> Suspension
Old 04-19-2005, 04:08 PM   #51
mamaboy
mamaboy's Avatar
Default Re: (digitalh3lix)
if you look at the very top where the adjustment tab is you'll notice that there is a bolt pattern. i believe the size for the portion is 3/8". the lock nuts are 3/4". just get the 3/4" on the upper lock nut and use the 3/8" to hold the shock and crack the upper one loose. and just back off the second lock nut
mamaboy is offline Report Post   Reply With Quote
Old 04-23-2005, 07:40 AM   #52
EG MikE
EG MikE's Avatar
Send a message via AIM to EG MikE
great write up
EG MikE is offline Report Post   Reply With Quote
Old 04-27-2005, 07:02 AM   #53
travissmithoh
travissmithoh's Avatar
Send a message via AIM to travissmithoh
This is a great write up. I'm getting ready to do this in the next couple days. (Koni Yellows w/ Progress Tech. Sport springs)
It looks like the front shocks have three places for the circle clip and the backs have two. I think the front clip was in the middle and the back in the top. If I want to keep my car flat for autocross, where to I put the clips?
travissmithoh is offline Report Post   Reply With Quote
Old 04-27-2005, 08:17 AM   #54
94eg!
94eg!'s Avatar
Default Re: (travissmithoh)
If your using "lowering springs", leave the circlips in their original spots (middle front, top rear). The lowering grooves are mainly for stock springs. If you lower a lowering spring, your rates may be too soft at that ride height causing bottoming.
Originally Posted by gabebauman
Screws are useless.
94eg! is offline Report Post   Reply With Quote
Old 04-28-2005, 05:37 AM   #55
CRX Lee
CRX Lee's Avatar
The fronts have two grooves and the rears have three. The stock perch location is top front , middle rear. They were painted and delivered from the factory that way so if the perch curclips have been moves, the grooves with no paint on them are the stock ones.
Lee
Shock guy
Due to the large number of IMs received on H-T, I have had to disable them. If you need to contact me about a shock question, please send me an email.
CRX Lee is offline Report Post   Reply With Quote
Old 04-28-2005, 07:49 AM   #56
travissmithoh
Thanks for the replies. I was planning on just leaving the circle clip alone at first, but it's good to have some verification first. I'd hate to get it all together and on the ground, then find out I want to more it.
Old 04-28-2005, 10:03 AM   #57
Audi RS4
Lover
Audi RS4's Avatar
Default Re: Koni Shock Install (.RJ)
Are those the stock springs?
Glock 9X19..... http://images.honda-tech.com/set1/smile/emwink.gif
06' CBR600RR
03' Audi A4 1.8T Quattro (BEAST)
Jack "YACK" Harris & P1 Auto http://images.honda-tech.com/set1/smile/emthup.gif
PLEASE HELP ME!
Taking $1 to $5 donations. Paypal 03Audi@comcast.net Any help is appreciated.
Audi RS4 is offline Report Post   Reply With Quote
Old 04-29-2005, 02:05 PM   #58
Punkaddic
Punkaddic's Avatar
Did it today on my itr, it was really easy and I never did it before. Thumbs up for koni yellow and this awesome thread
Punkaddic is offline Report Post   Reply With Quote
Old 05-03-2005, 06:36 PM   #59
g_teg
g_teg's Avatar
Excellent write up. Just wondering if there is a ring seat foer the rear shocks as well because i didn not get one and was wondering if there is suppose to be one, and if i did not put one, will that mess tings up. I just want to make sure what is right. Thanks
g_teg is offline Report Post   Reply With Quote
Old 05-04-2005, 08:20 AM   #60
94eg!
94eg!'s Avatar
Default Re: Koni Shock Install (g_teg)
When you say "ring set", what parts are you refering to (be specific)?
Screws are useless.
Old 05-04-2005, 11:47 AM   #61
g_teg
g_teg's Avatar
Default Re: Koni Shock Install (94eg!)
Like, there is the spring cup right, that sits on the perch. Now does that spring cup the only thing that slids over the the shock to sit on the perch or is there another ring to be put on before the spring cup. ( for the rears) becuase i know the fronts have them
Old 05-04-2005, 12:00 PM   #62
94eg!
