#1 | |||||
91 Civic Sedan |
#2 |
H-T Order of Merit
What are you going to do with the IACV?
God Mess This Bless. |
#3 |
I have heard that their SOHC manifolds can be a bitch to install because the flanges aren't flat, but thats what I've heard I have no proof. That sensor on the runner is the MAP sensor and will work any where it will fit as long as it sees a good crisp signal. Th brake booster will work on the back of the plenum but you need the proper fitting that will thread in. The largest hole should be used for the brake booster. I don't know how well this manifold will work because they probably put $5 into the R&D. It should make more power than the stock manifold but the flow between individual runners probably won't be as balanced as with the OEM manifold.
good luck! |
#4 |
friend had the obx manifold on his sohc for a month then the welds broke around the peleneum also it was boosted....
#5 | |
King Tut 2009 BMW M3 Coupe: e92.civichatch.com 1987 BMW 325is Coupe: Spec E30 Build |
#6 |
1997 Honda Civic |
Main things I see missing missing are: provisions for throttle cable, IACV, and IAT sensor. It also looks like you'll need to add some sort of nipple for the coolant passage on the passenger side of the flange. Assuming the bolt/stud pattern for the fuel rail is correct, the rest of the issues will be with tapping for all the vac sources you'd need, beyond the ones that are already tapped.
97 Civic with some stuff |
#7 |
thats not the map on the runner, thats the IAT (intake Air Temp) the map is usually on the throotle body or the fire wall.Just thought i would clear that up
1989 RT4WD civic wagon in the works |
#8 | |
#9 | |
also, you will need a throttle cable bracket welded onto the bottom of the manifold, or else, you can use a gsr throttle cable/bracket. |
#10 |
Yea. My main concern is the iacv. The iat will probably be simpl. I just need to make sure there are no leaks. I am not too worried about the throttle cable. I already have it rigged up in a way that it has no association with the intake plenum. Thanks for all the good advice. Keep it coming.
91 Civic Sedan |
#11 | |
thanks |
#12 |
those manifolads are a joke!
Intense Motorsports 704 537-0054 Dyno Tuning and Performance Specialists |
#13 |
Guest
Posts: n/a
word of advise...throw it away.
#14 |
why throw it away?? has anyone done testing on them to see if they made power?
http://www.Fab-Works.com http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif Custom turbo manifolds, Downpipe, IC pipings, Dumptubes. All your custom welding needs. Michael Nguyen Fab-Works Owner http://www.efi101.com http://images.honda-tech.com/set1/smile/emthup.gif |
#15 |
im in the middle of installing the same piece of junk OBX manifold on my H22 prelude, really should have thrown it away but i decided to make it work. anyways heres problems ive had to deal with...
-same IACV problem, i just drilled and tapped the two holes on the IACV and i plan on simply hooking them up to vacuum. -got the flange on the manifold surfaced ($40) at a local machine shop. -rigged the throttle cable bracket to one of the studs that holds the fuel rail on. -a few "T" connections for vacuum hookups -oh yeah, had to say peace out to the fast idle valve on the throttle body because it wouldnt clear the rear engine mount with the new position of the manifold. i figured since aftermarket throttle bodies didnt hasve them they werent 100% manditory but i guess ill find out for sure. -IAT sensor, planning on tapping the charge pipe for this as it will be the easiest fix and honda IAT's are so inaccurate anyway. tried to start the car today with everything hooked up except for the IACV vacuum sources and of course the fast idle valve and my prelude started and just wouldnt idle, then died out pretty quickly. i have a feeling though that the IACV may fix this. ill post more after working on it tomorrow... |
#16 |
Phuck that...
You get what you pay for... my buddy's leaked. Me= "told ya so" |
#17 |
All I seem to hear is how bad obx sucks. I know that OBX is a step up from ssauto... I guess im just the guiena pig. I am buying this to see for myself if it was a wise investment.
91 Civic Sedan |
#18 | |
sorry I couldn't help it.
2000 Gs-R Powered by Honda...pushed by Precision -=-=-=-=-=-=-=-=-=-==-=-=-=-=- DC Squad Member # 0221 |
#19 |
should of got a blox or skunk2
b00sted ls/vtec baby http://images.honda-tech.com/set1/smile/emthup.gif |
#20 |
it seems like obx made the manifold with weak welds to mimick 2 fast 2 furious or was it fast and furious, which ever same movie
Garage Park 1995 Nissan 240SX 1999 Prelude Turbo 2006 Acura TL - Navigation http://www.honda-tech.com/zerothread/1673078 5th Gen Engine bay shave |
#21 |
Better than steak
<FONT SIZE="5"><FONT COLOR="red">DANGER TO MANIFOLD!!</FONT></FONT>
10.006@150mph T1 Race Development -Competition Clutch -Full-Race Motorsports Don't call it a comeback... |
#22 | |
#23 | |
as for buying a blox or skunk2, which im guessing are in the $400-$500+ range, i wont do it. the obx manifold sucks, but its nothing more than a copy of the venom design which isnt that bad. with my mods and the price of the manifold i spent less than $250. half the price. sure it has been a bitch to install but its a MUCH better manifold for boost than the s2 or blox mani. just more people jumping on a certain hater bandwagon. |
#24 | |
1997 Honda Civic |
#25 |
Do I really have to get the manifold surfaced? It wont sit flush with the head or something? I find that hard to believe. The quality cant be that poor. I guess I will find out the hard way. Hopefully when I recieve it, i will clear up alot of confusion and rumors. Maybe the manifold isn't as poor quality as many people think, or maybe it is. There is apearantly a bias againt obx. People DO seem to jump the hate-band wagon just cause everyone else does, or they heard a story from a friend of a friend. Others complain about the manifold being poor quality due to the difficulty to install. As for the welds breaking, it is an intake manifold" it is not put through the same stress as a turbo manifold. I am very skepticle about the welds breaking. This manifold is basically a copy of the venom manifold. The desighn is rather simple. Four equal length runners on a box. I dont think it can be screwed up that bad. I guess I will have to wait and see.
Keep posting. Maybe someone out there has something GOOD to say about this manifold. Thanks for the feedback. I will post any updates in this thread.
91 Civic Sedan |
| Bookmarks |
| Tags |
| 0221, 92, civic, honda, iac, install, intake, manifold, manifolds, obx, prelude, racing, si, sports, style, venom |
