Stock Sway Bar Sizes
Old 11-26-2004, 06:05 AM
dropgear's Avatar
Default Stock Sway Bar Sizes
Hey H-T,
I've been compiling a list of stock sway bar sizes for Honda / Acura's:
http://grabka.org/articles/hondaswaybars.php
... but I need sizing information for the 92+ Civics. If anyone has that information, post it here!
Also, if you see any errors in that list, please let me know.
dg
Old 11-26-2004, 06:13 AM
egsleepercivic's Avatar
front bar on my 94 ex was *21mm*
thanks
Modified by egsleepercivic at 2:53 PM 11/26/2004
Old 11-26-2004, 09:53 AM
dropgear's Avatar
Default Re: (egsleepercivic)
really? from what I can tell, ALL 92-95 civic's had a 21mm front sway:
http://www.hondaautomotivepart...R+ARM
Looking this **** up is hard work
Old 11-29-2004, 06:19 AM
dropgear's Avatar
Default Re: (dropgear)
bumpage
Old 11-29-2004, 07:06 AM
kommon_sense's Avatar
92-00 civic ex has 22mm front sway.
I think that 92-00 civic lx also has 22mm front sway.
92-95 civic si had 22mm front sway
99-00 si had 26mm front sway, 13mm rear sway
No 96-00 civic (except si) had a rear sway. I believe the same is also true for 92-95.
Old 11-29-2004, 07:42 AM
Resident Evo's Avatar
Default Re: (kommon_sense)
Does the 99-00 Civic Si 26mm front sway have an advantage over other honda/acura front sways besides being slightly bigger ?
Old 11-29-2004, 08:25 AM
suspendedHatch's Avatar
Default Re: (EBP-Si)
Slightly bigger?!! Did you know that even 1mm thicker is a big difference?
While 26mm is huge and great for reducing body roll, many feel that it is too large and it makes it difficult to tune the suspension for neutral handling given the rates of the majority of aftermarket springs and swaybars. I haven't seen any rear solid swaybars thicker than 22mm as that thickness already poses a problem for the rear subframe. You could choose your own custom spring rates, but if you're at that level you're probably not using a front swaybar at all.
26-24-22-21mm front sway for street driving and autoX =
26-24-22-21mm front sway for racing =
no front swaybar + very high front spring rates for racing =
no front swaybar + very high front spring rates for street driving and autoX =
Old 11-29-2004, 08:26 AM
dropgear's Avatar
with the 26mm bar, the idea is to support the added weight of the B16 and associated accessories. but when it comes to daily driving dynamics, the 22mm is totally fine, even for the B16-equipped cars, and a larger rear sway bar is desirable..
Old 11-29-2004, 08:47 AM
93CivicSI's Avatar
Default Re: Stock Sway Bar Sizes (dropgear)
OEM on my 93 Si hatch was 22mm - no rear sway
Old 12-03-2004, 01:55 PM
dropgear's Avatar
up
Old 12-03-2004, 02:17 PM
Relic1's Avatar
a rear 99-01 JDM ITR is 23mm. (not sure about 96-98)
92-95 civics other than the EX/SI did not come with sways front or rear.
Old 12-03-2004, 07:58 PM
dwnthehatch's Avatar
Car Front Rear
Del SOl VTEC 24mm 15mm
Del Sol Si 21mm 13mm
Del Sol S 21mm N/A
92-95 Civic EX 21mm N/A
99-00 Civic Si 26mm 13mm
Old 03-14-2006, 12:50 PM
Tyson's Avatar
"Civic 88-91 17.0mm 13.0mm "
this isnt true.
Old 05-14-2006, 04:21 PM
EGbeater's Avatar
Default Re: Stock Sway Bar Sizes (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">"Civic 88-91 17.0mm 13.0mm"
this isnt true.</TD></TR></TABLE>
"Civic (Si) 88-91 18.0mm 15.0mm"
This is great general info, and I'm sure most of it IS right. But I just removed and measured the OEM swaybar from my '89 Civic Si, and while I've read elsewhere that 15 mm is the diameter on the 4th gen Si models, mine reads 0.52" with my micrometer, which is like 13.2 mm, so I'm thinking my car somehow got the non-Si bar . . .
I suppose it's possible they threw the base model bar on there by mistake, or maybe they just ran out of the correct, larger Si bar that day in the factory, but that seems really odd for Honda.
Old 08-10-2010, 08:33 PM
afranzy's Avatar
Good info! You can find the listings for the sized on honda's parts site. just find the sway bar part and it tells you the size of it.
Old 08-10-2010, 11:56 PM
sLAg's Avatar
tells you the sizes at the bottom of all gens including dc/eg
http://www.jdmuniverse.com/forums/view_ekswaybars.html
Old 09-18-2010, 03:17 PM
Tiggy's Avatar
you forgot to post prelude sizes, i know the 97-01 both sh and base have 24mm front and 22mm in the rear
Old 10-31-2010, 09:28 PM
chato's Avatar
Old 01-23-2013, 10:36 PM
GReeser's Avatar
This write up really helps as I'm researching my suspension setup. Good one.
italian_virus
06-25-2010 09:11 PM
SoullessJapaneseMachine
Suspension & Brakes
10-10-2007 07:43 PM
DarkBB4
02-01-2006 01:16 PM
WuRKD b16
03-03-2004 02:37 PM
Quick Reply: Stock Sway Bar Sizes
