#1 | |||||
#2 |
I like the big turbo at low psi (my setup) not sure of the advantages but seems better to say I made 350whp at 7-10 then saying I made 350 at 12-15psi. I would like to know also
2005 Acura TL 6 Speed, Navigation, Black on Black 2000 Integra Turbo Type R All Stock B18c5 Full-Race t3/t67 SOLD!! : | <FONT COLOR="#cc0000">Team RUSH</FONT> | <FONT COLOR="#333333">Vouches</FONT> |
#3 |
doesn't matter how many pounds of boost your running, your stock block will handle only so much whp. A smaller turbo creates more back pressure on your exhaust, which is why you have a lack of hp with them. A smaller turbo also creates higher intake temps, which further reduces your horsepower. I would shoot for the same peak whp or higher, despite the same peak horsepower, your powerband will look much better.
#4 |
Bigger turbo = more lag. If you pick the right size turbo for your setup you will have a good balance of power, instead of waiting all day to have a high peak with low boost.
2000 Gs-R Powered by Honda...pushed by Precision -=-=-=-=-=-=-=-=-=-==-=-=-=-=- DC Squad Member # 0221 |
#5 |
Its a drag car so lag really isn't an issue.
#6 |
More WHP at a lower boost level is nothing more than some bullshit to brag about. The smaller turbo will spool faster.
2000 Honda Civic EX Coupe D16Y8, 12.80@105.8 14 psi SOLD 2004 Ford F150 XLT Supercab Triton V8 |
#7 |
So I cannot safely make more WHP with the larger turbo?
#8 | |
#9 |
A stock motor can handle only so much before shit starts breaking. Doesnt matter if you have a tiny ass snail or a big ass one. Once the point come where the motor can't handle anymore it wont.
-Dustin EJ8 Squad #033 Gt28RS powered D16Y8 (9psi - stock internals) 1/8 mile:8.90 @ 83.94 on street tires eCtune http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif |
#10 |
bigger the better, obviously within reason (watch the efficency range) a bigger turbo will give you more air flow at a given psi than a smaller turbo=more power. Use the lag for traction. i'd rather have my t3/t4 60-1 than a smaller turbo
-02 BB S2K -94 H22 Turbo'd Integra http://honda-tech.com/zerothread?id=831210 -94 B16 Del Sol (sold) -93 RHD hatch |
#11 |
Pick a turbo that fits your motor and be done with it. Putting some monster turbo on your car is not going to make more power than the correct sized one. Say for example a t3 is the ideal size. Going with a 100mm garret is not going to make any more power at lower boost.
#12 |
3037 ball baering..
DA Build Crew - Garage Ridden - HardParked |
#13 | |
#14 |
Ok, I might just stick to the Super 60.
#15 |
i would say just find a turbo that fits your setup on the compressor map. that is by far the most important part of choosing a turbo... generating boost efficently. if your stuck between two turbos, remember the smaller one will have less lag, which doesn't matter since its a drag car... and the bigger one will have more growing room.
thumbsup: Snatch, Tegmech, Flamenco-T, Andy@AMR, John@M&H, Earl |
#16 |
I am thinking bigger turbo with less boost will heat the air less then a smaller turbo running higher boost.....lower air temps are good.
94 FD w/LS2 |
#17 |
There is one thing that I've started to notice about choosing a turbo.
If your even thinking about going with a large turbo, and just running low boost...GO FOR IT. The likely hood that you will be wanting more power in the future will surely be there, if infact your thinking of the big turbo now. Might as well go bigger now, than regret it later.
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
#18 |
bigger turbo at lower psi just means a steeper power curve which is not exactly healthy for ur block. with a good tune its not bad but if ur going to run low psi then a big turbo is not needed and you would be much happier with a smaller turbo for lack of lag. u should really only get a bigger turbo if you plan on getting close to its max some day.
97DX Lexus Grey b18c1 Garret HKS Tial Hondata RC Sparco Tokico Payn Tuned 252whp @ 9psi Mustang Dyno "whats a good turbo to put on VTEC engines, and still be able to use VTEC?" - feel my sol My For Sale Thread : http://www.honda-tech.com/zero...78538 |
#19 |
Is a Gt35R a decent match for a 2.0L B18?
FS: GSR Top Speed Header, JR FMU, JR boost timing, WW type W sides Integra FS: black WW commando spoiler, 95 front and rear bumpers, B18a block, LS Head !!!!!!make me an offer!!!!!!!! WTB: OEM ITR optional sides, mugen gen1 spoiler, rear wiper plug |
#20 |
I think you guys are nuts with your big ass turbos. My SC34-E (.63ar 57trim) is plenty big and will feed 525hp yet is dwafted by some of the turbos out there. Why go bigger and get the extra lag? 80% of you are only making in the 300s.
425whp/300ft-lbs at 17psi |
#21 | |
The thing is, I might swap it for a built d16 sometime in the future, so I dont want to spend 600 bucks on a turbo that leaves me with a power "ceiling". Also, I really dont care about this motor, its not a big deal if it blows, d-series are a dime a dozen. |
#22 |
Lets clear up the sizing thing, one is "BIG" in relation to the other, but not really big in the scheme of things. Here are the two turbo's Im chosing from-
A) Garrett T3 Compressor- .42 A/R 60 trim wheel Turbine- .48 A/R 68 trim wheel B) Garrett T3/T04e .48 A/R turbine 50 trim Stage 3 wheel |
#23 | |
you don't need a big turbo to make decent power. you should also be realistic and consider your long term goals when choosing a turbo. btw, i used a basic T3/T4 Turbo from CheapTurbo.Com in the passes i took in my sig. i'm not breaking ET records but i think its pretty damn good for a New $525 Turbo
Killer B 10.?@132.45mph |
#24 | |
#25 |
Personally I like the idea of a larger turbo on low boost. Just don't go too large on the turbo. It comes down to what your goals are, and do you want to spend the money up front.
Turbo Civic Si (Retired) 10.64 @ 141mph 638hp 457tq (gt35r) |
| Bookmarks |
| Tags |
| 55, ar, cold, garrett, t4, t66, turbo |
