| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Used Cars | Garage | Vendor Directory |
#1 | |||||
#2 |
There's a small hole right above where the catalytic converter is, did you search up in there? It's kind of hard to see unless you have plents of light or the car is on a lift..
#3 |
Depending on what year integra you have it should either be in the rear part of the exhaust manifold (near where it connects to the cat) or OBD2 cars have a two O2 sensor setup with one being in the manifold and one in the cat. Good luck!
__________________
'93 K20 Hatch... '97 Mixed colors Integra GSR - project winter beater '92 Harvard Blue Civic DX 3 door - sittin' '99 Dodge Ram 2500 Cummins Turbo Diesel 4x4 |
#4 |
thanks for the suggestions. again i am not looking for where the 02 sensor is but instead where it plugs in.
#5 |
What year is your car? On OBD1 and OBD2 models the front O2 sensor plugs in near the oil filter. There is a tab that is attached to the intake manifold bracket that holds th plug in place usually. These cars are so messed with these days that you never know if things are in the right place or not. On OBD2 cars the second O2 sensor drop down out of the body of the car somewhere above the catalytic converter. OBD1 cars do not have the second O2 sensor. Good luck, and sorry for the misread question!
__________________
#6 |
bump...havent checked yet but more answers would help before i do so.
#7 |
In your first post you say that your O2 wiring was peviously cut. In that case how are you expecting to find the plug? What year is your car, and what ecu are you running? I need some answers to give you a better idea of what's up.
__________________
| Bookmarks |
| Tags |
| b18b1, gsr, integra, o2, replacement, sensor |
