Easier axle nut removal without impact gun (Tip)
I don't know if any of you have tried this.
When I had to remove one of my axles last time, to keep the wheel from turning while trying to break loose the axle nut, I stuck a slot screwdriver into one of the brake rotor slots. When the wheel turned it came to a stop against the caliper. The nut came off easy using a breaker bar.
Before I figured this out, I spent nearly an hour trying different ways without impact tools.
1 Post
Re: Easier axle nut removal without impact gun (fred92htch)
why not just have someone step on the brakes or wedge something between the seat and the brake pedal? works every time for me.
Re: Easier axle nut removal without impact gun (xtremeazian)
it can some times be to hard even for a breaker
I would recommend buying a compressor and an impact and save the back pain and or hopping on a pole for little kids! lol j/p thats how i used to do it
Re: Easier axle nut removal without impact gun (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">keep the wheels on, remove center caps, put the handbreak on, put it in first, and use a breaker bar.</TD></TR></TABLE>
Oh yeah now your talking, I do this as well but I add a cheater bar to the mix to make it easier.
Re: Easier axle nut removal without impact gun (haccord2.2)
i broke one breaker bar and two sockets before i went out and bought a impact 32mm axel socket with a warranty breaker bar
Re: Easier axle nut removal without impact gun (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">i broke one breaker bar and two sockets before i went out and bought a impact 32mm axel socket with a warranty breaker bar</TD></TR></TABLE>
Yeah I hear that, I use my heavy *** 3/4'' breaker bar and a good impact socket as well, and I still sometimes worry about shattering the socket, because I have done it to one of my MAC impact sockets on something else before and it wasn't fun, but the socket was replaced so that was good.
1 Post
damn. you were unstaking them first right?
Re: Easier axle nut removal without impact gun (monicle)
yea i unstack them
**** was on there good
i had to use a jack ont he breaker bar to break it loose
i snapped a 6foot pipe on the breaker bar too
with a impact gun u dont even have to unstack them
Re: (eldorko86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eldorko86 »</TD></TR><TR><TD CLASS="quote">What way do you turn the bolt?
lefty loosy, righty tighty.
I leave the car on the ground in gear, handbrakes on. take off center cap, use 32mm socket and long breaker bar situated so it is parallel to the ground. use a hydraulic jack under the breaker bar to turn the nut counter clockwise. it will take a lot more than you think to break it loose, but when it does, it goes with a "pop", so be ready.
Re: (kkim)
Yeah they can suck. I broke a Snap-On breaker bar on mine. Best tools you can buy and it bent in half and the knuckle busted open. Ended up just using the "jam something in the rotor end" method and then impacting it off w/an air gun.
allmotorEG-SI
04-09-2005 08:34 PM
djcaseanova
11
12-04-2003 04:38 PM
