Go Back   Honda-Tech >
> Honda Accord (1990 - 2002)
Old 11-01-2009, 12:20 PM   #26
NeKe1point0
1994 Honda Accord Coupe
NeKe1point0's Avatar
Send a message via AIM to NeKe1point0
Default Re: STOCK F22B2-T Dynojet results 300+WHP !
Quote:
Originally Posted by accord_raffi View Post
Did you ever tune this car on another program or only the s300?
Only S300
Quote:
Originally Posted by SergEK View Post
I think you are a mild cam upgrade away from your goals. I think with a little more lift you would be making more power everywhere.
Does bisi make a mild NA cam you can use? Seems like either the head or cam is choking your power and I think the cam will unlock a TON of power in your combo.
Nice numbers
I agree with you 100%. A new cam would def make a major improvement ! My new setup will have an aggressive CAM (not CAMS << hint hint ).
This motor will stay 100% stock and i will attempt to make as much power as possible on it (with AC) till it goes !
__________________
Quote:
Originally Posted by ShadowBar View Post
So the part numbers are almst the same. U know what almst the same gets u? a hooker w. a penis. Its almst the same as a female hooker.
$30 DYNOJET DYNO PULLS www.ProvenPowerTampa.com 813.988.DYNO
NeKe1point0 is offline Report Post   Reply With Quote
Old 11-01-2009, 12:45 PM   #27
SergEK
Quote:
Good on ya
Should see 400+ on race gas/E85
The hp isnt so much as impressive as the torque....considering how cheap these motors are thats alot of torque for not really so much money lol
__________________
Automotive Photographers PM for opportunity $$$$
XBL = SergEK9
SergEK is offline Report Post   Reply With Quote
Old 11-01-2009, 01:15 PM   #28
accord_raffi
1996 Honda Accord
accord_raffi's Avatar
Send a message via AIM to accord_raffi
Do you think you will get the full benefit out of an aggressive cam? It sounds like you're power numbers are nearing the limit of the motor as is.
__________________
**Dent Sport Garage**
http://i56.photobucket.com/albums/g1...785/sig2-1.jpg
CD Squad Member #196
accord_raffi is offline Report Post   Reply With Quote
Old 11-01-2009, 03:33 PM   #29
SergEK
The cam IMO will unlock 30-50whp under boost...I could be off and the head is just stuck but I think the super mild cam in there is why his numbers arent higher.
With better fuel, a little more timing and cooler air this motor should clear 400+
I think a mild cam upgrade would really wake the powerband....but he wants to push the stock motor so see what happens
__________________
XBL = SergEK9
Old 11-01-2009, 03:58 PM   #30
NeKe1point0
Filled up tonight with Sonoco 100 and yes i want to see what the stock motor can push with factory internals.
__________________
Old 11-01-2009, 05:29 PM   #31
tamadrummer1120
1995 Honda Accord
tamadrummer1120's Avatar
Super sick setup. I love the fact that you can spend little to no money on our F22's on a pieced together turbo kit and make easily over 300 hp. H22 swaps are cool and all......but dayum son, talking about getting the money's worth.
__________________
CD Squad Member #220
tamadrummer1120 is offline Report Post   Reply With Quote
Old 11-01-2009, 05:29 PM   #32
accord_raffi
1996 Honda Accord
Oh ok in that case are you going to build the F if something goes boom? Or try a new powerplant? I'm assuming you're staying F series if you're going to bother with the head. Why not do some porting? Or try swapping in the 4th gen head since those seem to flow much better than the 5th gen heads. Just a thought.
__________________
Old 11-01-2009, 06:24 PM   #33
tamadrummer1120
1995 Honda Accord
f22a6 with some cams. killa setup haha.
__________________
Old 11-02-2009, 11:15 AM   #34
NeKe1point0
updated OP with some dyno video action !
