WRX Injectors
WRX Injectors
Well, I was looking at getting some WRX injectors to make my spraying experience a little safer. I have looked on a couple subi forums and found nothing. I was wondering if someone knew if they were high/low impedence, and how much they flow.
Thanks
-hatched05
Thanks
-hatched05
Re: (ImportRacr05)
They are high impedance and flow about 420cc stock or 800cc+ when modified. Me and wadanator are running modified ones but we are the only 2 hondas I have heard of using wrx injectors so far. If you dont need modded 800cc injectors then its easier to use standard dsm 450cc injectors as the subaru ones use wierd clips and they are significantly shorter which requires at minium removing the fuel rail spacers and may even require shorter bolts or studs. If you are going to be using nitrous I would leave the injectors stock and use a wet kit otherwise tuning will be a lot trickier since it will need two different tunes for whether you are spraying or not. Bigger injectors will not make it any safer as long as you use the proper fuel jet and verify its running safe with a wideband.
Here is a thread I did a while back on modding the injectors and installing them in a honda if anyone is interested
http://www.ecimulti.org/uberda...d=883
Modified by omahaturbocivic at 3:01 PM 10/14/2004
Thanks. Thats what I wanted to know. I know about the clips and modifying to them. I am pretty sure Im gonna do a wet now. I was planning on using a dry since I wasnt gonna be doing a huge shot. Thanks for the help
