> Honda Accord (1990 - 2002)
Old 06-22-2005, 12:33 PM   #26
deserthonda
deserthonda's Avatar
Default Re: 1997 Accord Brakes Tutorial (ramoneguru)
i also think it is a 10mm socket 12 points...
deserthonda is offline Report Post   Reply With Quote
Old 06-22-2005, 01:57 PM   #27
ramoneguru
ramoneguru's Avatar
Default Re: 1997 Accord Brakes Tutorial (deserthonda)
Almost, 12mm 12 point (I didn't check if the 10mm fit though, so you might be correct). Craftsman has them for about $12.....I probably should have just purchased the package and saved a few dollars....
ramoneguru is offline Report Post   Reply With Quote
Old 06-23-2005, 01:10 PM   #28
JDM MonopolyMan
JDM MonopolyMan's Avatar
Send a message via AIM to JDM MonopolyMan
Good article!! It helps alot when I was just about to turn my own rotors although I had no idea where to start due to them being pressed on. thanks!
JDM MonopolyMan is offline Report Post   Reply With Quote
Old 06-29-2005, 11:07 AM   #29
pumafeet10
pumafeet10's Avatar
Send a message via AIM to pumafeet10
are there any other tools you need to buy when u get the puller, it says you needsomething elese but i think its just a slide hammer im guessing thats not needed?
NO MAS Accord
now 00 Hatchy" The Lobsta"
let the madness begin
pumafeet10 is offline Report Post   Reply With Quote
Old 05-16-2006, 07:56 PM   #30
gianinline
gianinline's Avatar
very nice of you taking your time to take pics and post all the info and stuff....
Very Good!!!
CD squad #016
"it is dangerous to be right when the government is wrong" (Voltaire)
gianinline is offline Report Post   Reply With Quote
Old 06-07-2006, 08:14 AM   #31
accordisslow
accordisslow's Avatar
my question is ...on step 11-13 is the spindel nut suppose to stay on while useing the hub puller? because i tried that and ...i kinda effd up the threads on my hub puller ( actually a rental)....i mean i took all 4 bolts on the back side of it and i thought it would jus simple come off.....
what i am tryin to do..is apply new wheel bearings and new rotors...but i cant seem to get the damn rotors off..
For Sale:
1994 Accord 2.2 LX
149k miles http://www.honda-tech.com/zerothread?id=1698425
http://www.cardomain.com/ride/2107647
For Sale: TYC Altezza Taillights Euro Red Mint! 70 Shipped obo email me Accordisslow@gmail.com
accordisslow is offline Report Post   Reply With Quote
Old 06-07-2006, 08:24 AM   #32
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: 1997 Accord Brakes Tutorial (accordisslow)
You can have it on there to protect the threads of the axle but don't have it tightened or snugged down or anything. The nut tightens down onto the hub, if the nut is toughing the hub while you're doing this, then you're just doing nothing. Maybe try taking the nut off or just make sure it isn't touching the hub face (where it tightens down to) while you're doing this.
TouringAccord is offline Report Post   Reply With Quote
Old 06-07-2006, 08:31 AM   #33
accordisslow
Default Re: 1997 Accord Brakes Tutorial (TouringAccord)
i did that.....what i first did was put the hub puller on there and tightned it down with out the spindel nut and all it did was back the axle out Lol so then i partially threaded down the spindel nut maybe like 2 spins but it still wont pull out (the rotors!) i even tried givin the rotors a few smacks wit the hammer so the rust can losen up a little bit and still no luck .....is it suppose to b dificult to tighten down the hub puller? cuz honestly....i even tried standin on the ratchet and still no lucck lol
is there any other tool i can use to see if it will come off? like a slide hammer or something of the sort?
For Sale:
1994 Accord 2.2 LX
Old 06-07-2006, 09:30 AM   #34
TouringAccord
H-T Order of Merit
well, I personally don't know how that hub puller works since it's pushing on the axle which is just going to push out before the bearing comes free but some people say it works so... On my Accord, I had the bearing unbolted and then I hooked a slide hammer to the hub and I ended up pulling the hub out of the bearing, thats how rusted my bearing was into the knuckle. I had to take the knuckle to a shop and they had to use a press to free the bearing from the knuckle.
As long as you have the bearing unbolted from behind the knuckle, try hitting it with a hammer, if that doesn't work you can try the slide hammer. Just be careful to not pull the hub out of the bearing cause if you do the bearing should then be replaced.
I don't know what else to tell you. If your in a state that see snowy weather (road salts and such) it could just be really rusted in there.
