> Forced Induction
Old 11-05-2005, 06:41 PM   #1
Scracho
Scracho's Avatar
Default ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s
Did a search for some info and found very limited amount of information. I've been reading through the LS-T thread for a bit and just recently the D-Series thread. So I thought it would be cool to start a DOHC ZC-T thread. So lets see your setups and numbers. I'm in the process of trying to determine which route I would like to go in my EG and having had a CRX before with a ZC I thought I might try to build an OBD1 ZC for my EG considering their a D-series base which is already cheaper to build than a B-series and the fact you can get one from a JDM supplier for 1/3rd the cost of a B-series I thought this would be an awesome budget build!
Brantford Honda
Jon Machado - Service
Scracho is offline Report Post   Reply With Quote
Old 11-05-2005, 06:57 PM   #2
SOHCEK-Turbo
SOHCEK-Turbo's Avatar
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (Scracho)
Not bad didnt know there was obd1 ZC around. Let us know how it goes. Im sure there inst many around here with ZC anymore. But lets see some numbers from the people that do have one boosted. Im intersted since my friend had a ZC before he did another swap.
B & D series Torque Specs
http://www.honda-tech.com/zerothread?id=1169414
SOHCEK-Turbo is offline Report Post   Reply With Quote
Old 11-05-2005, 07:10 PM   #3
Scracho
Scracho's Avatar
The only information I have found to date is from a user here on HT; liam821 and his wicked 380whp/280torque @ 23psi DOHC ZC-T. From what I understand it's a 93 Si with a built OBD1 ZC. Bottom end is a Golden Eagle special with all the goodies and a ported head by JG Engine Dynamics.
Here is a pic of his setup:
Brantford Honda
Old 11-05-2005, 07:14 PM   #4
Rubixcu7
Rubixcu7's Avatar
Send a message via AIM to Rubixcu7
i know the guy who bought my ls mesh had a boosted zc in his crx
let the vtec roar...
Rubixcu7 is offline Report Post   Reply With Quote
Old 11-05-2005, 07:59 PM   #5
second edition
second edition's Avatar
heres mine.183/171 on 7lbs tuned on crome. ill be ditching the greddy kit this winter for a tubular manifold with a gt28r and a full 3 in and raising the boost a little.im hoping for around 240-250whp at around 10lbs..if i blow it, itll be a cheap rebuild
ej1 with boosted dohc zc
188hp,171tq .................sold
5th gen sedan................daily
Current project: 1994 garden style condo....Lots of mods
second edition is offline Report Post   Reply With Quote
Old 11-05-2005, 08:07 PM   #6
Scracho
Scracho's Avatar
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (second edition)
Stock internals I'm assuming? How long have you been running this setup? Any other mods i.e. Cams, headwork, fueling??
Just trying to get as much info as possible
Brantford Honda
Old 11-05-2005, 08:47 PM   #7
second edition
yes,stock internals.i have a walbrow 255 lb fuel pump and a b&m fpr..ill be buying tunertoys 550cc injectors with the new setup though..ive been running the setup 2 yrs,but only this summer on the crome and it usually sits in the garage
Old 11-06-2005, 02:23 AM   #8
mrchris1979
mrchris1979's Avatar
Well I just got my ZC finished up on the build. I'll type up the specs later but basically we will be tuning up to 30psi on a GT3071Rwith an equal length manifold. We are hoping mid 400's which is almost maxing the turbo out. I'm sure the ZC can hit high 500's at the same boost level with a bigger turbo but I want to keep the ride more streetable and the GT3071R seems to have the better response on the street while providing a wider powerband and still have just enough top end for the 1/4 mile. I have searched everywhere for info on the ZC with any GT turbo set-up and found nothing. So all I can do is hope that I get good numbers out of it. I really don't know what to expect at this point but when its all said and done, I'm hoping for 300's in the 18-22psi range on pump gas and 400's to 30psi on race gas. I have spent a large amount of time in research and money into this build, so if you anyone needs help on where to get parts for a ZC build, I'll be happy to help you out. Pics of the set-up coming soon.
B18c1 Turbo CRX - 400whp 331tq @13psi E85 fueled
In Memory Of Columbine. "We Will Never Forget"
mrchris1979 is offline Report Post   Reply With Quote
Old 11-06-2005, 03:37 AM   #9
civic_16s
civic_16s's Avatar
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (mrchris1979)
Stock internals
T3 .60/.48 by turbonetics
RC550's tuned with turboedit (OBD-0) and PLX R500 logger.
I'm pushing 9 psi I'll go to dyno asap.
And yeah, I know, SSAutoship mani, don't blame me I'll change.
Modified by civic_16s at 4:23 AM 11/6/2005
Modified by civic_16s at 2:00 AM 5/2/2006
Modified by civic_16s at 2:01 AM 5/2/2006
89' civic ZC with T3 60 trim
450's and turboedit fuel/ign management
Stay tuned http://images.honda-tech.com/set1/smile/emwink.gif
civic_16s is offline Report Post   Reply With Quote
Old 11-06-2005, 04:32 AM   #10
86si
86si's Avatar
Send a message via ICQ to 86si Send a message via AIM to 86si
I made 325whp on 25psi with a stage 2 T-netics, stock head TB and intake. just a built lower end. with spray it made 403whp. this was OBD0 Zdyne
86 Civic Si
<U>Counter Clockwise inc. </U>845-518-5023 or PM me.
[b]my 86 Si resto project[b]
[b]the shorter version[b]
86si is offline Report Post   Reply With Quote
Old 11-06-2005, 06:23 AM   #11
Scracho
Scracho's Avatar
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (86si)
^^^ Wow this is some great stuff guys! Keep it coming and thanks mrchris1979 for offering your help to those of us who may need some guidance.
