#1 | |||||
#2 |
How about a nice evening bump.
#3 |
dizzy king you dont go color to color email Jason(jkobd), he knows the right order, I think you just swap the orange and white though.
a rywire dizzy jumper will cure all concerns as well Ryan
Droppedcrxsi.com for B16 / B18 / K20 Swap Info rywire.com skunk2.com karcepts.com |
#4 |
Your jumper does look like it would work well... the problem is I already took the OBD1 plug off the distributor and I don't how the wiring went so I can't put it back on. (Good job! ... I know)
I'll take your advice and shoot an email to Jason. Thanks a lot. |
#5 |
you can always trace the wires back to the ECU.. I swapped the OBD0 connector on the harness to make it plug in play the other way but wanted to be 100% sure.. it only takes a few minutes to check.
B11-CYP P CYP -P Orange, CYP sensor input, N/A B12-CYP M CYP -M White, CYP sensor signal, N/A B13-TDC P TDC -P Org/Blue, TDC sensor input, N/A B14-TDC M TDC -M Wht/Blue, TDC sensor signal, N/A B15-CKP P CKP -P Blu/Green, CKP Sensor input, N/A B16-CKP M CKP -M Blu/yel, CKP Sensor signal, N/A
AIM: urname7698 Vouch http://images.honda-tech.com/set1/smile/emthdown.gif Bad Sellers: Junsu Rim or Jae Rim - junsurim@acsu.buffalo.edu - (716) 645-4502 - AIM: jrim4169 http://images.honda-tech.com/set1/smile/emthdown.gif http://images.honda-tech.com/set1/smile/emthup.gif Good Sellers: FDragger, civicexcoupeblack, hondaspeeder, ASHY-ELBOW, Marauder, B Speed,grndcont, YumVTEC, Dropspeed, Djaric, chameleon,craiger, maxpsi , SilverCIVIC96 http://images.honda-tech.com/set1/smile/emthup.gif Good Buyers: shiznattik, Pfieffdog, hondaboyitr, timmay, IE EK,sheekdude http://images.honda-tech.com/set1/smile/emthup.gif |
#6 |
Give me a minute homey I got you.........
<U>Destroy everything,obliterate what makes us weak</U> Give them nothing, but take everything. |
#7 |
Here you go these are colors that match up on the distributor. Their is only one pin that doesn't match up to the same color and I highlighted down below.
OBD0 OBD1 orange) (orange white) (white orange/blue) (orange/blue white/blue) (white/blue blue/green) (blue/green blue/yellow) (blue/yellow large white) (yellow/green <only color that is different black/yellow) (black/yellow blue) (blue Modified by goforbroke at 8:52 PM 8/24/2005
#8 |
do the colors even help? he cut the plug off the distributor ... and its a DistributorKing one.. not OEM.. wonder if they use the same colors..
#9 | |
everything that goforbroke said looks accurate. i happen to have my dizzy out of the car right now and matched all the colors up to what he said except for, blue/green to blue/green. i have a blue/green wire on my obd0 side but only have a blue wire(not blue/green) ond the obd1 side, this is wired together. also with the 2 white wires they dont look different in size to me, but how mine is wired is the wire opposite of the clip(obd0 side), is connected to the yellow/green( on the obd1 side). the white wire closest to the clip(obd0 side) is wired to the white on the obd1 side. Hope this helps!!
89 crx si (under construction) 05 subaru legacy gt 06 subaru sti |
#10 | ||
a way to acctually match the white wires is to peal back the harness alittle bit. the most of the wires will be together in a wrap and there will be one white wire off by itself. that white wire goes to the yel/grn
#11 |
you all are correct, BUT dizzy king is not color for color like the stock harness... Just email Jason
#12 |
this may sound gay but what are the advantages of going from odb-0 to odb-1?
277hp turbo LEGO http://www.myspace.com/36636812 $10 says that thing would start rolling like a potato by the 330' |
#13 |
Just grab a voltmeter and trace the wires from the ECU.
The I made the obd1 diagram below a while ago, and its 100% accurate. The obd0 diagram should be accurate also, but i just made it. Using the below info and voltmeter, it should be very easy to get your wiring sorted out. Let me know if you have any other questions. OBD0......OBD1 ------------------ [b10].......[b11] --> cyp P aka cylinder position [b12].......[b12] --> cyp M aka cylinder position [c3].........[b13] --> tdc P aka top dead center [c4].........[b14] --> tdc M aka top dead center [c1].........[b15] --> ckp P aka crank position [c2].........[b16] --> ckp M aka crank position [b15].......[a21] --> Ignitor signal
Proud member of: HB SQUAD "We dont need no stinkin trunks!" <FONT COLOR="red"><FONT SIZE="4">For Sale:</FONT></FONT>-> 90 hf complete car harness. PM me. |
#14 |
Alright, so far I've got this:
(format: distributor -> harness) beige -> orange beige blue -> orange blue white -> white white blue -> white blue blue -> blue yellow -> blue yellow yellow green -> For the two leftover colors I've got two choices: Something that looks like Beige but could maybe be a faded yellow and a blue yellow that may be a blue green. Hows that sound to you? |
#15 |
easier to find parts for any more
lower milage easier to tune....
"freinds don't let freinds, drive stock" |
#16 |
any one got a obd1 distrubitor by chance, or know where to get one...? doing the same conversion
passed bar b16a in my crx, let me know if you need the parts or help. |
#17 |
Distributor King has got 'em listed on eBay. Go the easy route: buy a distrib from them and get the conversion harness from rywire for $30 or so. That way you don't have to post a nice thread like this one.
Benefits of OBD1: Easier to chip and tune an OBD1 ECU. That's all I'm really using it for. |
#18 |
Evening bump...
Come on folks, I only need two more colors! Well... I suppose I could always guess
#19 |
you should have bought the jumper
what if your dist shits the bed then you have to rewire all over again
brand new d seires phantom grip style lsd for sale yo http://www.hondamarketplace.co...id=10 <FONT COLOR="red">To be one with nature simply remove what comes between you and it.</FONT> http://images.honda-tech.com/set1/smile/emthup.gif solfly73 on aim |
#20 | ||
blue goes with blue/grn and yel/grn goes with white
#21 |
Thanks civickiller, appreciate the help.
Hey solfly, nice job concentrating on what I should've done instead of helping me solve the problem. Hindsight is 20/20. If my distributor "shits the bed" then I'll have to buy a nice new one and then I can buy the jumper (like I should have to begin with) and I will have no further problems. Thanks for your concern.
#22 |
Alright, I've got it figured out thanks to all the help I got on here. This is the wiring that made my car finally start up using the Distributor King OBD1 distributor and the JKOBD conversion harness.
Format: OBD1 (Dist King) Distributor --> Engine Harness Tan Blue --> Orange Blue White Blue --> White Blue Yellow Green --> Thick White White --> Orange Tan --> Thin White Blue --> Blue Green Blue Yellow --> Blue Yellow Hope that helps anyone who bothers to do a search on this topic.
#23 |
does dist king use the same color wires every time?
#24 |
#25 | |||
| Bookmarks |
| Tags |
| b16, black, color, conversion, distributor, honda, obd, obd0, obd1, odb, positive, wire, wires, wiring, yellow |