94eg!'s Avatar
If I remember correctly the spring chrome spring cup (pic #1) sits directly on the snap ring (pic #2). Only the front has the extra ring that goes in between. I'll check my instructions when I get home from work (4:30 pacific time)...
Spring cup:
Snap Ring"
Screws are useless.
Old 05-04-2005, 01:10 PM   #63
Tad
you are correct,
the fronts have an extra ring that both sits on top but also goes around the sides of the circlip,
the rear spring cup has that design built in.
without that design the circlip can/will pop out..
I think this is why the skunk2 koni adapters were considered crap
Tad
SOHC luva!
Tad is offline Report Post   Reply With Quote
Old 05-13-2005, 08:18 AM   #64
.RJ
.RJ's Avatar
Send a message via AIM to .RJ
Default Re: (Tad)
Originally Posted by Tad
you are correct,
<FONT SIZE="5">NO!!!!!</FONT>
I looked at my hardware again last night and you absolutely do need the 'ring' that goes over the circlip for both front AND rear - otherwise the circlip will not be captured properly and can <FONT COLOR="red"><FONT SIZE="5">FAIL</FONT></FONT>
Madison Motorsports
CB750 | CB350 | SV650
04 Trek 8000 | 06 Trek Pilot 2.1 | 85 Trek 660
Racing is one of the finest mechanisms for the disposal of money - RR98ITR
.RJ is offline Report Post   Reply With Quote
Old 05-14-2005, 07:07 PM   #65
CerealWars
CerealWars's Avatar
Send a message via AIM to CerealWars
My Konis had the ring for the front, but didnt have it for the rear. It was already built into the spring seat.
CerealWars is offline Report Post   Reply With Quote
Old 05-16-2005, 07:03 AM   #66
be.twenty
be.twenty's Avatar
Default Re: (CerealWars)
i have the ring on the front and back... but then again, i have the SP3's..
DC Squad #0485
be.twenty is offline Report Post   Reply With Quote
Old 05-22-2005, 09:27 PM   #67
Tad
Default Re: (.RJ)
mine have it already built into the rears
basically you need to use everything koni gives you to hold the spring on there..
thats the bottom line
Tad
SOHC luva!
Old 05-24-2005, 06:40 AM   #68
be.twenty
be.twenty's Avatar
final confirmation.. koni sport shocks (incl. sp3) .... does it got the silver ring to hold the circlip on the front AND rear or only the fronts come with them?
i posted above that mine came with front and rear but on closer inspection, my front shocks are the only one that came with the ring and my rears only came with spring cup seat.. is this enough to hold the clip in place?
thanks.
DC Squad #0485
Old 05-26-2005, 08:31 AM   #69
be.twenty
be.twenty's Avatar
confirmed with Koni...
Only fronts have the ring that go over the clip. Rears do not have.
DC Squad #0485
Old 06-10-2005, 09:33 AM   #70
cbmprelude
* B A N N E D *
Default Re: (shogun-dc2)
what does the snap ring and spring cup do?
cbmprelude is offline Report Post   Reply With Quote
Old 06-10-2005, 09:36 AM   #71
.RJ
.RJ's Avatar
Default Re: (cbmprelude)
Look at the pics on the first post
Madison Motorsports
Old 06-10-2005, 04:29 PM   #72
cbmprelude
* B A N N E D *
Default Re: (.RJ)
yea thats why I was wondering becuase none of the pictures in this thread work for me
Old 06-10-2005, 05:01 PM   #73
.RJ
.RJ's Avatar
wtdr must be down.....
Madison Motorsports
Old 06-11-2005, 12:09 PM   #74
KCoupe
KCoupe's Avatar
Send a message via AIM to KCoupe
good info on those who haven't don that man
right on
My 00 Si
Got Damaged, Fix, Stolen, Recovered
K'ed up. http://images.honda-tech.com/set1/smile/emthup.gif
KCoupe is offline Report Post   Reply With Quote
Old 06-13-2005, 09:47 AM   #75
be.twenty
be.twenty's Avatar
Default Re: Koni Shock Install (KCoupe)
right on
Yup, this thread helped alot when I installed yellows onto my DC...
DC Squad #0485
Bookmarks
2001, 7110, brake, civic, guide, honda, install, installation, koni, line, mount, prelude, shocks, sp3, yellow
