> Forced Induction
Old 11-04-2009, 01:41 AM   #21476
allmotorek8
allmotorek8's Avatar
Default Re: LST / LS-T Turbo B18A B18B setups
Originally Posted by Civic89stdB16 View Post
he has been on it for almost a year and is tuned by a local guy on Chrome Pro. The motor is a $200.00 junk yard motor too.
wow very nice. keep it up
vouches in bio
buy my stuff people lots of pics
http://hondamarketplace.com/zerothread?id=2362231 DC Squad Member #64 biotch
allmotorek8 is offline Report Post   Reply With Quote
Old 11-04-2009, 06:29 AM   #21477
Silva Bullit DC4
Silva Bullit DC4's Avatar
20psi isnt that much on a stock ls. my buddy is running 26psi on a totally stock b18a1 and it has stock head studs to. thats on a 57 trim. hes on 20psi on all 93 octane dailly. for the 26psi he adds 2 gallons of c16 to a half of tank of 93. That car went 11.5 at 121 in a 93 coupe full interior with cut springs. He can go faster if it will come out the hole better. U have to love the good old LS.
How much power is he making @ 26 psi with that 57 trim?
Precision Powered Stock Integra LS (304 whp @ 14psi)
'99 NBP TL (under VIP construction)
Shue Tuning / Adrenaline Autoworks
Silva Bullit DC4 is offline Report Post   Reply With Quote
Old 11-04-2009, 07:49 AM   #21478
inspecta83
Originally Posted by Turbo-LS View Post
What distributor are you running obd0 or obd1? from that statement it sounds like your running an obd0 with obd1 plugs LOL.
Must be nice ! lol
im running an obd0 distributor...i took the original obd1 distributor off the motor (its an obd1 LS motor) and swapped it with the obdo distributor that im using now. since im also using an obd0 engine wire harness, the distributor just plugs right into it....is this the correct setup?? or did i do something wrong? thanks...
inspecta83 is offline Report Post   Reply With Quote
Old 11-04-2009, 08:59 AM   #21479
Turbo-LS
Turbo-LS's Avatar
Send a message via AIM to Turbo-LS
Assuming your running an OBD1 ecu then no that is not correct. You need to run an OBD1 dizzy with obd1 plugs and obd1 ecu. if your running obd0 ecu then yes that is fine. sounds to me like your running an ecu that is obd1 though and thats your problem. please correct me if im wrong
Hondata, Crome Pro Tuning, Socketing
Originally Posted by Turbo-charged
My Weldon 2015 started working about 50% in the middle of a pass. 40lbs of boost, 3rd gear, and about a 16.5 AFR left my radiator looking like a taco.
Turbo-LS is offline Report Post   Reply With Quote
Old 11-04-2009, 10:17 AM   #21480
Civic89stdB16
Civic89stdB16's Avatar
have no idea because he refuses to go to the dyno. The car has been street tuned the hole way. The guy who tuned the ls will be tuning my b16 here some and we will be going to the dyno after we street tune for a little while so I dont have to rent the dyno for as long.
=============For Sale Thread Updated Daily=============
http://www.hondamarketplace.com/show....php?t=2645511
Civic89stdB16 is offline Report Post   Reply With Quote
Old 11-04-2009, 11:53 AM   #21481
Turbo-LS
Turbo-LS's Avatar
what has he ran for times and in what chassis?
Old 11-04-2009, 05:03 PM   #21482
Civic89stdB16
11.50 at 121 in a 93 coupe full interior and cut springs as posted above.
Old 11-04-2009, 05:11 PM   #21483
Turbo-LS
Turbo-LS's Avatar
so its putting down about 375ish, pretty damn good for stock LS, although i dont see how its not getting headlift with that kind of boost, its alittle hard to believe especially since even with small turbos 20 psi is about the max that can be ran and not experience headlift
Old 11-05-2009, 12:39 AM   #21484
v8killaz
v8killaz's Avatar
hey guys i am building a motor, b18b with internals
im looking for a turbo and stumbled across this one
would this be good for about 350-400whp. could i use it one my completly stock motor or no before my other one is built
http://www.xceedspeed.com/forums/sho...d.php?t=149780
1999 em1 for sale
http://www.xceedspeed.com/forums/sho...d.php?t=151225
v8killaz is offline Report Post   Reply With Quote
Old 11-05-2009, 04:34 AM   #21485
Turbo-LS
Turbo-LS's Avatar
Do not buy that turbo lol t4 is way to big for 400whp
Old 11-05-2009, 07:01 AM   #21486
inspecta83
Icon2 Re: LST / LS-T Turbo B18A B18B setups
ok, so i just got back from taking a look @ my car @ the shop..turns out i even confused myself about what i have...anyway, i do have an OBD 1 dizzy w/ OBD 1 plugs, OBD 1 ecu (with OBD 0 to OBD 1 plug and play conversion harness)...i think i'll probably end up buying a new OBD 1 dizzy just to rule this out as the culprit...any other suggestions as to what could be causing this problem??
just to refresh... all of a sudden since i changed my spark plugs and hooked up my water temp gauge, my car won't rev past 4k RPM (its like there's a rev limiter there) which by coincedence is where boost kicks in..i had this problem b4 but was able to get it to go away, even though i would get a CEL...now the CEL is on as soon as i turn the car on
Old 11-05-2009, 07:47 AM   #21487
Eli2
Eli2's Avatar
What spark plugs did you use? So basically it starts missing real bad when boost hits?