Brantford Honda
Old 11-06-2005, 08:17 AM   #12
v-tec maz
Send a message via AIM to v-tec maz
shit i didnt even know you could do this, this is cheap and awesome. what kind of modification's do you have to to the head? just wxtrea oil lines?
v-tec maz is offline Report Post   Reply With Quote
Old 11-06-2005, 08:26 AM   #13
Soccerking3000
Soccerking3000's Avatar
Send a message via AIM to Soccerking3000
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (v-tec maz)
what? the ZC is a DOHC d-series
BUY MY TURBO D16 STUFF
http://honda-tech.com/zerothread?id=1743695
Garrett, Greddy, TIAL, APEX'I
Soccerking3000 is offline Report Post   Reply With Quote
Old 11-06-2005, 09:27 AM   #14
Scracho
Scracho's Avatar
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (Soccerking3000)
Yes the ZC came in a variety of configurations, but the most common is the OBD-0 1.6L DOHC that came in the 88-91 Civic's and CRX's in Europe and Japan. There is also an available OBD-1 version of this DOHC 1.6L that came in 92-95 Civic's that is apparently alittle less common than the OBD-0 version. There are also SOHC versions as well.
I'm trying to cover the DOHC versions on this thread.
Brantford Honda
Old 11-06-2005, 11:02 AM   #15
liam821
liam821's Avatar
Send a message via AIM to liam821
Yeah the dohc ZC obd1 is a neat little swap in a EG. That picture above is my old setup, ive changed it now to something new now.
I now have a gt28rs which im gonna try to get around 300whp on pump gas, and 350-400whp (max it out) on race gas. Id like to have a nice powerband this time around.
The dohc ZC is a great little motor though, im pretty impressed with it.
Here is a dyno from my old setup above:
pump gas @ 20psi
Here is the race gas one, but i had a boost leak, you can see where the power isnt there in the topend. Annoying we didnt find it until it was too late.
racegas @ 23psi
liam
93 civic track hatch
liam821 is offline Report Post   Reply With Quote
Old 11-06-2005, 05:46 PM   #16
Scracho
Scracho's Avatar
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (liam821)
^^^ Thanks Liam, those are some impresive numbers! I plan on using a GT series also. I want a real linear powerband, don't want any lag at all.
Brantford Honda
Old 11-06-2005, 08:54 PM   #17
liam821
liam821's Avatar
Im hoping i can get that from the gt28rs. Ill post dyno charts of course once i get it all together.
liam
Old 11-06-2005, 09:10 PM   #18
mrchris1979
I actually based my ZC build after Liam's set-up. I'm hoping to hit a similar dyno graph with the GT3071R but with a little more response on the lower end. Liam, please post the dynograph on the GT28rs, I'm interested to see how the ZC's respond to the GT series turbos. That will at least give me a clue on how the GT3071R will do on my ZC.
Modified by mrchris1979 at 5:21 AM 11/7/2005
Old 11-06-2005, 09:54 PM   #19
liam821
liam821's Avatar
The gt30 should spool alot better then my t3/04e 60trim. It will be a really nice setup!! I cant wait to see the results!
liam
Old 11-06-2005, 10:14 PM   #20
mr_hahn73
mr_hahn73's Avatar
Hey guys here is my setup in my signature but does anyone know where i can get a cheap obd1 grey plug zc distributor. pm me please
Wtb 99-00 SI Wheels
WTB EF si interior for hatch
mr_hahn73 is offline Report Post   Reply With Quote
Old 11-07-2005, 09:01 AM   #21
liam821
liam821's Avatar
Default Re: ZC-T 1.6L DOHC Setups OBD-0/1 Specs/Dyno #'s (mr_hahn73)
ebay (distributor king) $217 - cheapest you are gonna find anywhere.
http://cgi.ebay.com/DOHC-OBD1-...wItem
or find one used, but good luck there.
liam
Old 11-08-2005, 06:48 PM   #22
Scracho
Scracho's Avatar
Well might be getting my ZC very soon... Some tech's at work are trying to convince me to run B-Series N/A, or LS-VTEC, but I'm resisting temptation of the mighty B's in favour of more affordable boost. I keep reminding them that by the time I swap in any B-Series I could have my ZC in and completely built for the cost of your average swap!
Brantford Honda
Old 11-09-2005, 11:34 AM   #23
JonnyCoupe
JonnyCoupe's Avatar
Default Re: (Scracho)
My Cousins Rover Coupe from the UK with a d16a8. Greddy manifold and a T25 with 0.48A/R turbine.
Running just over 5psi at the mo and 175bhp/150lbft, probably going to be pushing the boost up now its been running for a good few months now although clucth needs replaceing sooner. Not sure how high we can go.
Pure JDM Integra SiR-G
It even has a Jap license disk and parking pass http://images.honda-tech.com/set1/smile/emsmilep.gif
JonnyCoupe is offline Report Post   Reply With Quote
Old 11-09-2005, 11:42 PM   #24
mrchris1979
I don't know how to post pics yet but Tobi at TC's performance was nice enough to take a few pics for me. http://www.thezcr.com/forums/s...11992
You gotta love that 3" throttle body. I'll get more pics once we get the turbo hooked up with the motor.
Old 11-12-2005, 08:10 AM   #25
Scracho
Scracho's Avatar
Default Re: (mrchris1979)
Anymore bump?
Brantford Honda
Bookmarks
5th, 91, boosted, builds, d16, distributor, dohc, gen, obd1, piston, rebuild, spec, specs, wiseco, zc
