#1 | |||||
Madison Motorsports CB750 | CB350 | SV650 04 Trek 8000 | 06 Trek Pilot 2.1 | 85 Trek 660 Racing is one of the finest mechanisms for the disposal of money - RR98ITR |
#2 | |
I'de like to add one thing to that:
The Civic shock shaft is IDENTICAL to the ITR shaft, so the install would be identical if your using ITR upper mount bushings. The stock upper mount bushings are different on the civic though. They allow you to use the Koni washers & collars w/o drilling anything. The ITR bushings have the washers built in, so if you use them they have to be bored out..
#3 |
RicerJ, you forgot the first and most important step:
[1] Open a
#4 |
this would have been nice to have when i was doing mine but its all good, and great write up
#5 |
HT White Ops
Sticky maybe?
"It is curious that physical courage should be so common in the world, and moral courage so rare." --- Mark Twain "Everything in the world may be endured except continued prosperity." --- Johann Wolfgang von Goethe |
#6 |
.RJ you are the man!!!!
Thanks for this thread!!!!
EJ8 Squad Member # 10, bitches. 97 Civic EX coupe, turbo ITR - blown up and parted out...RIP 07 GSX-R 1000 - It's not a bike, it's an engine with wheels! |
#7 |
nice job! how much was it to revalve? those look new... did koni replaced them for you or did they just repaint the busted used shocks?
2004 CLK 500 (Current) 2006 Sebring Silver S2000 (SOLD) 2007 Bianchi Via Nirone Triple Ultegra (Current) 2000 Integra ITR CLONE fully restored (SOLD) |
#8 |
$540ish including shipping for rebuild, revalve and converting the rears to externally adjustable. Did not have them shortened.
#9 |
I'm getting Koni yellows real soon, and was wondering how many of you guys are not running the stock brake bracket? Anyone making dust boots, or using the bump stops? I'm asking this because I don't have these things for the install.
Check my for sale threads http://www.hondamarketplace.com/show....php?t=2591413 http://www.hondamarketplace.com/show....php?t=2600965 |
#10 |
Sweet writeup. My koni yellows are coming this week.
'95 teg sedan ls (crashed) My CarDomain DopeROMs.com http://images.honda-tech.com/set1/smile/emthup.gif |
#11 |
take off y0 spinnaz!!!
(and remeber to use the rubber socket so not to scratch the chrome plating off!good write up
-Brandon PSN: infinate13 intent.. commitment.. accomlishment.. +/- 0..!..1..!..2..!..3..!..4..!..5..!..6..!..7..!..8..!..9..!..10 |
#12 | |||
There is a DIY thread here that someone wrote about making dust boots for their konis. It had a lot of pics too. Do a search. They looked good, but involved zip ties, and I'm not a fan of zip ties (I found it, click HERE). You must use bump stops. If you don't, your risking the destruction of your expensive shocks. Ground Control says never use less than 1" of bump stop. Here is CRX lee's how too on mounting your koni's lower in the fork... Quote:
![]() Modified by 94eg! at 10:19 AM 1/8/2005
#13 |
This thread is invaluable. I installed my front konis yesterday, and kept running upstairs to look at this guide
As far as the brake lines, I just tucked them in a place I know won't bind the springs, although I like the modified bracket idea. Will be puttin the rears on tonight most likely, we'll see how it goes. Does anybody happen to know the stock perch location on the koni sp3 5-perch shocks?
#14 | |
Middle perch is stock. The upper grooves were desgned to be able to raise the car back up a little when using lowering springs.
#15 | |
#16 |
bump
#17 |
so how much did it cost to have them revalved/rebuilt?
Tad --------- SOHC luva! |
#18 |
$540 with shipping.
#19 |
I got my Yellows about a week ago. Couple questions. When they package them do they wrap the shock in anything? Mine werent and ended up getting scratched. I know it dosnt matter sence the shock will perform just as well...just curious. And do you guys not reuse your dust covers? This is the second time ive seen a picture where you can see the bump stop. Although very nice write up .RJ...this did help with one question I had about a part.
#20 | ||
Koni's yellow paint is notorious for chipping easily. If you do a search, you will find a few threads about it. There is also a thread about making dust covers out of steering rack boots. As for the paint, I took maters into my own hands, and stripped all the yellow off, wire brushed and clear coated them. They turned out pretty nice. I just hope the clear holds up (it was a lot of work)...
#21 | |
No, they don't wrap them in anything, my ots ones werent wrapped in anything either, but they are held in the boxes "pretty" secure.. I think.. hard to remember exactly. but anyways, if the piston rods are scratched... i'd think about whether its bad enough to make a difference, if not, dont worry about it, if so, send them back.
#22 |
That wire brushing looks really good. So is there a reason why you guys dont use your dust covers? Interference? Im guessing sence you arnt using them it shouldnt have any effect on the shock? Even if its a daily driver seeing every bit of wheather? And yes it was just the paint on the body of the shock that got scraped.
#23 |
hey .RJ off the topic i was wandering if you are going to sell your tow hooks anytime soon. because you posted that you had them and were going to sell them
email me at de192004@yahoo.com
Texas Muthafu*ka thats where i stay.... |
#24 |
People should know to be careful when compressing the coil springs. With that spring compressor or others similar to it, you have to make sure that the 2 compressors are perfectly opposite from one another and to slowly compressed them each a little at a time. The coil spring scared the crap out of me when I was doing it.
Really nice write up though. Clearly defined pictures are a must and you did a great job of doing that.
Vigilante member # <FONT COLOR="red">001</FONT> 1996 Civic DX Coupe |
#25 |
good write up
| Bookmarks |
| Tags |
| 2001, 7110, brake, civic, guide, honda, install, installation, koni, line, mount, prelude, shocks, sp3, yellow |
