Go Back   Honda-Tech >
> Paint and Body
Old 10-25-2009, 10:40 PM   #1
skthx
1995 Volkswagen Jetta
skthx's Avatar
Default DC2 Quarter Panel Repair
so i picked up a teg with previous fiberglass work done to it, and obv it was a 1/10 job and the rust came back. I had to cut everything out (not fun) and the passenger side still got bondo all over it. Shortly i'll be doing a diy on some bodywork involving refabricating sheetmetal for the complete wheelwell & QP on this teg and also fabricating a fatter lip on the Qp's to give it a bold look. Car is already at my shop as of yesturday and should start the job early next week! )
skthx is offline Report Post   Reply With Quote
Old 10-29-2009, 06:05 PM   #2
skthx
skthx's Avatar
Default Re: Coming up DC2
ok bodywork started. finished putting metal in. diidnt bring my camera to work but got 2 pics of my shitty phone. will take pics of finished product tomorrow.
BEFORE
AFTER
This side was not finished yet.. only the inner wheelwell
Old 10-29-2009, 06:14 PM   #3
bakertime
bakertime's Avatar
Looks like a lot of work...good luck with it!
By the way, if you use photobucket you can rotate your pictures.
__________________
My Integra Paint & Body Thread: http://honda-tech.com/showthread.php?t=2613670
Read this before a $50 paint job: http://www.honda-tech.com/showthread.php?t=2490171
bakertime is offline Report Post   Reply With Quote
Old 10-30-2009, 12:48 PM   #4
Duc_du
Duc_du's Avatar
that is a lot of cutting buddy. GL
Duc_du is offline Report Post   Reply With Quote
Old 10-30-2009, 05:59 PM   #5
skthx
skthx's Avatar
heres some pics of the car finished with the metal part of the job... Also how do you like the drop in the front? the rears i haven't had time i need new LCA's to drop it. . .
Old 11-02-2009, 10:44 AM   #6
Ziprock
Ziprock's Avatar
Default Re: DC2 Quarter Panel Repair
is this your first quarter job? if it is, props for diving into one hell of a mess. i myself have to do this to my own dc and im not looking forward to it.
the bottom of the quarter directly in front of the tire has more of a curve then your metal patch has. also, the wheel well could be more curved. you want to do the best you can with your metal patch so your not trying to make up for it being mis-shapen, with body filler. are you covering it with fiberglass filler? short strand filler is waterproof and wont soak up moisture like body filler will. not sure if you knew that or not so i threw that out there.
props for using metal though. good work so far.
__________________
95 Integra LS
Ziprock is offline Report Post   Reply With Quote
Old 11-02-2009, 10:27 PM   #7
z395civic
z395civic's Avatar
Send a message via AIM to z395civic
looks like he is using duraglass, could be wrong tho. IMO duraglass is the best thing to use on rust repair after you weld/glue a patch on. i always add more fiberglass resin to it. it doesnt soak up water like bondo does.
__________________
Quote:
Originally Posted by hurleyint
Jesus tap dancing Christ. 23's...on a CD accord? http://images.honda-tech.com/set1//smile/emcrook.gif no.
z395civic is offline Report Post   Reply With Quote
Old 11-02-2009, 10:35 PM   #8
gorillafart
gorillafart's Avatar
did u just shape your own metal and bondo it to the car?
gorillafart is offline Report Post   Reply With Quote
Old 11-03-2009, 05:31 AM   #9
skthx
skthx's Avatar
No its welded only the big gaps i put some duraglass indeed. I hate bondo with a passion and even refuse to use their mixing tools.
The most ideal way of doing a job like this is shaping one complete peice to get the curve to match. I had no time so i used several layers but i have an idea of what im going to do to shape it out nicely.. doing the prep work today or tomorrow will keep you guys posted.
Old 11-03-2009, 07:00 AM   #10
b18bye
b18bye's Avatar
Send a message via AIM to b18bye
patches look pretty good .
It would be nice if rustrepair.com or fixmyrust.com made patches for Integra's . save alot of time and less bondo needed !!
__________________
Black 95 4dr Teg (WoRked) Ls-V
EBP Em1 ,Laguna Seca b16 EK
94 dc2 ,92 Civic Si LS BOOSTED
b18bye is offline Report Post   Reply With Quote
Old 11-03-2009, 05:50 PM   #11
skthx
skthx's Avatar
So finally got a day where it wasn't too busy so i started prepping the teg. Two quarter panels, two doors, fender, trunk, bumper. Started off by grinding it down
Taking pics in the shop isn't the neatest thing
Filled with superglass
Cheesed, grinded / sanded with 40
Mixing lightweight filler
Filled / sanded
Some evercoat rage / filler at this stage i think
Another area being assesed. (TYK previous owner fiberglassed it. ;()
Word of advice, if you're shaving side mold's
please do not fiberglass matt it. Simply sink it with a dolly and fill it with
glass filler.