__________________
Old 11-02-2009, 04:20 PM   #35
sir4doorking
sir4doorking's Avatar
Quote:
Originally Posted by Andryzzle View Post
A/C helps with traction control in the rain
that's a nice looking dump tube too lol, i'm jealous
lol
sir4doorking is offline Report Post   Reply With Quote
Old 11-02-2009, 04:28 PM   #36
sir4doorking
You are correct about the routing. Typical Accord routing was used. This is the only pic I could find of my engine bay. Good shot of my dumptube though
-The reason the rev limiter is set so lower is because peak power is achieved before redline.. and when you spin the motor faster then Honda intended, FACTORY parts start failing ! lol
-Duty cycles at WOT are stupid low... Not even 50% if i remember. These injectors have been great for the year+ that i have had them. I have done quite a bit of tuning on this set up and get ~28MPG with beating the sh!t out of it and about 32-35MPG taking it easy on it... Im planning on selling these Delphis soon and will then upgrade to Injector Dynamics 1000s for my new setup
- Yes, 93 pump gas was used for this dyno session. Next time im thinking ill run some Sonoco 100 and a but more timing.
- 3" Downpipe/Exhaust
yo bro so what kit did u use? because i have a 95 accord wagon that i want to boost but keep my A/C like u did. thanx for any reply
Old 11-02-2009, 06:52 PM   #37
NeKe1point0
I pieced this kit together.. You can do the same or I think Treadstone Perf make an AC comp kit.
__________________
Old 11-03-2009, 02:10 PM   #38
BbqEazyE
BbqEazyE's Avatar
bump because this is badass. Nice numbers man.... So what is the plan to reach your goal? Im curious to see the future of the car. :thumbs up:
BbqEazyE is offline Report Post   Reply With Quote
Old 11-03-2009, 06:15 PM   #39
sir4doorking
i am going to look in to that thanx for ur reply bro
Old 11-03-2009, 07:14 PM   #40
Andryzzle
Andryzzle's Avatar
Send a message via AIM to Andryzzle
accord raffi has the treadstone kit if you have any questions about it.
__________________
Georgia Institute of Technology / Southern MD
94 Accord EX Turbo
CD Squad #038
Andryzzle is offline Report Post   Reply With Quote
Old 11-03-2009, 08:28 PM   #41
kccord
kccord's Avatar
Send a message via MSN to kccord
I do have Treadstone Kit. Need to tell Jason to upgrade to 0.63A/R turbine housing. I can only make 290whp with the 0.48A/R @ 15psi that comes standard with the kit (with stock head and cam). Tried to tune 20psi, didn't make any power so my bet was that the 0.48A/R Turbine is choking + I get moderate power drop after 5800rpm.
The compressor housing is fkn big I can tell you that
__________________
H-T home for crazy fast Serious Honda Builds
The ONLY Accord Turbo in Perth - 290WHP 385Nm Torque @15psi 0.48AR T3/T4.
Next Tune: 0.63A/R Turbine Housing Coming
kccord is offline Report Post   Reply With Quote
Old 11-04-2009, 12:27 AM   #42
extralargenog
extralargenog's Avatar
Quote:
Originally Posted by twkdCD595 View Post
Very nice, x2 on more pictures.
Whats the new setup thats going in?
Guys are walking on our old F "records" LOL
__________________
LEED tuned 660 WHP 4 do' panty soiler
GFI:WE build FAST!!!
REALHOMEMADETURBO.COM, KAIZENSPEED.COM, LSD Motorsports
extralargenog is offline Report Post   Reply With Quote
Old 11-04-2009, 07:31 AM   #43
twkdCD595
twkdCD595's Avatar
I know right, its too bad back then I only had some maxed out 450cc injectors and a shitty clutch. Stock head bolts and all.
If I had another stock motor to put my setup on now with some ARP's, I think I could probably pull off a little better numbers than the old 335whp it did back then.
Oh well. I have moved on to new F series sohc records... sometime I need to post when I am not lazy and see if I have gone far enough yet.
__________________
-try not, do or do not... there is no try.
God bless the men and women of the U.S. armed forces.
T1 Race Development
Laskey Racing
PortFlow Design
Bisimoto Engineering
twkdCD595 is offline Report Post   Reply With Quote
Old 11-04-2009, 11:18 AM   #44
extralargenog
ya man serious i have yet to see pics or anything
__________________
Bookmarks
Tags
1994, 300, clean, dyno, dynojet, f22b2, hp, limiter, parts, performance, results, rev, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