Eli2 is offline Report Post   Reply With Quote
Old 11-05-2009, 08:33 AM   #21488
Civic89stdB16
sometimes people just get a freak motor. this is one of them. I would never boost a car without arp head studs myself. It has stock head bolts because I pulled his valve cover off to see if he was lying.
Old 11-05-2009, 09:44 AM   #21489
v8killaz
v8killaz's Avatar
so hes using a completly stock motor, damn
lucky one
usually people have to build theirs to reach that high. i woudl love to see him hit 400 with some supportive mods, think that will be crazy
get some arp studs too lol
1999 em1 for sale
Old 11-05-2009, 10:29 AM   #21490
Turbo-LS
Turbo-LS's Avatar
Wait, what did you hook the water temp gauge up to?
Old 11-05-2009, 12:26 PM   #21491
inspecta83
it just won't rev past 4k, exactly like how a rev limiter would do...i just used regular NGK plugs, nothing fancy....
its an autometer water temp gauge and its wires are hooked up to an apparatus installed in the upper radiator hose...maybe the gauge and spark plug installs are coincedental to this problem reoccurring...
Old 11-05-2009, 01:31 PM   #21492
Turbo-LS
Turbo-LS's Avatar
ok just makign sure you didnt wire it to the oem water temp sensor, peopel have done that LOL
Old 11-05-2009, 07:08 PM   #21493
Eli2
Eli2's Avatar
Hmm did you gap them properly and such?
Old 11-05-2009, 09:07 PM   #21494
EGhatch87
EGhatch87's Avatar
Originally Posted by EGhatch87 View Post
here my set up...let me know what ya'll think or recommendation...
94 B18b motor 120k bone stock
LS Tranny
Turbo
Blox manifold
Preceision SC61
3' Down Pipe
38 TiAL Wastegate
2 1/2 IC Pipeing
rev hard FMIC
Vortech BOV
RC 550cc
Walbro 255
Comp Clutch Stage 4
hondata S300 with boost option
looking for 275-315hp
im hittin the dyno tomorrow moring...
EGhatch87 is offline Report Post   Reply With Quote
Old 11-06-2009, 01:57 AM   #21495
crxboy111
crxboy111's Avatar
Send a message via AIM to crxboy111
my car want ****in start =( im not getin no spark anyone might know what it is ?
crxboy111 is offline Report Post   Reply With Quote
Old 11-06-2009, 02:10 AM   #21496
v8killaz
v8killaz's Avatar
dizzy
ground
1999 em1 for sale
Old 11-06-2009, 02:11 AM   #21497
v8killaz
v8killaz's Avatar
how much power will it support
1999 em1 for sale
Old 11-06-2009, 04:53 AM   #21498
Turbo-LS
Turbo-LS's Avatar
its not that it will support alot of power, judging by the pic it seems to be a diesel turbo with a big exhaust and small compressor wheel in a big housing. its junk dont buy it. T4 inlet turbo is just way to big and not nessesary and will be very laggy on an LS motor only trying to make 400hp. you dont just buy any old turbo you buy one that is suited to the build for best performance and spooling characteristics
for a 400whp car you would be better off with a 57 trim or 60 trim or a gt3076 or a turbo from the borgwarner family. also there t3/60-1 or t3/62-1 on an sc34. lots of options out there for a 400whp build that would work very well
Old 11-06-2009, 10:25 AM   #21499
v8killaz
v8killaz's Avatar
ok thx alot thats what i htought it was from a deisel car
i was just asking because it seemed some people were running some similar sizes
ok should i uprgade pistons and rods or both, becaus eim just wanting to hit the 359whp barrior. and dont want to sepdn too much imm poor and i hav e a cast log mani which wont do too good
1999 em1 for sale
Old 11-06-2009, 10:48 AM   #21500
crxboy111
crxboy111's Avatar
when the motor was in the da i didn't touch it at all all i did was take it out and put it in the rex.do you think the dizzy, just took a shit on me>?
Bookmarks
b18, b18a, b18b, good, honda, hondata, hp, ls, lsturbo, manifold, meutek, motor, specs, stock, turbo
