttle by wire system. Also, there's the issue of an LSD, found only on the K20A and K20Z3.
SiR Phil is offline
Old 11-09-2005, 04:42 AM
H-T Order of Merit
George Knighton's Avatar
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference (SiR Phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Phil &raquo;</TD></TR><TR><TD CLASS="quote">Also, there's the issue of an LSD, found only on the K20A and K20Z3.</TD></TR></TABLE>
All K20A(*) have an LSD? It was an option on the CTR in all markets, and I <u>thought</u> it was an option on the ITR in most markets.
Am I wrong about that?
George Knighton is offline
Old 11-09-2005, 06:37 AM
sk8flex's Avatar
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">All K20A(*) have an LSD? It was an option on the CTR in all markets</TD></TR></TABLE>
Only the JDM CTR EP3s are factory equipped with LSD, European CTRs come without LSD as standard and it´s no dealer option in most countries. The only European country I know about that can order LSD as an option for the CTR is Switzerland.
sk8flex is offline
Old 11-09-2005, 07:13 AM
The Tech-1's Avatar
The Tech-1 is offline
Old 11-10-2005, 06:16 AM
SiR Phil's Avatar
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference (sk8flex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8flex &raquo;</TD></TR><TR><TD CLASS="quote">Only the JDM CTR EP3s are factory equipped with LSD, European CTRs come without LSD as standard and it´s no dealer option in most countries. The only European country I know about that can order LSD as an option for the CTR is Switzerland. </TD></TR></TABLE>
Don't forget that European CTRs come with a K20A2, whereas JDM CTRs come with the K20A, so to answer George's question, all K20A 6 speed trannies should have an LSD in them.
SiR Phil is offline
Old 11-10-2005, 06:43 AM
H-T Order of Merit
Now I'm really confused.
I feel like I'm calculating the date for Easter.
Is it the first Sunday after the first full moon after the Vernal Equinox, but after Passover?
I before E except after C? Or was it G? What if the G is in a diphthong?
What if it's a JDM diphtong that was imported to Switzerland?
Old 11-10-2005, 08:04 PM
Role Model's Avatar
i live in canada and if i'm right in canada the k20a1 is the base rsx 02-04 and the k20z2 is the 06 new EL (forgot the new name)
so whats the different with the a and the z ?!
Old 11-10-2005, 08:29 PM
Nikos's Avatar
I like to give specific answers to specific questions. Your question is too broad and would probable take me a long time to cover all aspects.
As far as the difference between the a and the z... It really depends what Z you are referring to and what a....
The z1 and a2 have different cams, intake manifold but same block and head (bare)
Nikos is offline
Old 11-11-2005, 05:01 AM
H-T Order of Merit
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference (Nikos)
I really thought the EL was just going to have a K20A3, and that the 155 HP rating was because of the new HP rating standards.
After thinking about it, though, I realise that they might have had to make some internal changes because of how the motor in the new EL would be tilted back against the firewall when compared to the motor that was in the old SiR.
I guess that makes sense, since some stresses would be different and some major parts (like the header, certainly) would have to be different.
Maybe that's also why we have a K20Z3 instead of just putting the K20Z1 into the new FG2 Si.
Old 11-11-2005, 10:11 AM
BarracksSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Now I'm really confused.
What if it's a JDM diphtong that was imported to Switzerland?</TD></TR></TABLE>
Makes me think of a certain card game (don't know the name) where you make up the rules as you go along...
"Well, normally, on the second Friday of the month, spades would be higher; but since it's November, a trick has to be alternating..."
BarracksSi is offline
Old 11-11-2005, 03:34 PM
SiR Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonModel &raquo;</TD></TR><TR><TD CLASS="quote">i live in canada and if i'm right in canada the k20a1 is the base rsx 02-04 and the k20z2 is the 06 new EL (forgot the new name)
so whats the different with the a and the z ?!</TD></TR></TABLE>
No no no no no. The base rsx engine is the K20A3... same as the EP3. And the new EL should have the same R-series engine in the new civics. There is no a1, and there is no z2.