Grinded, sinked holes and filled with superglass.
Fender slightly was damaged/bubbling so might as well take care of that now.
Another side sinked and filled as well.
Trunk holes were also fg matted, lol, so same procedure. Grinded, sinked,
filled.
Fender
Getting there, putty with some filler
Sanded the glass, put lightweight filler over, sanded.
Fixing some high spots.
chessed / grinded ( ran out of 40 grit ) / sanded
Lightweight filler, almost there
Hmm
Some of the tools ^_^
Some more minor highspots filled, then putty then 320 sanded ready for primer.
Blowing the car from dust --> My man eran
Quick masking job..
Blah..
b4..
primed..
Thats it for the day, will sand tomorow maybe one more time prime it, watersand and ready for paint! YESSSIR! hope you enjoyed. Feel Free
to ask questions.
Old 11-03-2009, 05:59 PM   #12
Duc_du
Duc_du's Avatar
nice. look forward to see tomorrow work!!
Old 11-04-2009, 06:32 PM   #13
skthx
skthx's Avatar
Default Re: DC2 Quarter Panel Repair PAINT ready
sanded primer, primed again...
Machined with 320.
Started water sanding.. with 600 over everything with the exeption of the uper quarter panel trim, and of the two fenders with 2000 since its only being blended. (clear coat only).
Turned out the kid partially painted the bumper with a spraycan before and didn't even clear it lol ... Going to repaint the whole bumper now..
Sanded...
Washed, thinned inner trims of oversprayed primer, will mask the car tomorrow and shoot it friday or early saturday.
This was a fun project, but, shows how a small job can go far. If you don't know much about bodywork, you will, in the end pay someone else not to only finish the initial damage but cleaning the mess of your work
Will give you guys the paint tips and which paint / clear / gun im using when i spray it.
Old 11-04-2009, 07:23 PM   #14
Spawne32
1995 Acura Integra
what kind of primer did you use?
Spawne32 is offline Report Post   Reply With Quote
Old 11-05-2009, 07:45 PM   #15
slow_srt
slow_srt's Avatar
Quote:
Is this your dads work you were talking about in another thread?
__________________
60% of the time, it works everytime...
slow_srt is offline Report Post   Reply With Quote
Old 11-05-2009, 07:49 PM   #16
Spawne32
1995 Acura Integra
Quote:
what?
Old 11-05-2009, 07:56 PM   #17
Blk99ek
that passenger side doesn't look right
Blk99ek is offline Report Post   Reply With Quote
Old 11-05-2009, 07:59 PM   #18
Spawne32
1995 Acura Integra
Quote:
well it doesnt look like it was done with galvanized steel, and it doesnt look like he treated the welds behind the panels at all, so its just gona rust again from the back side of the panel.
Old 11-07-2009, 12:48 PM   #19
jcdimvic
i would have used some rust mort behind the quarter, its cheap insurance that the rust doesnt take control again. It only takes 0.006 of a square in for the rust to reappear
jcdimvic is offline Report Post   Reply With Quote
Old 11-07-2009, 10:42 PM   #20
lil_cook97
Quote:
I could tell you in one simple word...this wasn't goin to be easy to begin with from the beginning!
__________________
Love it or Hate it...get over it!
lil_cook97 is offline Report Post   Reply With Quote
Old 11-08-2009, 11:53 AM   #21
slow_srt
slow_srt's Avatar
Quote:
How is that one simple word exactly?
__________________
Old 11-08-2009, 08:22 PM   #22
skthx
skthx's Avatar
lol i sealed the weld spots.. especially on the other side & one stepp'ed & undercoated. car is painted ... just need to polish out the top .. will take some pics tomorrow
Old 11-08-2009, 10:22 PM   #23
lil_cook97
I meant a couple of words smart ass!
__________________
Old 11-08-2009, 10:30 PM   #24
lil_cook97
How do you know this? are you a body tech? I've seen this done and its never rusted from the under side. Its true it is a fifty fifty chance it might show up again depending on how well he primer and color the whole underside and top along with his body work. I've even done it myself buy not on my hatch. Yeah but you are right so I'm giving the guy his other alternative since he doesn't have access to a MIG welder.
__________________
Old 11-21-2009, 10:52 AM   #25
skthx
skthx's Avatar
will repaint bumper after winter.
Bookmarks
Tags
acura, bondo, civic, dc2, fiberglass, filler, honda, hondatech, panel, panels, quarter, repair, replacement, shaping, soak, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
