New JS Boost Controllers - Single and Dual Stage Units
Introducing the new JS boost controller line up. These Boost controllers were designed and tested by a customer of mine and they have been proven to work very well. I can vouch for the quality and performance of the units.
JS Single Stage Boost Controller - $50 shipped
This is a simple single stage unit that allows you to increase the amount of boost you can run over your wastegate pressure.
I have personally used this unit and can vouch for its ease of use and setup.
JS Dual Stage Version I Boost Controller - $100 shipped
This is a simple dual stage boost controller which has the first stage set as your wastegate pressure and the second stage is adjustable to your desired pressure over the wastegate spring pressure. The two stages are controlled by a solenoid and can be switched by wiring up a simple switch.
JS Dual Stage Version II Boost Controller - $130 shipped
The Version II Dual Stage controller is similar to the Version I with the difference being that both stage I and stage II are adjustable over your wastegate spring pressure. Again it is controlled by a solenoid and the stages are controlled by wiring up a simple switch.
For more information please visit JS Boost Controllers
Any questions please email me at john@j-k-tuning.com or send me a PM.
Re: New JS Boost Controllers - Single and Dual Stage Units
Great product, I will never run any other MBC again, these things match and even out perform the top dogs while costing pennys on the dollar.
I just got one and its every thing it was advertised to be. Great seller and top notch product. Thanks!
ive purchased one of these mbc and it rocks. Def see a diff from any cheapo to this one, once i upgrade my setup will be purchasing one of the dual stages. Good quality Good craftsmanship and have had buddies sell their name brand mbc to switch to these. Thumbs UP
I will vouch for this product, have seen it in action first hand and the results are awsome. BIG UPS to the BEST MBC on the market yet!
Just stuck another one of these on a buddys turbo civic , once again dead steady boost and steady spool. buy these up guys you wont be left down.