SiR Phil is offline
Old 11-11-2005, 03:35 PM
SiR Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">I really thought the EL was just going to have a K20A3, and that the 155 HP rating was because of the new HP rating standards.
Maybe that's also why we have a K20Z3 instead of just putting the K20Z1 into the new FG2 Si.</TD></TR></TABLE>
ELs are just rebadged civics... so the engine should be the same as that (new R-series). If it has a K... well.. now I feel cheated!
SiR Phil is offline
Old 11-12-2005, 06:49 AM
Role Model's Avatar
yeah but the new el have 155hp sorry but i have a book thats say it all
Old 11-12-2005, 04:18 PM
SiR Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonModel &raquo;</TD></TR><TR><TD CLASS="quote">yeah but the new el have 155hp sorry but i have a book thats say it all</TD></TR></TABLE>What book is this? Acura of Canada hasn't even put up the new EL on their website, and I've heard no official news.
SiR Phil is offline
Old 11-13-2005, 05:55 PM
Role Model's Avatar
its a french book, talking about all of canada car in it, forgot the name damnit
Old 11-14-2005, 12:26 PM
Root79's Avatar
Switzerland Guy correct about K20A2 trany. We don't heave here in Europe on CTR the LSD. Sadly, but that's the fact.
Root79 is offline
Old 11-14-2005, 02:07 PM
lastlude2k1se's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Phil &raquo;</TD></TR><TR><TD CLASS="quote">What book is this? Acura of Canada hasn't even put up the new EL on their website, and I've heard no official news.</TD></TR></TABLE>
http://www.acuraworld.com/foru...63043
New Acura CSX(old EL), will have a K series engine in it. 155 hp
It's a civic with JDM front and rear end conversion and K series swap and possibly better suspension
lastlude2k1se is offline
Old 11-14-2005, 03:36 PM
pon55's Avatar
Looks good by me!
pon55 is offline
Old 11-17-2005, 04:45 PM
SiR Phil's Avatar
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference (lastlude2k1se)
I didn't want to take the word of a forum, so I did some looking around... you were right. K20A3 going into the CSX... maybe they're calling IT the Z2 though, due to the new SAE measurement regs (just like a z3 is basically a z1 + LSD).
SiR Phil is offline
Old 11-17-2005, 09:30 PM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Phil &raquo;</TD></TR><TR><TD CLASS="quote">I didn't want to take the word of a forum, so I did some looking around... you were right. K20A3 going into the CSX... maybe they're calling IT the Z2 though, due to the new SAE measurement regs (just like a z3 is basically a z1 + LSD).</TD></TR></TABLE>
the Z3 also has the chain-driven balancer mounted in oil pan which the z1 doesn't.
H23 Power is offline
Old 11-18-2005, 05:22 AM
H-T Order of Merit
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z2, k20z3 whats the difference (H23 Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power &raquo;</TD></TR><TR><TD CLASS="quote">
the Z3 also has the chain-driven balancer mounted in oil pan which the z1 doesn't.</TD></TR></TABLE>
Well, for goodness sake. There goes two HP.
Old 11-18-2005, 10:21 AM
H23 Power's Avatar
Well, for goodness sake. There goes two HP. </TD></TR></TABLE>
supposedly thats the only internal difference between the engines. so it may be responsible for more than a 2 hp loss. seeing as the Z3 also has electric power steering should have made up a few hp.
Old 04-14-2009, 09:16 PM
bkkfarang's Avatar
Default Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z3 whats the difference
K20
[edit]K20A
The 2.0L (1998 cc) K20 engines have 86 mm (3.39 in) bore and 86 mm (3.39 in) stroke. The 2.2L (2157 cc) version has 87.0 mm (3.43 in) bore & 90.7 mm (3.57 in) stroke.
