> Forced Induction
Old 04-30-2005, 10:13 AM   #26
Speed PHreak
Speed PHreak's Avatar
Send a message via AIM to Speed PHreak
Default Re: (soon2brb240)
I hope that you plan on tuning that setup very well and even then I wouldn't try pushing 12psi all the time on a bone stock engine. From the looks of your parts list you're trying to fab up a homebrew-ish turbo kit. The HX35 is equivalent flow-wise to a T61, 62-1, ect ect. It makes big power numbers, upawrds up 600hp. Since I don't see any forged internals in your setup I'd recommend going with an HX30, it's much more stock engine friendly. Especially seeing how you have a 91 intergra that most likey has over 150k miles on it. The HX30 spools very fast and puts out the same power as a mid-sized t3/t4 turbo.
~~~ 88 CRX HF~~~
. . . .Death trap. . . .
Speed PHreak is offline Report Post   Reply With Quote
Old 04-30-2005, 10:24 AM   #27
rhd
Send a message via AIM to rhd
hey stevie...joey talked me into an hy for my GTi-R...what ya thinK?
rhd is offline Report Post   Reply With Quote
Old 04-30-2005, 10:27 AM   #28
Speed PHreak
Default Re: (rhd)
Hellz yea dude. Bastid spools nasty fast from what I've heard, makes the power too. GTi-R eh, when did you pick that up?
~~~ 88 CRX HF~~~
Old 04-30-2005, 10:33 AM   #29
rhd
should get it tommorrow
has some wiring issues....but nothing a nerd like joey can't help me figure out
bidding on one right now (hy) what should i limit myself to spending?
Old 04-30-2005, 10:39 AM   #30
Speed PHreak
Default Re: (rhd)
HY? I wouldn't go over 350~400 for a new/reman something used and good conidition I wouldn't go over 200~250.
~~~ 88 CRX HF~~~
Old 04-30-2005, 10:42 AM   #31
rhd
werd
Old 04-30-2005, 10:49 AM   #32
soon2brb240
soon2brb240's Avatar
Send a message via AIM to soon2brb240
Well, actually, I just rolled over 106k on my car. And yes, I will be tuned, xenocron is being really helpful with that...but thats not even my question or concern, I know the limits of LS's. I was just wondering if the HY will be able to do 300whp with a nice solid tune. Also, if anybody wants to purchase one of these turbos you could contact ht member b18bturbo, he's got a source for these, and his prices are great!
soon2brb240 is offline Report Post   Reply With Quote
Old 04-30-2005, 11:10 AM   #33
Speed PHreak
The HX35 and the HY35 both have the same compressor wheel/housing, just different exhuast turbines/housings. Both will make 300whp with ease.
~~~ 88 CRX HF~~~
Old 04-30-2005, 11:14 AM   #34
soon2brb240
Great, thats what I thought, just wanted to hear someone else say it I guess...haha. Think I would have to go to a diesel aftermarket store to find a flange for the hy if it doesn't come with one? I need to make up my downpipe and I know the hx uses a v-band, but from what I've seen, the hy doesen't. Also, are the hx and hy oil and drain fittings the same?
Old 04-30-2005, 01:35 PM   #35
Speed PHreak
AFAIK the HY35 uses the stadard T3 flange just like the HX35, any T3 manifold will bolt up to it. They both uses the regular T3 styles oil drain flange.
However the HX and HY compressors are almost 9" in diameter at thier widest points....That makes it a bit difficult to get proper fitment. You are going to have to do some radical modifications to the front of your car to fit the turbo and I strongly doubt that your choosen turbo manifold will angle the HX/HY properly. You'll be hitting the block with the turbo. I have a shitty SSAC manifold on my setup, I ended up rotating the turbo flange around 30 degrees just to make clearances.
My CRX front end and your Integra share a alot of similarities in design under the hood. You will most likely loose your A/C if you haven't gotten rid of it already. Since you've got a DA chassis you'll prolly have to get a new front cross-member to have any room to route a downpipe(especially a 3") and a 1/2 width radiator...those items are a minimum.
