How important are Camshafts on our Turbo Cars ???
How important are Camshafts on our Turbo Cars ??? Dyno Inside...
this important
this is a before and after dyno graph of just a simple camshaft change - same timing, same boost, same targeted lambda
we are still in the process of playing with the cam gears settings a bit to see if we can pick up anymore from just tinkering with parts that we already have on the car
engine setup:
85mm cp pistons
b18c1 block, golden eagle sleeves
carrillo rods
ed's racing p&p b16 head with supertech valves, valve springs and retainers
golden eagle intake manifold
gt4067 turbo
motec m4 ems
advertised specs
skunk2 turbo intake - 9.77mm lift, duration 230 at 1 mm
skunk2 turbo exhaust - 8.89 lift, duration 225 at 1mm
jun type 2 intake - 12.0mm lift, duration 266.6 at 1mm
skunk2 stage 1 exhaust - 10.9mm lift, duration 249 at 1mm
dyno 003 - skunk2 turbo camshafts
dyno 007 - jun type 2 intake, skunk2 stage 1 exhaust
engine shot:
Modified by GSC Motorsports at 12:44 PM 8/8/2005
Modified by GSC Motorsports at 12:49 PM 8/8/2005
Modified by GSC Motorsports at 12:58 PM 8/8/2005
Modified by GSC Motorsports at 2:34 PM 8/8/2005
engine setup:
85mm cp pistons
carrillo rods
gt4067 turbo
motec m4 ems
advertised specs
engine shot:
Re: How important are Camshafts on our Turbo Cars ??? (Bulldogg83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 »</TD></TR><TR><TD CLASS="quote">Damn James. Nice numbers. Good write up as well. </TD></TR></TABLE>
thanks - we are getting there - still a bit down from ultimately where we want to be but this really explains only trapping 138 mph in bristol, a little at a time we are figuring it out - we should have some fun again for once at NHRA Moroso
That must be the power you guys have been looking for lol! I wonder if there would be as signifigant gains on say a small bore GSR 81mm.
Good power though... see you guys at the track soon
chris
chris
Re: How important are Camshafts on our Turbo Cars ??? (Eluzion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eluzion »</TD></TR><TR><TD CLASS="quote">Very nice results. What kind of setup is this on?</TD></TR></TABLE>
updated in first post
Re: How important are Camshafts on our Turbo Cars ??? (GSC Motorsports)
that is a very good comparison...to bad I have the skunk2 turbo cams. That makes me want to cry haha.....I feel jipped
Re: How important are Camshafts on our Turbo Cars ??? (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">that is a very good comparison...to bad I have the skunk2 turbo cams. That makes me want to cry haha.....I feel jipped </TD></TR></TABLE>
from the research that i have done on them recently - they appear to work very well in relatively low hp cars up to say 20 psi and 400 whp - but then again i haven't seen anyone do any definitive testing on a lower hp application either so i am not 100% sure what i have learned about them is true.
James Innes
James Innes
Who is Mr Robot?
so would skunk2 stage2's offer more of an increase? i have noticed that the more overlap a turbo honda has the more power it seems to make..
hmmm, itr's or skunk2 stage 2's (already have the itr's tho)
Re: How important are Camshafts on our Turbo Cars ??? (wantboost)
Maybe this will put all the no overlap for turbo, jock the B16 cams for life, no aftermarket cams people to bed?
Awesome numbers!
Awesome numbers!
alright... lets see the REAL DYNO SHEETS, not the ones from 3 months ago
thanks for the info.
on my built d16 i plan to run either an exospeed race a6 or comparable cam. I dont care what people say about overlap, i think that the more air you can cram into that cylinder the better. If there proven to make more top end power NA, then why wouldnt they do just the same with boost?
Re: (B20T CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20T CRX »</TD></TR><TR><TD CLASS="quote">so are we going to see the car at Atco running low 10's or even some maybe 9's? </TD></TR></TABLE>
I'M JIM HUCKS BEYOTCH !!!!!
Re: How important are Camshafts on our Turbo Cars ??? Dyno Inside... (GSC Motorsports)
cool comparison for sure,
but it would be more informative comparison if you provided datalogs, especially of the boost. ive seen cars that will boost higher w/ just a cam change, even running off just the same wastegate spring, no boost controller.....
it also looks like the car bogs?
and id love to see what an oem cam, like ITR's would do against the others.
Re: How important are Camshafts on our Turbo Cars ??? Dyno Inside... (D0GMAN)
You tell me why it would pick up any boost AT ALL if he has the same target set in his motec with that massive HKS GT gate? We use that sucker to control boost on a friends Nova with a 406" small block and a 106mm turbo, I'm sure it has no problems holding exactly what he wants on a little 100 inch honda.
Re: How important are Camshafts on our Turbo Cars ??? Dyno Inside... (b16sedan)
THat is some AWESOME info! THanks for posting it up. What was the boost level?
well sup James it Donny from Rev Motorsports .. we order a few sett of your 272 cams for our evo 8s a few weeks back .. VERY NICE BUILD UP ... great number .. now slap on the slicks and see what kind of numbers you can clock ..
Donny @ Rev Motorsports
Re: How important are Camshafts on our Turbo Cars ??? Dyno Inside... (ValleySyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ValleySyder »</TD></TR><TR><TD CLASS="quote"> well sup James it Donny from Rev Motorsports .. we order a few sett of your 272 cams for our evo 8s a few weeks back .. VERY NICE BUILD UP ... great number .. now slap on the slicks and see what kind of numbers you can clock ..
Donny @ Rev Motorsports</TD></TR></TABLE>
and those cars sound mean as hell
Re: How important are Camshafts on our Turbo Cars ??? Dyno Inside... (N20civicB18)
Cool, hopefully I'll get to see it in action at moroso in a few weeks. Awesome gains!