Found in:
Honda Civic Mugen RR Advanced Concept
Displacement: 2,157 cc (131.6 cu in)
Power: 260 PS (256 hp/191 kW) @ 8250 rpm
Torque: 237 N·m (175 lb·ft) @ 6750 rpm
Honda Civic Mugen RR (Honda ABA-FD2)
Displacement: 1,998 cc (121.9 cu in)
Compression: 11.7:1
Power: 225 PS (222 hp/165 kW) @ 8000 rpm
Torque: 218 N·m (161 lb·ft) @ 7000 rpm
Redline: 8400 rpm
2007- Honda Civic Type-R (FD2)
Compression: 11.7:1
Power: 222 bhp (225 PS, 165 kW) @ 8000 rpm
Torque: 158 ft·lbf (215 N·m) @ 7000 rpm
Redline: 8600 rpm
2001-2006 Honda Civic Type-R (EP3)
Compression: 11.5:1
Power: 212 bhp (218 PS, 158 kW) @ 8000 rpm
Torque: 149 ft·lbf (202 N·m) @ 7000 rpm
Redline: 8600 rpm
2001-2007 Honda Integra Type-R (DC5)
Compression: 11.5:1
Power: 220 bhp (220 PS, 162 kW) @ 8000 rpm
Torque: 152 ft·lbf (206 N·m) @ 7000 rpm
Redline: 8600 rpm
I-VTEC Engagement: 6200 rpm
2003-2007 Honda Accord Euro-R
Compression: 11.5:1
Power: 217 bhp (220 PS, 162 kW) @ 8000 rpm
Torque: 152 f·lbf (206 N·m) @ 7000 rpm
Redline: 8800 rpm
[edit]K20A2
Found in:
2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP3, European)
Compression: 11.0:1
Power: 200 ps/201 hp (148 kW) @ 7400 rpm
Torque: 146 ft·lbf (193N·m) @ 5600 rpm
Redline: 7900 rpm
I-VTEC engagement: 5800 rpm
[edit]K20A3
Found In
2002-2005 Honda Civic Si
2002-2004 Acura RSX
Compression: 9.8:1
Power: 160(120 kW) @ 6500 rpm(SAE net J1349 Rev 8/04)
Torque: 142 lb·ft (193 N·m)* (191 N·m) @ 4000 rpm(SAE net J1349 Rev 8/04)
Redline: 6800 rpm
[edit]K20A4
Found in:
2003-2005 Honda Accord (UC1)
2006-2008 Honda Accord (UC3)
2001-2007 Honda CR-V (RD5)
2000-2003 Honda Stream (RN1)
2004-2007 Honda Stream (RN3)
[edit]K20A6
Found in:
2003-2005 Honda Accord (European)
[edit]K20Z1
Found in:
2005-2006 Acura RSX-S
Compression: 11.0:1
Power: 210 hp (154 kW) @ 7800 rpm (SAE net J1349 Rev 8/04)
Torque: 143 ft·lbf (194 N·m) @ 7000 rpm (SAE net J1349 Rev 8/04)
Redline: 8300 rpm
i-VTEC Engagement Window:5800 rpm
[edit]K20Z2
Found in:
2006- Acura CSX (Canada)
Compression: 9.6:1
Power: 155 hp (114 kW) @ 6000 rpm (SAE net J1349 Rev 8/04)
Torque: 139 ft·lbf (188 N·m) @ 4500 rpm / 188 N·m @ 4200 rpm (Singapore)
Redline: 6800 rpm
2006- Honda Civic (JDM)
Compression: 9.6:1
Redline: 6800 rpm
2006- Honda Accord(Europe)
Displacement: 1998 cc
Compression: 9.6:1
Redline: 6800 rpm
[edit]K20Z3
This inline-4 cylinder internal combustion engine is found in the US market Honda Civic Si (2006+) & Canadian market Acura CSX Type-S. It has an aluminum block with an aluminum head, and a bore and stroke of 86 mm x 86 mm, resulting in a 2.0 Liter displacement.
Found in:
2006-2009 Honda Civic Si (FG2 - Coupe & FA5 - Sedan), 2007 Acura CSX Type-S
Displacement : 1,998 cc (121.9 cu in)
Compression : 11.0:1
Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 139 ft·lbf (189 N·m) @ 6200 rpm (sae NET Rev 8/04)
Redline: 8000 rpm
i-VTEC Engagement Window:5600 rpm
[edit]K20Z4
This inline-4 cylinder internal combustion engine is found in the redesigned Honda Civic Type-R (FN2). It has an aluminium block with an aluminium head, and a bore and stroke of 86 mm*86 mm, resulting in a 1,998 cc (121.9 cu in) displacement.
