#26 | |||||
Swollen Member
1993 Milano red sedan DD 1995 Cosmos Black M3 (blown head gasket) 1994 Aztec green gs-R sedan track whore 600cc CBR powered Top Kart shifter http://images.honda-tech.com/set1/smile/emthup.gif |
#27 | |
awesome shocks, I loved having them all year on track
Madison Motorsports CB750 | CB350 | SV650 04 Trek 8000 | 06 Trek Pilot 2.1 | 85 Trek 660 Racing is one of the finest mechanisms for the disposal of money - RR98ITR |
#28 | |
#29 |
F.Y.I. People still do steal radios you know... how do you think I got this suit? |
#30 |
RJ, where did you get that set of spring compressor?
ive found working with the loaner set you get at autozone to be a bear to work with. they barely accomplished the task of putting my stock front springs ON. however, after some engineering problem solving (not by me quite frankly) and finally finishing the task, it's possible in hindsight with the set you get from autozone, but really, i look at your set to compare and they look so much more suitable and easier to use.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there. FS: Mugen CF-48 13x5.5 -38 Wheels *NIB* FS: 4040 Brake Proportioning Valves |
#31 |
Bought them at autozone, $20 I think.
#32 |
Nice write up
But it brought back memories of when i did my install last fall, the front was no problem at all but the back was a bit*H . . . . I broke the head of 2 bolts wound up haveing to cut the stock rear shock bracket off to get them out, then it was a PIA to get the new bushings pressed into my LCA, it wound up takeing all weekend to install, but its all done now and the ride is GREAT!
Fellas grab your left nut make the right one jealous http://images.honda-tech.com/set1/smile/embeer.gif http://images.honda-tech.com/set1/smile/emthup.gif Help me empty my garage! No reasonable offer refused! - 94-97 integra tails OEM used - D16Z6 intake mani & TB - SOHC VTEC - D16Z6 Fuel rail - SOHC VTEC - Audiovox Hood lock (used) - 14" steels w/ integra hubcaps (used,no tires) - 94-97 Integra Bra - 94 Integra OEM Rotors Front & Rear (used) - Iomega ZIP 100 Drive, barely used - 94-97 Integra heater controls PM me if interested |
#33 |
Awsome write up, im gonna have to put this into effect in a month or 2
#34 |
any tips on putting the shock fork/lca bolt back on?
That one seems to kick my ass regularly. Last time I did it, I ended up filing down the insid of the shock fork alittle, so it'd slide over the lca easier. and I use a jack to lift the lca up into it.. for some reason if I just try to do it by hand that fork will never line up right to fit over the lca !
Tad --------- SOHC luva! |
#35 | |
Is the problem that your shock fork is pinching the LCA to hard? I can see that this would make it pretty difficult to get the bolt holes to line up. I usually need to push down on the brake assembly to get the holes lined up, but I haven't had a problems with the fork pinching the LCA too tight on the 3 hondas I've taken appart...
I did have a problem with my CRX now that I think about it. It seems that the previous owner had new shocks put on, and when his mechanic installed the old springs & upper mounts on the new shocks, he got the upper mount in the wrong position. It's only off a few degrees, but it was enough to rotate the fork out of alignment with the LCA when the fork is properly seated on the shock. The mechanics remedy was to leave the fork out of its locating groove, and rotate back into place. When I mounted it onto the groove (after some axle work), it made it almost impossible to line up the holes. I was twisting the shock assembly with all my might, and could barley get that damn bolt in. Once I did I though I was all set, but a year later that bushing was basically ruined. Recently I replaced the bushing, and reset the fork the way that mechanic had it. Ride height seems pretty much unaffected though. I wanted to reset the upper mount to the proper degree, but my autozone doesn't carry a spring compressor that fits between the CRX's coils. Those Butt holes...
#36 |
hey i have a question..
i have koni yellows and my springs are sitting on the lowest pertch.. i was wondering if i could change that myself so the springs sat higher? i see how to take out the suspension, but i was wondering how to remove the circlip etc.. im rubbing everywhere and my tranny and oil pan are getting raped..
"beyond the walls of intelligence, life is defined .." -nas hyori > boa |
#37 | ||
#38 |
i noticed when you did i the rear you released the bolt from the upper trail arm to free up the shock. next time just release the bolt that connects the lca to the spindle and it will not throw off your alignment.
other than that pretty good job.
VTEC Cam Identification: http://www.ff-squad.com/tech/temp/VtecCams.htm |
#39 | |
making it hard to fit it over the lca. but once you make both ends of the fork over it at all, it lines up fine. The thing that makes it tough for me I think, is that I have my koni's jammed down real low into the fork, for that extra ammount of stroke. So it would be horrid to try and remove them any time i did my suspension. So I have to get the fork on with it bolted to the shocks! Maybe if I got something to pry them open and stretch em out alil.. i dunno.
#40 | ||
#41 |
excellent write up.
#42 |
cool thread.. good work
#43 |
owh mach cost this kit??
#44 |
does the suspension disemble works on honda civic 98 coupe?
Modified by perochan at 9:03 AM 4/5/2005 |
#45 | |
Check out my BLOGhttp://thenextenth.wordpress.com/ Thanks to.. www.motowear.com www.prima-racing.com www.hasport.com |
#46 |
one helpful thing i noticed is marking the upper mount portion with a white out all the way down to the base so when reinstalling it goes in as it did before.
#47 | ||
#48 |
good write up
All Show,Super Slow // <FONT COLOR="Red">PHUC DAT BICH PERFORMANCE</FONT> // VEE Squad! |
#49 |
nice write up!
"Real cars are Built not paid for off the lot!" "Where does it say on my Si "race me please"? "Cheap, Fast, Reliable. Pick 2 because the other is what your car WONT be!" *<U>Vouches</U>*: c-rotors, importboi22, Outkasted24, 92eg6, jaydmem1, s3x2000* http://images.honda-tech.com/set1/smile/emthup.gif Weksos http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif Prostreetonline http://images.honda-tech.com/set1/smile/emthup.gif |
#50 |
alrite do you know how to take em apart? i cant break apart those 2 thin bolts on top. any suggestions?
07' honda accord i-vtec k24a8 - Alabaster Silver Metallic 5spd. 93' honda prelude vtec h22a1... SOLD http://images.honda-tech.com/set1/smile/emsad.gif |
| Bookmarks |
| Tags |
| 2001, 7110, brake, civic, guide, honda, install, installation, koni, line, mount, prelude, shocks, sp3, yellow |
