ACL Bearings? Opinions?
Whose got their opinions on ACL Bearings? I'm looking for bearings to use for an LS/VTEC. I'd like to go OEM but ACL is just hassle free and the price is right. Opinions?
Re: ACL Bearings? Opinions? (Coyote1800cc)
where did you purchase them? I saw off kteller they're 100 dollars for the mains, rods, and thrust washers, can that be beat? Also, what motors did you build with them and what were you revving them to?
Re: ACL Bearings? Opinions? (Big Teggie)
I use ACL's on all my race engines. They are always right on tolerances and always performed well under extreme conditions. Went 7.93 in the 1/4 mile on ACL's and have also logged over 70,000 miles on a boosted motor I built using ACL's
worked well for me, ran strong for 6k until I tore it apart to go bigger. Lsvtec that is. I was very surprised to see how nice the bearings looked after tearing the motor apart.
Re: ACL Bearings? Opinions? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">And the ACL competition bearings are even better.</TD></TR></TABLE>
Re: (shorto85)
ooo one for OEM. After this post, I'm thinking more possitively on the ACL's. I didn't think it'd come out this way. See if we can get some more opinions!
Any more info on the acl compition bearings??? or are they basically moly coated. Oh yea, i forgot to mention that I had my acl's moly coated, cost me about another 65-70 bucs but worth it in my opinion.
Re: (turbociv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv »</TD></TR><TR><TD CLASS="quote">Any more info on the acl compition bearings??? or are they basically moly coated. Oh yea, i forgot to mention that I had my acl's moly coated, cost me about another 65-70 bucs but worth it in my opinion. </TD></TR></TABLE>
Where did you have this done?
Re: ACL Bearings? Opinions? (SiBuddy00)
johnzm came over this past week and helped me rebuild the bottom end of my gf's itr motor - all the acl bearings plastigauge'd out at .0015" perfectly with stock rods.
I'll have to get back to you on how they wear.....
Re: ACL Bearings? Opinions? (mmuller)
ACL Race Series Information:
Excellence in engineering,
design and metallurgy produce
outstanding engine bearings.
Main bearing grooves occupy
only 3/4 of the circumference
thereby providing optimum
oil supply while increasing
the surface area for better
load-carrying capacity.
Increased crush and the elimination of
flash plating improve seating of bearings
in their housing for better thermal
transfer from bearings to rods and block.
Large chamfers are designed
and precision machined to allow
use of crankshafts with larger
fillets where applicable.
Tight, consistent wall tolerances
(+-0.004mm/ +-0.00015”) help
maintain accurate clearances.
Improved overlay and reduced
overlay thickness where applicable
increases fatigue strength.
Designed with a medium
degree of eccentricity.
Connecting rod bearings have hardened
steel backing which helps maintain their
crush under high load and temperature
conditions during operation.
ACL Race Series Flyer
Modified by GoldenEagleMfg.com at 10:36 AM 1/27/2005