Old 06-07-2006, 10:09 AM   #35
jmk64
jmk64's Avatar
I live in Michigan too, and my hub was froze into the knuckle. I used a hub puller and managed to seperate the hub from the bearing (really pissed me off). After working on it for 2 days I got the passenger side back together (LOL). I took the car in and had the drivers side done.
When I seperated the bearing from the hub it came apart nice and easy and I didn't break the race or tear the seal so I just cleaned it up put a little grease on the shaft and bearing and gently inserted it back into bearing. I used the Hub nut to press it back together. Seems to be okay, my mechanic said that I got lucky.
He used a slide hammer to remove the other side.
http://images.honda-tech.com/set1/smile/emsmile.gif
1997 Accord LX V6
1998 Chevy Venture "Wagon Queen Family Truckster"
jmk64 is offline Report Post   Reply With Quote
Old 06-07-2006, 10:31 AM   #36
TouringAccord
H-T Order of Merit
Default Re: 1997 Accord Brakes Tutorial (jmk64)
yeah, my hubs came out of the bearing without any noticable damage to the bearing. But they recommend that if you seperate it and expose the inside of the bearing, you should replace it. I didn't want to have to go back in and fix it in a few months so I just bought new bearing so I didn't have to worry about it. I've heard of others just pulling the hub with a slide hammer and then reinserting the hub into the bearing but I didn't feel like taking the chance, my luck something would have gone wrong and I would have had to take it all back apart.
Old 06-07-2006, 12:10 PM   #37
technine
technine's Avatar
Very good write up. Very clear and to the point.
"... sell crack for the image...not the money"
Originally Posted by shamoo
***WARNING*** Those denying the existence of ninjas may indeed be ninjas themselves http://images.honda-tech.com/set1/smile/emsmileo.gif
"Plastic turns to bills in thirty days"
technine is offline Report Post   Reply With Quote
Old 08-04-2006, 11:10 PM   #38
spooky187
spooky187's Avatar
Default Re: 1997 Accord Brakes Tutorial (technine)
I have two questions, the first one is more important!
I have an acura 2.2cl 97'. The setup for this exactly the same, but i am having trouble getting the spindle nut off. Do you go counter clockwise or clockwise? from the Tutorial i would assume its clockwise, but i wanted to make sure, cause im still having trouble. ( from the tutorial it says take off spindle "bolt" in step 6, and then in step 7 it says take off spindle "Nut" , so does that mean take out the grey middle bolt out of the middle before using the big torque bar on the spindle "nut")
Also if its possible, do you guys know anything about the conversion of using the newer hubs on a 98-99 2.3cl acura, so you don't have the hub over rotor?
I have two 2.3cl acura 98' hub assembly, but i don't see how it makes anything easier. Thanks in advanced!
spooky187 is offline Report Post   Reply With Quote
Old 09-09-2006, 05:16 AM   #39
BigMoose
BigMoose's Avatar
Default Re: 1997 Accord Brakes Tutorial (spooky187)
I know it's an old but good thread. Have to do this on my 96 Accord. Here is a Wagner brake tutorial on the air chisel method of getting the bearing housing out of the knuckle.
http://www.federal-mogul.com/f...nt%22
I am also not understanding how the hub puller works. It has to be compressing the drive axle and putting the force into the transmission. I don't think I want to put a lot of axial load into the axle joints with a rusted bearing housing in the knuckle. If I am missing something, let me know.
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..."
BigMoose is offline Report Post   Reply With Quote
Old 09-09-2006, 10:41 AM   #40
Intense3.2
Send a message via AIM to Intense3.2
Default Re: (fuglycord)
Very nice! An asset to HT.
Intense3.2 is offline Report Post   Reply With Quote
Old 09-10-2006, 09:56 AM   #41
jmk64
jmk64's Avatar
Default Re: (Intense2.2 _Y.T.S._)
I found this the other day, and I thought it would be nice to add it to this thread.
http://www.try-intools.com/
It's kinda pricey, but it looks heavy duty.
1997 Accord LX V6
Old 09-10-2006, 07:12 PM   #42
thedarkone
thedarkone's Avatar
Send a message via AIM to thedarkone
I wish it were that easy for NY accords damn salt and rust! Nothing like a good blister inducing slide hammer session to brighten your day... good thing we had a lift and a good team of strong arms. lol
thedarkone is offline Report Post   Reply With Quote
Old 09-11-2006, 06:45 AM   #43
TouringAccord
H-T Order of Merit
Default Re: (jmk64)
I personally wouldn't buy that tool. Not because of the cost but because of what it does.