Found in:
2007 Honda Civic Type-R (FN2) (Europe Market)
Power: 222 bhp (201 PS, 148 kW) @ 7600 rpm
Torque: 142 ft·lbf (193 N·m) @ 5600 rpm
Redline: 8200 rpm
i-VTEC Engagement: 5,400 rpm
[edit]K23
[edit]K23A1
Turbocharged
Found in:
2007/2008 Acura RDX
Displacement: 2,300 cc (140.4 cu in) [1]
Compression: 8.8:1 [2]
Power: 240 hp (179 kW) @ 6000 rpm (SAE net)
Torque: 260 lb·ft (353 N·m) @ 4500 rpm (SAE net)
Redline: 6800 rpm [3]
Bore: 86 mm
Stroke: 99 mm
[edit]K24
K24A4
[edit]K24A1
Found in:
2002-2006 Honda CR-V
Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (120 kW) @ 6000 rpm
Torque: 162 ft·lbf (220 N·m) @ 3600 rpm
Redline: 6500 rpm
[edit]K24A2
Found in:
2004-2008 Acura TSX
Compression: 10.5:1
Power: 200 hp (147 kW) @ 6800 rpm (2004-2005)
Power: 205 hp (150 kW) @ 6800 rpm (2006-2007) *SAE Net Rev 8/04
Torque: 166 ft·lbf (225 N·m) @ 4500 rpm (2004-2005)
Torque: 164 ft·lbf (222 N·m) @ 4500 rpm (2006-2007)*SAE Net Rev 8/04
VTEC Engagement: 6000 rpm
Redline:
Automatic 7100 rpm
Sequential Sportshift 7300 rpm
Manual 7600 rpm
[edit]K24A3
Found in:
2003-2007 Honda Accord (Europe(EDM)) and Japan(JDM)) and 2003-2007 Honda Accord Euro CL9 (Australia)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 10.5:1
Power: 189 hp (140 kW) @ 6800 rpm
Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm
Redline: 7400 rpm
[edit]K24A4
Found in:
2003-2005 Honda Accord, 2003-2006 Honda Element
Compression: 9.7:1
Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
Torque: 161 ft·lbf (218 N·m) @ 4500 rpm (@4000 rpmin 2007/2008)
Redline: 6800 rpm
[edit]K24A8
Found in:
2006-2007 Honda Accord
Compression: 9.7:1
Power: 166 hp (124 kW) @ 6000 rpm
Torque: 160 lb·ft (217 N·m) @ 4000 rpm
Redline: 6500 rpm
2007-2008 Honda Element
Compression: 9.7:1
Power: 166 hp @ 5800 rpm
Torque: 161 lb·ft (218 N·m) @ 4000 rpm
Redline: 6800 rpm
[edit]K24Z1
Found in:
2007- Honda CR-V (RE3, RE4)
Compression: 9.7:1
Torque: 161 ft·lbf @ 4200 rpm
Redline: 6500 rpm
[edit]K24Z2
Found in:
2008 Honda Accord LX/LX-P trim models
Compression: 10.5:1
Power: 177 @ 6500 rpm
Torque: 161 ft·lbf @ 4300 rpm
Redline: 6800 rpm
[edit]K24Z3
Found in:
2008 Honda Accord LX-S/EX/EX-L trim models
Compression: 10.5:1
Power: 190 @ 7000 rpm
Torque: 162 ft·lbf @ 4400 rpm
Redline: 7100 rpm
Found in:
2009 Acura TSX
Compression: 11.0:1
Power: 201 @ 7000 rpm
Torque: 172 ft·lbf (MT), 170 ft·lbf (AT) @ 4300 rpm
Redline: 7100 rpm
bkkfarang is offline
Old 04-15-2009, 05:25 AM
Function > Form
josh's ep3's Avatar
This thread was confusing the crap out of me until I realized it was from '05 haha. Thanks for answering a question nearly 4 years old for your 1st post
josh's ep3 is offline
Quick Reply: k20a, k20a1, k20a2, k20a3, k20z1, k20z3 whats the difference
