1995 Civic EX ABS Cel
Hello guys today I did my suspension swap for my 1995. From Oem, to Tein Super Street. I did everything I remember correctly and what not. When I finished the swap my ABS light was turned on????? -_- Any hints on what this could be if any one has had it happened to them. It is in my 1995 Civic Sedan EX. Thanks YOU
Re: 1995 Civic EX ABS Cell
Start off with checking and cleaning your abs sensor, wildoutgsr did a nice write up for you to follow.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-%2A%2A%2A-check-clean-your-rear-abs-wheel-sensor-2205909/
Jump the service connector to pull the ABS code. The ABS light will blink the code(s), just like pulling CEL codes.
Ok cool I will try that, I just went for a ride and when I start the car, the ABS light truns on and goes away. After I start driving after about 20 seconds it truns on. That usually is a sign of? Also do abs lights turn on if any wheel is loose?
4-2 Circuit of left hand front wheel speed sensor
Thats is the Code that it gave me any ideas? When I was putting the suspension on I pulled the brake and heard a cable pop I was like OOOO lol but when I took a look it was just a rubber part that had broke didnt seem important. I dont know if that has anything to do with it. Thank You.
I inspected the sensor and wire, and they seemed to be in really good shape. I am going to try and clean it, but if that does not work I dont think i want to spend that much money on a new speed sensor. Is it worth to just get that off.
Today I will be going to get it tested.... I remember pulling the whole brake system and hearing something pop. No lines broke but I know it came from the ABS like in the Front Driver, on the side im getting code. Could that have created a short in the system? What gets me is that nothing seems broken and I inspected it today. The front sensors should be cleanred as well correct?
Hey question, I was looking today at wheel speed sensor and I noticed they come with the wire that connects them. That same wire was the one that I pulled and hear a loud pop. My assumption is I caused a short in that wire causing that whole sensor to messed up could I be correct?
at the jetties fishin'
LS1powered
04-27-2006 09:13 PM