~~~ 88 CRX HF~~~
Old 04-30-2005, 02:38 PM   #36
drumking15
drumking15's Avatar
Send a message via AIM to drumking15
to make mine fit in a teg...had to chop my ac bracket in half....and im runnin a nuekin mani and it fits in there pretty nice...
some nics pics of a holset snail
OEP 4 Life...no other way to be http://images.honda-tech.com/set1/smile/emthup.gif
drumking15 is offline Report Post   Reply With Quote
Old 04-30-2005, 02:41 PM   #37
soon2brb240
Well, it is true that our cars have many similarities, but since you've got a b swapped into your crx there is significantly less room than in an integra engine bay. My friend has a b16 swapped EF and i've got easily twice the room from the front of my motor to the radiator than he does. And you are correct about the AC, its coming off. My BMCrace manifold places the turbo at kind of a "forward angle" so i'll see if its enough. I'll post everything once its done. I'll definitly come back to this thread if i've got any problems when i'm putting it together. Thanks for everyones support!
Old 04-30-2005, 02:43 PM   #38
drumking15
drumking15's Avatar
im just gald everyone is seeing what i saw about 6 months ago....a good turbo not used by everyone...me and friends predicted this will soon become the poor man's bandwagon heh
Old 04-30-2005, 02:44 PM   #39
soon2brb240
Well, since I am poor, and this is HT, a new bandwagon is in the making!!
Old 04-30-2005, 11:50 PM   #40
imthedude
imthedude's Avatar
Send a message via AIM to imthedude
Default Re: (rhd)
heres mine when i had it on
the holset is on my friends supra now.
boost would be nice http://images.honda-tech.com/set1/smile/emsmile.gif
imthedude is offline Report Post   Reply With Quote
Old 05-01-2005, 06:17 AM   #41
redzcstandardhatch
redzcstandardhatch's Avatar
Send a message via AIM to redzcstandardhatch
those turbos are so cool...
tough little buggers.
custom EF traction bar and a cheap K24 for sale too! PM!
WTB: useable h22 of h23 block/girdle..no crank needed
redzcstandardhatch is offline Report Post   Reply With Quote
Old 05-01-2005, 08:18 AM   #42
rhd
what are you guys doing about the internal gates and what are you doing for compressor outlet..looks to be setup for a v-band on that too
Old 05-01-2005, 01:04 PM   #43
soon2brb240
Default Re: (rhd)
Usually people just weld the wastegate "flapper" closed and run an external gate.
Old 05-01-2005, 04:28 PM   #44
drumking15
drumking15's Avatar
i made a bracket that holds the wg shut...very simple..disconect the stock wg arm...and youll understand what im talkin about....locked in place held by a bolt...shouldn't open...
Old 05-01-2005, 09:01 PM   #45
Speed PHreak
Default Re: (imthedude)
~~~ 88 CRX HF~~~
Old 05-03-2005, 05:29 PM   #46
drumking15
drumking15's Avatar
its on the ground now i just gotta tune the biatch!!!
Old 05-03-2005, 05:42 PM   #47
b16sedan
Default Re: (drumking15)
I've heard from some local guys that HX35's are ballbearing. Any truth to this?
1990 Sedan B16
1992 DX Hatch Z6
b16sedan is offline Report Post   Reply With Quote
Old 05-03-2005, 05:49 PM   #48
soon2brb240
Nope, they aren't ballbearing, but they are rumored to have wheel technology as good, if not a little bit better than the garret GT series...BTW drum, how's it feel so far?
Old 05-04-2005, 04:56 PM   #49
drumking15
drumking15's Avatar
feels real good...started driving it today but cant get dam uber to log correct a/f's...
right now i have a 3" dp to stock exh....w/ a 3" manual cutout...hitting boost around 4k...but having a hard time tuning the maps....boost feels good tho...cant wait to get on it...thing is already gettin me antzy....it rips so far...but uber dataloggin is whats hangin me up from gettin it running better
Old 05-04-2005, 04:57 PM   #50
drumking15
drumking15's Avatar
also it was rumored that holset bearings are sickly designed not only to handle high rpms....but copious amounts of boost....should be a really good turbo on any high revvin motor...it sounds soooo purdy too..mine is missing the silencer ring and have a huge k&n on the thing.
Bookmarks
adapter, celica, difference, fast, h1c, holset, honda, hondatech, hx35, hx35g, hx35w, hy35, sizes, spool, vband, vid
