| New! Use your Facebook to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendor Directory | My Recent Topics | My Notes | Used Cars |
#1 | |
*** Update as of Nov. 18th *** The Del Sol is mothballed until I can re-focus on the project. I was finding it hard to keep motivated - too many false restarts, and difficulty building the momentum required to complete it. This is by no means the end of the project, it will be back and hopefully better than before. I have appreciated everyone's continued interest and kind words. -Scott --------------------------------------------------------------------------------- Index: Page 2) Transmission cable link assembly Page 4) Scoop design - molds - Carbon fibre prototype Page 6) Monster radiator mock-up, Turbo block, twin engine mock-up, wiring harness start Page 10) Rear engine removal, rear engine bay temporary firewall Page 14) Riced out and Rollin' Page 16) Dual Engine Math - Warning those with ADD might stop reading here (I am also not liable for any brain trauma that may result) Page 19) Brake Booster Kung-Fu - The "Legend" continues Page 25) Back to work - Twin H's on the way! Page 29) Caged in - Roll bar construction begins instead Page 30) Simple swap - Front motor in, fuel and coolant lines on Page 32 & 34) Rice removal - 4 wheel 5 lug conversion finished, turbo manifold production begins here and completes here Page 35) Sump'n new - fuel tank modification Page 38) Twin H22's - final fab begins, down-pipe and exhaust Page 39) Shifty business - new shifter, solid linkages Page 40) Rear Mount Intercooler and Air box Page 41) RMIC - Charge pipes Hello all! I wanted to share my Mid engine Del Sol project car with the H-T community. I've spent countless hours reading threads (mostly for technical info) on here I thought I might as well give something back. Any questions or comments would be appreciated. Project Beginnings Since the first time I read about the Top Fuel Del Sol featured in Superstreet magazine I was fascinated by the rear engine swap. I had recently purchased a Del Sol and was preparing to put a turbo H22 motor under the hood. Preparation took over a year but in May 2004 I swapped out the D16Z6 for my fully built, turbocharged H22a4. The car hauled ass, but tuning, traction and suspension issues left much to be desired. So beginning in July I started researching the RWD swap, mainly because I wanted something different than the thousands of other boosted hondas, and because I love the feel of mid/rear engine platforms. Unfortunately I found little information regarding the rear suspension of the Top Fuel Sol. Originally I was interested in the CRV rear setup, but was unconvinced it would work.. which is when I stumbled upon Cody's (Tinker219) RWD Del sol project. I was struck by the pure brilliance of it! Cody used the front suspension from a 92-95 civic, and a extensive tube frame to mount the engine rearward. Along with Dave's (RaceCity_USA) Mid engine Integra GSR I was inspired to do more with my own vehicle using an amalgamation of the two principles. I should note that I have the utmost admiration and respect for both other mid engine RWD projects. My own project was in no means meant to duplicate their exact process or results. I delayed releasing any information regarding my own project until now out of respect for the work which Dave (RaceCity_USA) has been doing on an on-going basis since August 2004 - A true testament to his inginuity, knowledge and dedication to the project. At the end of October 2004 I commenced my own Mid engine project. Engine pulled for rebuild ![]() Here is the donor vehicle 1993 Civic DX Hatchback Well.. at least the front half (October 31st 2004)![]() Since I wished to use the frame from the civic instead of a tubeframe; I started tacking supports to the inside of the bay so nothing would shift once I started trimming it down to fit. ![]() For every hour I've spend in my tiny (12'x 20' ish) garage on this, I've probably spent a good 3 hours thinking on my next move. The hardest part of this project thus far was the frame itself. Of the many issues to consider before starting, the three major ones were track,wheelbase and alignment of the rear suspension and frame. I decided the first order of business was to level the car with jacks and build a jig.(November 8th 2004) ![]() ![]() I'm still looking for the pictures of cutting the Del sol trunk to peices, I will post them when I find them. At any rate it was the point of no return. Once cutting was complete on both donor and Sol, I dropped donor suspension under the body and started to align it using the jig and measurements from the front Del Sol suspension. Having identical suspensions was key to having the proper frame position. Floor to cross member heights, floor to frame heights everything was measured and matched at the rear of the car.(December 11th 2004) ![]() Pic of boxing up the frame rails with 1/4 inch mild steel plate (January 6th 2005) ![]() ![]() ![]() Because the outer frame rail (what the fender mounts to) was cut from the donor suspension I decided to beef up the strut towers by tying it into the del sol. I'm glad I did too, upon welding to it I discovered how thin they really are It made for a very long night of very slow work. Without this added support I am certain it would buckle.(January 25th 2005)![]() ![]() ![]() Heres a better view of the jig once the car was moveable. (February 12th 2005) ![]() Type R hub conversion with brembo slotted rotors ![]() Sheet metal and frame work (no specific date) ![]() ![]() Finally the engine is in May 16th 2005! (This is my mock up engine) ![]() ![]() Thanks for looking! This is far from the finished product, much more to come! -Scott P.
- - - Gemini Project: TWIN H22 POWERED AWD DEL SOL - - - - - - Honda Beat Project: B16 Turbo - - - Last edited by WhiteSol; 11-18-2009 at 04:51 PM. |
#2 |
im very impressed.
i like how u made the rear stut towers look alot better. but, i do notice aot of open holes on ur engine. oh, and for working in the snow u deserve a
ACT B series clutch & flywheel and QSD EF/DA H2B kit all new 4 sale: http://www.hondamarketplace.com/show...6#post43436456 |
#3 |
I love these types of projects. Can't wait to see the outcome.
