Go Back   Honda-Tech >
> Road Racing/Autocross
Old 11-03-2009, 03:17 PM   #1
petwhookie
petwhookie's Avatar
Send a message via AIM to petwhookie
Default Uneven camber?
I recently gotten an alignment for my DC that's dropped on koni/gc and it turns out I have -1.6 degrees on the front left and -1.3 degrees on the front right. My drop is pretty even on the front and I double checked before my alignment. What concerns me is the uneven camber. Is my camber uneven because the drop is uneven? I was under the impression that if I were to drop my car the same amount on both sides, the camber should be the same. Or does the difference not matter that much?
petwhookie is offline Report Post   Reply With Quote
Old 11-03-2009, 03:56 PM   #2
ScottBell
ScottBell's Avatar
Default Re: Uneven camber?
Not enough to worry about IMO. You should check your ride height on both sides and/or scale the car to make sure you are not goofed up on your corner weights.
__________________
ITR 98-301 Yes, the #35 "Budman" car. Currently in NASA PTC trim.
HOOSIER TIRES ROCK.
ScottBell is offline Report Post   Reply With Quote
Old 11-03-2009, 07:05 PM   #3
TunerN00b
TunerN00b's Avatar
Check to see if your subframe is centered. If it has been shifted to the side, it will add negative camber on one side while taking it away from the other. Caster is also affected by the subframe position.
TunerN00b is offline Report Post   Reply With Quote
Old 11-04-2009, 05:36 PM   #4
petwhookie
petwhookie's Avatar
besides the subframe would there be any othe reasons why my camber is uneven
Old 11-04-2009, 06:10 PM   #5
TunerN00b
TunerN00b's Avatar
Quote:
Bushing deformation
Bent suspension parts
Incorrect parts installed on only one side (its happened to some people when buying used)
Frame damage
Uneven ride height (though generally not very noticeable in terms of camber differences)
Old 11-04-2009, 08:04 PM   #6
Tyson
Tyson's Avatar
thats not uneven.
__________________
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