It removes the hub from bearing which it's then recommended that you replace the bearing. I know I know, many people have gotten away without doing so but there are some that have experienced problems. It's not recommend because if any dirt or anything gets inside the bearing your screwed, or if you don't get the hub back into the bearing all the way you'll have problems as well. Then a month later or somethng you'd be back in there to replace the bearing, which means you would need a press to get the race off of the hub and to have the new bearing and hub pressed together.
Not worth it in my mind. I would rather go through the extra steps to ensure not damaging the bearing.
Or you could take the money you would spend on that tool and put it towards a Rotor-over-Hub conversion. Which is my plan for when I get my next Accord.
Old 09-11-2006, 07:06 AM   #44
nist7
nist7's Avatar
what if I cannot take off the spindle nut? (driver's side)
I even used an electric imapct wrench (350ft-lbs) and the nut isn't even budging....
nist7 is offline Report Post   Reply With Quote
Old 09-11-2006, 07:39 AM   #45
TouringAccord
H-T Order of Merit
Default Re: (nist7)
it needs to come off or you can't do the job.
an electric impact? Are you sure it wasn't 350in-lb? I think all the electric impacts I've seen were in-lb but that doesn't mean yours isn't ft-lb, just want to make sure.
To get mine off, without air tools, I always leave the car on the ground (just remove the center cap to get access to the axle nut. I use a 1/2" drive rachet or breaker bar and a 5ft long steel pipe. Works great for me.
If that doesn't work, see if you can find someone with heavy duty air tools or someone with a 3/4" rachet/breaker bar and the correct size socket.
One time I had a problem with my driver side axle nut as well. I kept breaking 1/2" drive rachets and breaker bars. I was using the aluminum 2pc handle from my low profile jack, then I tried a steel pipe and the nut broke free on the first try no problem. Ever since then I always use a steel pipe and haven't had any problems. I assume the aluminum 2pc pipe flexed too much or something causing the problem, IDK... I just use a steel pipe now and no problems.
Old 10-29-2006, 05:44 AM   #46
doctoroctopus
doctoroctopus's Avatar
Default Re: (TouringAccord)
New to the site. I just want to change the pads and rotors, regrease the pins and get out of there. Can I get the rotor off the hub without removing the hub and all that. There's just that little lip keeping the rotor from coming off. Is this unique to Honda's ? Thanks, DO
doctoroctopus is offline Report Post   Reply With Quote
Old 10-30-2006, 04:03 PM   #47
ujhonda
ujhonda's Avatar
Default Re: 1997 Accord Brakes Tutorial (rudeman85)
ramoneguru:
Ohh my friend, I can't thank enough, Helms Manual inc. must hire you.
Nice job, indeed it is nice.
once I had to take my rotters off, but I failed - due to tools, finally local Midas did it - cost my arm and leg. but next time.
ujhonda
2000 Accord SE - A/T - everything stock
I salute all good Techies on HondaTech.Com http://images.honda-tech.com/set1/smile/emthup.gif
ujhonda is offline Report Post   Reply With Quote
Old 11-26-2006, 12:41 PM   #48
SPORT INJECTION
1990 Honda Civic
SPORT INJECTION's Avatar
I could have used this write a day or two ago. ive been going nuts trying to figure out how to get these rotors off.... ahhhh so much easier on the civic.
///FGMTeam Lazy
90 Civic Si
96 Accord Wagon
SPORT INJECTION is offline Report Post   Reply With Quote
Old 11-26-2006, 07:43 PM   #49
lilman4o8
lilman4o8's Avatar
Send a message via AIM to lilman4o8
i'll be sure to save this thread
NOR * CAL
lilman4o8 is offline Report Post   Reply With Quote
Old 03-17-2007, 02:56 PM   #50
soon2bdropped
soon2bdropped's Avatar
Default Re: (lilman4o8)
kinda confused.. ive seen people change rotors like its nothing. you guys make it seem like its a hassle.. i always thought u undo the 2 bolt on the caliper slam in new brake pads.. than undo the 4 bolts in the front of the hub.. hub slides off and rotor slides off and just leave the bearings in there with the wheel studs.. idunno i want to try it this summer but i don't know.. hub, bearing, all confuses me...
Vouches : Frank_2.0L
soon2bdropped is offline Report Post   Reply With Quote
Bookmarks
1997, 92, 97, accord, front, honda, hub, lug, nut, puller, removal, remove, rotor, rotors, tech, torque