インテグラ タイプR 98-0425 |
#4 | |
The actual built motor will be back from the builder very shortly Here is a few pics of a side scoop I had in mind for the rear engine. Still not certain if I will use this or make something from CF instead. Either way its bolt on at the moment and easily removable if I change my mind ![]() ![]() ![]() ![]() Thanks for your comments! -Scott
- - - Gemini Project: TWIN H22 POWERED AWD DEL SOL - - - - - - Honda Beat Project: B16 Turbo - - - |
#5 |
Awesome!
- 2007 Honda Civic Si (FA5) Tafetta White - 2007 Honda Oyssey EX-L Tafetta White - 1995 Honda DelSol VTEC (EG2) GBP Spoon Sports Certified #00923 |
#6 |
i give you lots of credit for your time and effort..
from me!!
Taking a break.. DPK* X ATS -Originality at it's finest, until others follow.. WTB: 1st Gen Spoon Rear Tow Hook with "Spoon" Insignia |
#7 |
oooh, cool.
that scoop is nice too, creative. i dont know if u like this idea but the one on the older mr2's is nice. (the scoop that they have come out from the back up and over the side, on the driver's side) now of course, this carbon fiber u talk about is always a nice touch.
#8 |
wow....that is one crazy piece of work. Good job on doing all that, can't wait to see more updates on this
Garage Sale! Comptech, J's Racing, Mugen, Spoon, HKS, etc http://www.hondamarketplace.com/show....php?t=2442844 |
#9 | |
Human salvation lies in the hands of the creatively maladjusted. 2001 Pontiac Montana (cage) 1989 Suzuki Katana 750 |
#10 |
Nice. That's alot like the set-up we used building the CR-NSX!
NICE WORK!!!![]()
Mahdavi Motorsports 5395 Hwy. 29 LILBURN, GA 30047 770-923-1550 http://www.mahdavimotorsports.com 2005 NDRA TURBO 6 CHAMPIONS 2005 FORD 5.0 KING OF STREET Home of the 1 & ONLY.... CR-NSX |
#11 |
damn an H22T, mid engine del sol.... a CRNSX, damn whats next... wait i dont want to know... now i feel slower then hell..
#12 |
holy hell that thing is crazy.
that thing will be an eye catcher well done keep up the great work
10.73@133 on 14psi DD 2600lbs bitches!!! PY ITR #01-0604 Built motor on the way!! Soon to be in the 9's!!!! http://www.speedfactoryracing.net/ for all your go fast needs |
#13 | |
mahdavimotorsports,
That CR-NSX blows my mind!! Good to see it can be done! I was very interested in the NSX subframe and suspension also, however the cost of getting it would have put my project budget past my means . Great project, keep up the innovation!Quote:
I'll post more pics today of the intake tube and scoop, shift mechanism and ebrake mechanism if I get time to mount them. Thank you everyone for your enthusiasm!
#14 |
Just curious though... when the suspension and frame are complete and you remove the car from the jig... is it going to sit higher/lower on either the front or back? It would be really cool if it turned out to look completly stock from the outside and then see it do some insane drifts. That will drift nicely!
#15 |
very nice keep us posted cant wait to see more!!!!
Im Loved By Some, Hated By Many, Envied By Most, But Wanted By Plenty!*~*! good sellers: gsronthebottle, boostedsol,timmay,ben@importparts.com, flamenco-t, mr. wu, nolimitmotorsport.com |
#16 |
More info on the CRX/NSX, please
#17 | |
As for being able to drift, anything is possible ![]() Today's progress pics - Intake tube for side scoop ![]() ![]() Shifter assembly (inverted the second shifter, added adjustment bolt) ![]() ![]() ![]() Dual wilwood compact remote master cylinders mounted to single piece of 3/16" plate steel. Slides and balance bar control movement when compressed by the ebrake cable. These are the .750" bore cylinders and should be able to lock the rear brakes quite easily Originally I was attempting to use the NSX rear caliper (mechanical vs hydraulic), however it turned out to be too much work. ![]() Cheers, Scott
#18 |
nice, it seems like ur moving fast on this... how long have u been working on it so far? and do u have a guess as to when it will be driveable?
#19 | |
I try to get roughly 3-4 hours per night, 4-5 nights a week. I managed to get a solid 12 hours of work in today, spent 2 hours trying to get the paper thin metal inside the gas filler hole looking a little better; very frustrating . You'd think honda would make a section that oxidizes so easily a little thicker..I'm aiming for mid july to have it running, seems like a lot of work left but its coming along. ![]()
#20 |
wow, another one. now i want one
#21 |
Awesome looking project man. Can't wait to see the finish project. The time and effort get two huge :thumbsup: from me.
#22 |
subscribeeeeeeeeeeeeeee
marijuana: helping us learn the metric system one gram at a time. AP2 '05 SSM, cf ht. |
#23 |
Holy crap.... you're out of your mind!!!
.....show me more!!! :D
Flickr |
#24 |
wow
:sigh: |
#25 |
wow this is awesome!!!
-3rd gen honda crx link to my car: >> _/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/ i luv 8200 rpms _/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/ |
| Bookmarks |
| Tags |
| 80, cell, civic, del, engine, fuel, h22, honda, hondas, mid, pages, project, reports, sol, turbo |
