New OEM Brake Upgrade Option -- S2000 & RSX Type-S -- Installed, Tested, & Reviewed
#51
Here is the stuff I found. Added a couple of cars. Hope this helps. I can keep updating it as I find more info. And convert everything from inces to mm. Anyone need any specs for their car just let me know. Glad to help another Luder.
Technical Information:
Here are Spec's for the Related Material that has been mentioned throughout this Review. Hopefully we can find all this information and complete this Spec Sheet.
S2000 Spec's
Caliper
Piston Size: 2.0"
Weight: Approx. 9.5lbs (Loaded)
Rotor
Diameter: 11.8"
Width: 24mm
Bolt Pattern: 5x114.3
Hub Size: 70.3mm
Height: 39.6mm
Weight:
06 RSX Type-S Spec's
Rotor
Diameter: 11.8"
Width: 25mm
Hub Size: 64.2mm
Height:46.99mm(47mm)
Weight:
91 NSX Spec's
Caliper
Piston(s) Size: 34mm and 36mm (I believe this is correct.)
Weight: Approx. 12lbs Unloaded (Caliper + T28 Bracket, Info from Televator)
Rotor
Diameter:11.1" inch
Width: 28mm
Hub Size: 70mm
Height: 35.9mm
Weight:
98 NSX Spec's
Caliper
Rotor
Diameter:11.7" inch
Width: 28mm
Hub Size: 70mm
Height: 36mm
Weight:
94-95 4DR Legend GS Spec's
Caliper
Piston(s) Size: 36mm and 38mm (I believe this is correct.)
Weight:
Rotor
Diameter: 11.1"
Width: 28mm
Hub Size: 70.2mm
Height: 47mm
Weight:
4thGen Prelude S & Si Model Spec's
Caliper
Piston(s) Size:
Weight:
Rotor
Diameter: 10.2"
Width: 23mm
Bolt Pattern: 4x114.3
Hub Size: 64.3mm
Height: 47.2mm
Weight:
4thGen Prelude VTEC Model Spec's
Caliper
Piston(s) Size:
Weight:
Rotor
Diameter: 11.1"
Width: 23mm
Hub Size: 64.3mm
Height: 47mm
Weight:
5thGen Prelude Spec's
Caliper
Piston(s) Size:
Weight:
Rotor
Diameter: 11.1"
Width: 23mm
Hub Size: 70.2mm
Height: 47mm
Weight:
'99 - '00 Acura RL Spec's
Rotor
Diameter: 11.8"
Width: 28mm
Hub Size: 70.3mm
Height: 47.2mm
Weight:
06' Acura 3.5RL Spec's
Brembo Style 4pot Calipers
Rotor
Diameter: 12.6"
Width: 28mm
Hub Size: 70.2mm
Height: 50mm
Weight:
08' Acura TL TYPE-S MT Spec's (AT specs are different)
Rotor
Diameter: 12.2"
Width: 25mm
Hub Size: 64.2mm
Height: 45mm
Weight:
S2000 Spec's
Caliper
Piston Size: 2.0"
Rotor
Diameter: 11.8"
Width: 24mm
Hub Size: 70.3mm
Height: 39.6mm
Weight:
Rotor
Diameter: 11.8"
Width: 25mm
Hub Size: 64.2mm
Weight:
91 NSX Spec's
Caliper
Rotor
Diameter:11.1" inch
Width: 28mm
Hub Size: 70mm
Height: 35.9mm
Weight:
98 NSX Spec's
Caliper
Rotor
Diameter:11.7" inch
Width: 28mm
Hub Size: 70mm
Height: 36mm
Weight:
Caliper
Weight:
Rotor
Diameter: 11.1"
Width: 28mm
Hub Size: 70.2mm
Height: 47mm
Weight:
Caliper
Piston(s) Size:
Weight:
Rotor
Diameter: 10.2"
Width: 23mm
Hub Size: 64.3mm
Height: 47.2mm
Weight:
Caliper
Piston(s) Size:
Weight:
Rotor
Diameter: 11.1"
Width: 23mm
Hub Size: 64.3mm
Height: 47mm
Weight:
Caliper
Piston(s) Size:
Weight:
Rotor
Diameter: 11.1"
Width: 23mm
Hub Size: 70.2mm
Height: 47mm
Weight:
Rotor
Diameter: 11.8"
Width: 28mm
Hub Size: 70.3mm
Height: 47.2mm
Weight:
Rotor
Diameter: 12.6"
Width: 28mm
Hub Size: 70.2mm
Height: 50mm
Weight:
Rotor
Diameter: 12.2"
Width: 25mm
Hub Size: 64.2mm
Height: 45mm
Weight:
#53
Re: New OEM Brake Upgrade Option -- S2000 & RSX Type-S -- Installed, Tested, & Review
Just a heads up. Gonna be doing a 5 lug swap onto one of my ludes so as soon as I get that done I'm doing the Legend Swap.
#54
http://hondamarketplace.com/showthread.php?t=2427063
just weighted the brembo calipers with pads 7.5lbs. Will get the weight of rotors soon if anyone is interested.
#55
Aren't the RSX and S2000 calipers the same? If not, couldn't you have used the RSX calipers also?
#56
Been out of the loop for a while and didn't write out all the math, but is this really beneficial? The rsx-s rotors will increase brake tq by 8% over vtec rotors. Thats a good mod. But to reduce caliper caliper piston area by 21% seems like a step in the wrong direction. The si and vtec calipers may be different in size and the pads it takes but the piston sizes are the same (2.25") making them equals in brake tq. Increasing the rotor diameter by 1" increases its tq by 11%. The only benefit in this mod that I see is that the brake bias is moved toward the rear of the car. This would be good for a lowered car because of the reduced weight transfer to the front wheels during braking. Am I missing something?
#57
^Really want more info on this, just waiting for my Si pads to wear out before upgrading the front. Hopefully someone who really knows brake systems can step in and clear some things up like if this will indeed give better braking performance since biasing more towards the rear even with a firm suspension that doesn't transfer the weight forward seems more like a downgrade even if it is physically bigger.
#58
Want to use s2000 calipers on my setup
i have accord twin pot calipers with 282mm 4x100 rotors
GreenBean
36
08-31-2004 07:05 PM
cobalt
35
10-05-2002 09:31 PM
fastbrakes
02-21-2002 02:09 PM
