JDM D15B (non-vtec)?
Ok so I picked up a EE wagon a couple weeks back, and been so busy havn't really had time to poke around in the engine bay. So being not as familiar with the D series motors as I am with the B series.
The block is stamped D15B which I thought was only a JDM Vtec motor. Did they make a (non-vtec) version? I'm assuming I just have a D15B block with a non-vtec head.
YES I SEARCHED! Any info would be appriciated.
I've attached 2 quick pics taken with my cam phone, not the greatest.
A lot of JDM motors are vaguely stamped, many D series are just stamped D15B. In fact, my D15Z1 is stamped D15B. The D16Z6 equivalent is stamped D15B also, so I wouldn't be surprised if the others were as well.
Re: JDM D15B (non-vtec)?
i gotta bring this old thread back, i bought a D15B from the junk yard thinking it was JDM D15B Vtec but it had a non v tec head on it. and the pistons were stamped pm3 does this mean its pretty much a d15b7? or better?
The D15B is a JDM engine that came in several different variations in several different cars from 1988 to 2005 – This is a partial list (there are more) of the various D15B configurations and the cars they came from in Japan:
OBD0 - Single Carb – Compression Ratio 9.2:1 – 91ps – Found In:
88-91 Civic 4 door Sedan – Models 35M and 35U
88-91 Civic 3 door Hatch – Model 25R
OBD0 – Dual Carb – Compression Ratio 9.2:1 – 100ps – Found In:
88-91 Civic 4 door Sedan – Model 35X
88-91 Civic 5 door Shuttle – Model 55X
88-91 Civic 3 door Hatch – Model 25X (105ps in 5 speed – 100ps in automatic)
88-91 CRX – Model 1.5X (105ps in 5 speed – 100 ps in automatic)
OBD1 – Dual Carb – Compression Ratio 9.2:1 – 100ps – Found In:
92-95 Civic and Civic Ferio – Model MX
OBD1 – VTEC – Compression Ratio 9.3:1 – 130ps – Found In:
92-95 Civic and Civic Ferio – Model VTi
93-95 CRX Del Sol – Model VXi
OBD1 – VTEC-E – Compression Ratio 9.3:1 – 94ps – Found In:
92-95 Civic and Civic Ferio – Model ETi
OBD2 – Non-VTEC – Compression Ratio 9.4:1 – 105ps – Found In:
96-2000 Civic 4 door Sedan – Model Ri
96-2000 Civic Ferio Sedan – Model Mi
97-2000 Integra SJ (Joyful Sedan) – Models LXi and EXi
OBD2 – VTEC – Compression Ratio 9.3:1 – 130ps – Found In:
96-97 CRX Del Sol – Model VXi
OBD2 – VTEC (3 Stage) – Compression Ratio 9.6:1 – 130ps – Found In:
96-2000 Civic 4 door Sedan – Model VTi
96-2000 Civic Ferio Sedan – Model Vi
97-2000 Integra SJ (Joyful Sedan) – Model VXi
2001-2005 Civic Type B
2001-2005 Civic Ferio Type C and Type C4 (4wd)
OBD2 – VTEC – Compression Ratio 9.9:1 – 115ps – Found In:
2001-2005 Civic Type G and Type G4 (4wd)
OBD2 – VTEC Lean Burn – Compression Ratio – 10.2:1 – 105ps – Found In:
2001-2005 Civic Type Ie
Hi there,
I currently own a JDM civic with a D15b engine which is dual carb and non V-Tech ('91). Engine produces 106hp(ps) and looks very similar to your engine in the photo. the V-Tech engine was D15B1 or D15B3 for a three stage V-Tech controller I think!
All the info you need on engine spec; try
www.wikipedia.org/wiki/Honda_D_engine
I bought a d15b that was jdm, then swap'd into a sedan. Im swaping it to mpfi and then into my 91 Canadian hatch. ill produce about 115 hp. so listen to that!
sorry to once again bring this thread back but im really confused, i bought a 1993 civic hatch it is bone stock it has ac but no power locks or windows or power steering its a manual and the engine says 16 valve and has the honda emblem set off to the side, the block is stamped d15b but every picture i see of a d15b in a 1993 civic eg hatch says vetec on it, mine isnt a vetec it has an intake tube about the size of a paper towel roll.....its the smallest tb iv ever seen in my life...im pretty sure my lawn mpwer has a bigger one lol, iv got a z6 head and intake mani to swap on, my engine is already mpfi, im so confused, also i have no idea what trim i have
PLEASE HELP!!!
PLEASE HELP!!!
Awake the dead thread.
I recently bought a 92 DX hatch, it has has a D15B non vtec I know it's not original to the car. How do I figure out if it's an older motor meant for the older carbureted civics. I'm looking for a thread that has good references on how to properly swap a jdm D15B non vtec into a non vtec dx hatch, wiring and sensors. If I were a betting man I would say it's a non vtec D15B with the intake and throttle that was on the original engine. Any references would be greatly appreciated.
I say Why make new threads for the same topic
aquabob89
33
01-19-2020 08:56 PM
