| New! Use your Facebook to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendor Directory | My Recent Topics | My Notes | Used Cars |
#1 | |
JDM 98 Spec B18C-R engine swap guide for any 99-00 CX/DX Civic HB
Mounts: · JDM-R front passenger side mount · P54 Del Sol front driver’s side mount bracket (Honda P/N 38930-P54-000) if you wish to keep A/C. Use the JDM-R front driver’s side mount bracket if you don’t. · 99-00 Civic Si driver’s side upper engine mount bracket (Honda P/N 11910-P30-000) w/ 99-00 Civic CX/DX driver’s side upper mount and frame mount. · 99-00 Civic CX/DX passenger side transmission mount and frame mount. · 99-00 Civic Si rear engine mount bracket (Honda P/N 50827-S04-N10) w/ 99-00 CX/DX Civic rear frame mount. Wiring: · Si Wiring harness o IAT sensor plug needs swapped from stock JDM harness to Si harness and wires extended. o Vehicle Speed Sensor plug needs swapped from stock JDM harness to Si harness. o EVAP sensor plug needs swapped from stock JDM harness to Si harness and wires extended. o Plastic mounting bracket for injector plugs needs swapped from JDM Harness to Si harness. o Borrow the EVAP sensor and 2 way valve from the stock CX/DX motor and install/connect the vacuum lines and sensor plug. · 98+ Spec JDM-R ECU o An OBD2b -> OBD2a jumper harness is needed for the OBD2b 99-00 Si harness to be usable with a 98+ Spec JDM-R ECU(unless you want to swap plugs and wire everything yourself). Fuel supply: · Replace the fuel feed line from the filter to the rail and also the fuel return hose from the rail to the hard line runnning under the vehicle w/ 98-01 ITR units. · Replace the OEM fuel pump with at least an OEM 98-01 Integra GS-R/ITR fuel pump. Exhaust: · A 2.5” converter is needed for the JDM 4-1 header. Just have a muffler shop cut your exhaust to length and weld on the converter with a 2.5" collector flange. · A 2.5" donut gasket will be needed for the header to flange connection. Power Steering: · Replace the OEM CX/DX PS pump with the JDM-R PS pump provided with the swap. The OEM Civic power steering line and return hose will connect to the JDM-R pump with no hassles. Cooling: · I went with a Fluidyne aftermarket radiator designed for the 96-00 Civic, but I've been told that a DelSol DOHC VTEC radiator will work just fine. Misc parts: · 98-01 ITR radiator hoses · 98-01 ITR TB gasket(Recommended so you don’t break the TPS during install) · 98-01 ITR Exh. Manifold gasket · 98-01 ITR throttle cable(The stock cable will work, but it’s quite a bit longer than is needed) · 98-01 ITR axle seals I put this together during the before and after of my 98 Spec JDM-R engine swap into my 99 DX. Let me know if you have anything you think I should add, subtract, or change. Modified by All-MotorSports at 6:00 PM 10/10/2004 Modified by All-MotorSports at 8:23 PM 11/17/2004
Sold my Evo IX MR, bought a Fit for my daily commute, and now I'm in the market for an ITR.....guess I never should have let the ex-wife sell the 1st one for an IS300. |
#2 |
is there any other way to mod that header besides welding it?
<U>213whp 151tq</U> |Prostreet Online |JHP USA |HMotorsOnline| |NoLimitMotorSports |Camp 1320 |SixSigmaRacing | |Lightning Motorsports |Kteller| K@tman| Slammed Si | |Golden Eagle Manufacturing|WhoisDan|Intec Racing| http://images.honda-tech.com/set1/smile/emthup.gif |
#3 | |
#4 |
Can't I use USDM ITR's engine mounts for swapping into a '00 EK? Why is that only the Si's mount is needed?
Thanks! |
#5 | |
#6 |
If I were to have a complete '97 ITR with all the engine harness intact, could i swap this completely into a 00 EK?
What molifications do I need? I intent to take everything except the ABS from the ITR to the EK. Thanks! |
#7 | |
In case you didn't already know though, it's "illegal" to install an engine in a street car with a manufacture date older than that of the chassis that the motor is going into. In other words, you can legally install only a motor built from 2000-present into your '00 "EK", so install that '97 C5 at your own risk.
#8 |
Thank you for the input and forenote. Yes, putting an older engine into a newer car is against the law. However, but cars are OBDII compliance. So I don't quite see a problem with that. Furthermore, those guys who sold engines from Japan are rather older engines also.
I will see about the pulling everything from the donate car, as the car has almost everything intact except the rear Actually, I plan to pull the ITR radiator also and stick into the EK. I will see if I can make it fit. Only issue trouble me is the ECU plug and play. I read on this Hybrid section that the plugs are different between OBDIIA and OBDIIB. Wonder what I need to change.... Regards, |
#9 | |
Yes, get everything you can out of that car. You'll need just about all of it. I believe that the Integra radiator will fit just fine. Yes, the plugs are definitely different between the OBD2A and OBD2B systems. Get a Si harness and an OBD2B->OBD2A jumper harness and you have the ECU side covered. After that, you should just have to swap a couple plugs from the Integra harness onto the Si harness and you're done with the engine side.
#10 |
Thanks bud.
I still need Si harness??? Arrgh... I will try to do with ITR harness and see what happens... Even if I have complete access to all the wirings in the ITR, can't i simply just swap over and be done with it? Oh boy... This is going to be fun! |
#11 | |
#12 |
oh, what do you know? I bet you're the kind of a hole that would freakin spray paint his car!
92 hatch 12.21@109mph all-motor |
#13 | |
#14 |
Dude,
He is helping to contribute his knowledge on swaps. Can't you have better things to do than to jack this post? |
#15 | |
Thanks for having my back though.
#16 |
wow. people can be super touchy! I am SORRY for "jacking" your post dude.
#17 | |
| Bookmarks |
| Tags |
| 97, 99, b18c, civic, cx, deals, ek, engine, florida, good, jdm, lx, motor, swap, swaps |
