97 Civic/B16a2 swap acting up - can't figure out idle problems
Old 05-24-2011, 09:03 PM
89efDUSTY's Avatar
Default 97 Civic/B16a2 swap acting up - can't figure out idle problems
Sorry for making a thread, I have been out of the honda scene for a while but my friend's civic is goofing off. The car's idle is very low (200-300rpm) when started but builds up to 800 after around 20 seconds. When the throttle is opened the car dips before the rpm can go up, once released the idle drops very low and the car nearly dies.
We checked spark, and cleaned out the IACV and idle control screw. The car is throwing no codes, and there is no misfires (drives great when accelerating, just nearly dies when releasing the throttle).
Car is 97 civic and has a 2000 civic SI b16 motor...he has not done any modifications to car in months. I'm thinking it is fuel related, but I am not sure how to check on this car.
Any help is greatly appreciated, thank you!
Old 05-24-2011, 09:36 PM
89efDUSTY's Avatar
Default Re: Car acting up can't figure out idle problems
Also we sprayed carb cleaner on all the vacuum lines to see if we could get the idle to move and nothing happened. Any help or links provided would be awesome because it is his only car, thank you!
Old 05-24-2011, 09:42 PM
civic-steve-94's Avatar
fuel filter maybe i had a bogging problem when mine was clogged
but since its not throwing any codes its something mechanical check timing could have randomly jumped
Old 05-24-2011, 10:22 PM
hytechb20's Avatar
Sounds like the tps sensor. Start the car, unplug the sensor for a few seconds then plug it back in. If it idles fine after that you need to replace the sensor.
Old 05-25-2011, 07:27 AM
89efDUSTY's Avatar
Thanks he hasn't replaced it in years so I'll let him know since it is such a cheap easy fix.
Great we will test it out later and report back.
Thank you both for your insight and if anyone else has any ideas please feel free to post up.
Also, I am pretty sure it is not related to coolant temp or the temp sensor because the car heats up normal and guage is fine.
Old 05-25-2011, 09:11 AM
that_boy_sammy's Avatar
Tps sensor, low voltage from an alternator can also make the car funny. Check the tps first though.
Old 05-25-2011, 02:53 PM
89efDUSTY's Avatar
He said he started the car and pulled the TPS, the idle jumped around and plugging it back in didn't fix it. Sounds like it is bad right?
Old 05-25-2011, 06:54 PM
No. If you unplug the tps and it idles fine after, thats how you know the tps is bad. If the idle is still jumping around with the tps unplugged it is something else. Try starting the car and unplugging the IACV wire and see if it idles fine after that. Even though you cleaned it, it still could have gone bad.
Old 05-25-2011, 06:59 PM
h22acd5's Avatar
I had the same problem it was a vacuum leak the fluted from my intake chewed the metal hose to the ac and made a gaping hole did t notice it because the filter was over the hole check that. If your filter reaches that far down there
Old 05-25-2011, 10:47 PM
89efDUSTY's Avatar
Sweet thanks guys, I'll check with him tomorrow!
Have a great night everyone!
Old 05-26-2011, 05:09 AM
Former User's Avatar
When was the last ignition system tune up done (plugs, wires, cap, rotor)? Is the ignition timing set to spec?
Did he follow the service manual procedure for adjusting the idle speed?
Old 05-26-2011, 05:14 AM
Procedure for adjusting the idle speed on the 99-00 B16a2 engine:
ek.troy
12
02-13-2012 03:45 PM
frankenghia
05-09-2011 08:05 PM
b16crx88
03-19-2005 11:14 AM
Quick Reply: 97 Civic/B16a2 swap acting up - can't figure out idle problems
