#51 | |||||
<FONT COLOR="red">JKMotorsports Traction Bars from LSD Motorsports:</FONT> Great Traction Bars at a Great Price! 93 Hatch, DOHC ZC, Eagle Rods, SRP Pistons, Delta Cams, JG Cam Gears, ARP Studs, JKMotorsports Sidewinder, T3/T04B all real Garrett, Tial KnockOff, Direct Port Nitrous, CromePro, LC-1, Ostrich, Helical LSD, Clutch Specialties Stg4 90 RHD Hatch in Build |
#52 |
![]() New numbers on 16lbs. This was done on 93 pump gas, stock head, stock internals. 300whp and 238wtq on a completely stock dohc zc with OEM 86-87 d16a1 internals. |
#53 |
Those are awesome numbers LurkerS8!! My car is almost back together...here is some sneak peaks.. goals? over 500whp at high boost! zc powa ![]() ![]() ![]() liam
93 civic track hatch |
#54 |
Damn Liam821! I can't wait to see the new graph on that sick setup. We have yet to put my built block together
Should be done by winter time and hoping for about 350+ on 18lbs-20lbs on pump gas. Should be good for low 11's to high 10's in my little crx.
#55 | |
I'm still debating on which pistons to run. HKS gasket, Rods and ARP's are here already. What pistons are you running Lurker and Liam?
http://www.GO-AUTOWORKS.com 88' Civic HB D16 10.99 @131MPH 09'-2010 Import Face-Off Race Sponsors...Keep the Sport alive, Come Race with US!! |
#56 |
Moderator
I <3 d-series and zc-series
http://people.clemson.edu/~ABense |
#57 | |
If i was to do it again, i would ask Endyn for some 9.5:1 - 10:1 turbo rollerwave dohc ZC pistons. liam
#58 |
my setup before the rebuild...
#59 | |
#60 | |
liam
#61 |
Yeah, the highest I found for the Z6 that wasn't just an N/A was the 10.5:1. I also spoke to Endyne about the rollerwaves as well that are.5 over.
#62 |
My old setup from 03, which blew because of the damn fiber HG's. Grrr.
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
#63 |
#64 | |
![]() liam
#65 | |
#66 |
Hi, I have built ZC to. CP pistons, Eagle rods, ARP studs, OEM head gasket. It worked fot one week in 250HP and head gasket blow of. Did't You have that problem? What head gasket do You use? Do You have block guart or darton sleeves?
#67 | |
#68 |
I'm giving the OEM HG a try, if she blows, I'll step up.
#69 | |
#70 |
I use CP pistons from D16A6 cr11 and they are ok, much stronger than stock. With HKS head gaskek i would have cr 10, isn't it to much? with oem 9.7. A lot of people said that oem gasket will hold if its tune right, is it true?
#71 | ||
I HATE fiber gaskets. Quote:
#72 |
OEM is lower than 9.7 stock
#73 |
where you are guys getting the HKS HG's from?
I've been running the stock gasket for a couple years @ 10 psi (tdo4) with zero problems *knocks on wood* |
#74 |
I actually just bought one from NOPI (of all places). Overboost.com also lists them.
#75 |
I know that oem CR in ZC is 9.5 but head was milled about 0.3mm and CP pistos have a litte diferent volume so now i have about 9.7. Maybe i buy HKS, cr 10 is still ok for turbo.
| Bookmarks |
| Tags |
| 5th, 91, boosted, builds, d16, distributor, dohc, gen, obd1, piston, rebuild, spec, specs, wiseco, zc |
